Feb 2005 Porsche 997 C2S with 52k miles
Mileage Oil change date
17,242 4,183 19-Nov-09 Mobil 1 0W40
21,752 4,510 07-Jan-11 Mobil 1 0W40
28,230 6,478 31-Jan-12 Mobil 1 0W40
32,914 4,684 05-Jan-13 Mobil 1 0W40
38,193 5,279 27-Dec-13 Mobil 1 0W40
40,353 2,160 10-Jul-14 Millers NT Nanodrive 5W40
45,644 5,291 01-Jul-15 Millers NT Nanodrive 5W40
48,812 3,168 16-Jun-16 Millers EE Nanodrive 5W40
Ok so above is my oil service history since I have owned the car. Oil changed every year, and I do about 3.5 - 5k miles a year.
Whilst the car was below 40k miles I was using Mobil 1 0W40, and oil consumption was below 1.5 litres during the year.
I switched to Millers 5W40 at 40k miles, and straight away noticed a little more oil consumption, however still below 1.5 litres.
Since my last oil change on 16-Jun-16, I have done about 2k miles, used what felt a little more than usual (0.5l) until a couple of months ago and only got round to checking it today.
So today I saw it two bars down (never seen it that low before), and had to top up with 1 Litre. I know a lot of you will say that is normal, however this is a first for my car, and somewhat worrying for me.
In addition to this, I was noticing a little coolant loss, and this is going back to May-13 (at 33k miles). I had the coolant changed, installed a LTT, checked all the Rads for leaks and found nothing. After the coolant change, and a few small top ups straight after, the coolant level stabalized, and was fine for a while. Last couple of years, I have had to do some top ups.
I took it to an indi in Aug-16 to check for leaks, and got told it was all fine (only thing not checked was front rads, as it required front bumper removal), and 0.5L every six months is normal (BS as it is a sealed system - didn't agree at the time, but accepted it). Was also told the water reservoir doesn't leak - which is again BS, so paid an hour's labour and left with little faith in anything else I had been told.
I began keeping a record of coolant top-ups:
22-Dec-15 Coolant topped up 550ml 47,277
26-Jul-16 Coolant topped up 450ml 48,993
So today when I checked coolant level, it was well below min level, and had to top up with a whopping 1.5l. Again a bit of a shock to see it so low.
Engine sounds fine, no blackened tailpipes, no blue smoke, coolant is pink and no froth, as far as I can tell (with no dipstick) there is no mayo in filler cap, and I think oil is ok.
Something is not right, and I plan to take it somewhere more reliable who can do a more thorough check for the coolant loss, and not make me feel like I have wasted my time and money like my recent experience. And also thinking a compression test and boroscope is likely needed.
I am thinking this time I need to get it to Hartech, in the hope they will know what to look for, and resolve it as efficiently as possible!
Any thoughts/advice?
