997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
Stuart Mackay
PostPosted: Fri Jul 07, 2017 7:29 pm    Post subject: Reply with quote
Very happy bunny today as car has just returned from Porsche Colchester, who seem to have sorted the intermittent Temp Indicator Failure that has annoyed me for the last 12 months. I replaced the water temp sensor on the block with new a few weeks ago and this did not cure this annoying fault.
I had noticed that the engine wasn't reaching 80 C when under light load, and the failure indicator would come on at around the 70C which made me think it was a thermostat issue. Also, it seemed to all work fine when on track under heavy load, so was getting a bit confused with cause and effects.
It appears the cause wasn't directly related to the temperature sensor circuit on the engine, but it was a faulty gearbox cooling solenoid that had stuck open and was allowing the coolant to pass permanently through the gearbox rad, thus overcooling the engine under light loads. Apparently, this is an occasional fault, and without the experience of the Tech at Colchester, Kev Stevens, I would have carried on down the merry path of engine temp circuit investigations.
see Health Check vid from Colchester (ignore the tyre comments, the geo was out and new tyres are on order!)
https://video.citnow.com/vtXZbDK260f
Oh and the bill??...a very reasonable £165 including 70 mile pick up and delivery thumbsup thumbsup
2007 Speed Yellow 997 Carrera GT3 CS
2002 Guards Red Aerokit 996.2 C4S Cabriolet
2000 Westfield Cosworth
Stuart Mackay
PostPosted: Mon Sep 11, 2017 8:57 am    Post subject: Reply with quote
Fitted some Eurocup GT carbon mirror triangles and here is the procedure for those who also feel there life is not complete without them!
You need to remove both mirror assemblies from car, Torx screws on inside behind inner triangle.
The mirror and casing need to be disassembled. Single screw on lower mirror body and be careful you dont break the moulded tabs on the plastic casings.
The mirror arm is fixed to the outer triangle with 3 small T8 Torx self tappers.
Remove the rubber gasket and you should be able to remove the mirror mechanics from the triangle by squeezing the arms gently.
Assembly is a reverse of the above. Fit the gasket after you have the mechanics through the triangle.
The small Torx self tappers were too small for the Carbon triangles, so either fill with epoxy or use a piece of cocktail stick inserted into hol;e in C/F part to give the retaining screws something to bite onto.
Nicely moulded and a massive weight saving puh puh
Next mod will see the car being returned to Matt at Fearnsport for a Nitron suspension set up and Winter check over.
 Filesize:  577.83 KB
 Viewed:  6081 Time(s)
Stuart Mackay
PostPosted: Mon Sep 11, 2017 10:07 am    Post subject: Reply with quote
Refurbed garage floor over the past couple of weeks and used the Duramat UK 500mm interlocking PVC tiles, pleased with results. thumbsup
 Filesize:  222.66 KB
 Viewed:  6071 Time(s)
Stuart Mackay
PostPosted: Sat Oct 21, 2017 12:59 pm    Post subject: Reply with quote
Dropped car off with the very talented brace of Matt's at Fearnsport for fitting of Nitron suspension/geo and for Matt Counsell' s expert annual inspection and oil change. OMP wheel and replace rattling PSE exhaust diverter valves.
Was treated to Matt firing up the F40 that he has been building for the last year and most impressed with the level of detail engineering that Matt has put into the build.
 Filesize:  132.94 KB
 Viewed:  5698 Time(s)
Stuart Mackay
PostPosted: Thu Oct 26, 2017 11:32 pm    Post subject: Reply with quote
Guess where I have been today? thumbsup
 Filesize:  370.61 KB
 Viewed:  5725 Time(s)
Stuart Mackay
PostPosted: Thu Oct 26, 2017 11:44 pm    Post subject: Reply with quote
Nitron 3 ways fitted with new springs and one of Matt's extensive geometry set ups. Also fitted the OMP wheel and annual oil change/checkover and new PSE valves fitted.
Pic below shows Matt's neat work of fitting the rear shock remote reservoir canisters utilising the rear engine mounts to solidly fixi the reservoirs in place yet still allow easy access for damper setting adjustment.
Whilst there, Ibrahim showed up with the Ekanoo/ES Motors 1700 hp Turbo drag car for Matt to continue work his magic on the car (currently 8.47sec 1/4 mile and 240 mph V Max!!!)
https://www.youtube.com/watch?v=mzXyKzE543w
https://www.youtube.com/watch?v=eX__IkV1M1M
 Filesize:  408.54 KB
 Viewed:  5723 Time(s)
Stuart Mackay
PostPosted: Thu Nov 23, 2017 8:39 pm    Post subject: Reply with quote
Have just fitted a Rennline "strut brace" so that I could mount the front reservoirs in a convenient position.
The plastic covers will go back over these new parts.
 Filesize:  741.01 KB
 Viewed:  5436 Time(s)
Roro
PostPosted: Fri Nov 24, 2017 5:52 am    Post subject: Reply with quote
Interesting, isnt there one as standard fit? I can't remember seeing one in mine last time I looked Question
2007 997.1 GT3
2017 F87 M2
NXI20
Paul Ricard
2004 Porsche 996 GT3 Mk2
PostPosted: Fri Nov 24, 2017 8:46 am    Post subject: Reply with quote
No, there are reinforcing bars between the turrets & the bulkhead which do a better job of anchoring the turrets anyway. The race cars don't use a strut brace so I don't suppose it's doing much for added stiffness. The RS & GT2 993 cars had a strut brace as standard from the facrory though.
Shell construction & stiffness has moved on so much since the 993 that I doubt a strut brace on the later cars is anything more than added bling.
Nick
1978 Carrera SC Barn Find in Red (restoration project)
Roro
PostPosted: Fri Nov 24, 2017 9:35 pm    Post subject: Reply with quote
There's nothing wrong with added bling (says the man with the gold wheels Grin )
2007 997.1 GT3
2017 F87 M2
Stuart Mackay
PostPosted: Sat Nov 25, 2017 10:11 am    Post subject: Reply with quote
I am sure Nick's comments are valid, hence my original "strut brace" comment in inverted commas, now all I need for the "full bling" is Nitron to make some gold anodised reservoir mounts!
Bigfra
PostPosted: Mon Nov 27, 2017 10:26 am    Post subject: Reply with quote
That OMP wheel adds about 15bhp mate, deffo Question Grin Thumb
Stuart Mackay
PostPosted: Wed Dec 27, 2017 8:20 pm    Post subject: Reply with quote
My daughter bought me these natty little CNC machined mounts from Nitron as a Christmas pressie to replace the tie wraps used originally, here they are fitted.
 Filesize:  960.68 KB
 Viewed:  4841 Time(s)
Johnd52
2011 Porsche Cayman 987
PostPosted: Wed Dec 27, 2017 10:20 pm    Post subject: Reply with quote
A neat way of making the brace useful😊
2015 Cayman GTS. No more PDK but still red.
Stuart Mackay
PostPosted: Sat Feb 17, 2018 6:40 pm    Post subject: Reply with quote
First Track day of the season today at Snett, absolutely perfect conditions to test out the new Nitron Suspension and Fearnsport set up in earnest.
Hopefully you can see this Instagram post from today.
https://www.instagram.com/p/BfS57tGFPWU/
Stuart Mackay
PostPosted: Tue Feb 20, 2018 8:48 pm    Post subject: Reply with quote
Exiting Murrays onto Senna Straight at Snett on Saturday 17th,
The Nitrons and Fearnsport set up are sublime.
 Filesize:  264.79 KB
 Viewed:  4184 Time(s)
Mitch312
PostPosted: Wed Feb 21, 2018 8:48 am    Post subject: Reply with quote
Car looks great Stuart. Same dampers I had on my 996, incredible improvement over stock.
996.2 GT3 Club Sport - SOLD
BMW 1M - SOLD
Caterham CSR
Caterham 420R
NLW73
PostPosted: Wed Feb 21, 2018 1:51 pm    Post subject: Reply with quote
looking great stu and the stance and ride height is great. serious set up on the car too now.
speed yellow GT3s are just so so good!
997 C2s Schwarz
Stuart Mackay
PostPosted: Fri Feb 23, 2018 10:20 pm    Post subject: Reply with quote
In car vid from Snett last Saturday
https://youtu.be/xqBs2v5pyP4
 Filesize:  700.56 KB
 Viewed:  4074 Time(s)
Stuart Mackay
PostPosted: Fri Feb 23, 2018 10:30 pm    Post subject: Reply with quote
And now trending on Instagram Smile
Goto page Previous  1, 2, 3, 4  Next
Page 2 of 4
