997 : 2004- 77
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 12
Stuart Mackay
PostPosted: Sat Dec 03, 2016 5:35 pm    Post subject: 997 GT3 Clubsport running report and upgrades Reply with quote
Dropped the yellow thing off at Fearnsport's GT Emporium at Siverstone today for Matt to work his magic, planned are:
-Set of big Alcons, thanks Nick for supplying so promptly!
-Gearbox checkover/refresh and fit Cup diff plates, again thanks Nick for recommendation!
-Fit double pump stainless cover and replace scavenge pump O rings
-Sort out "failure Indicator" on water temp gauge, fault reader shows a stuck thermostat, or is it an intermittent connection?
Oh and some new wheels!
thumbsup http://www.fearnsport.co.uk/about_us.html
2007 Speed Yellow 997 Carrera GT3 CS
2002 Guards Red Aerokit 996.2 C4S Cabriolet
2000 Westfield Cosworth
 Filesize:  142.1 KB
 Viewed:  13841 Time(s)
Stuart Mackay
PostPosted: Sat Dec 03, 2016 5:37 pm    Post subject: Reply with quote
Nice noses!
 Filesize:  216.33 KB
 Viewed:  13839 Time(s)
Stuart
2004 Porsche 996 GT3 Mk2
PostPosted: Sat Dec 03, 2016 6:38 pm    Post subject: Reply with quote
Any more pictures of that green 996GT3?
In good hands with Matt...
911tom
Watkins Glen
PostPosted: Sat Dec 03, 2016 8:27 pm    Post subject: Reply with quote
Matt is a good guy, you won't go wrong but he had better finish building my engine first lol. Can just about see my car, silver turbo at the front of the que.
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
718 Cayman GTS
350Bhp astra van for work, semi-retired from daily duties
2009 Ariel Atom 3 Supercharged SOLD but never forgotten
Stuart Mackay
PostPosted: Thu Dec 22, 2016 9:21 pm    Post subject: Reply with quote
Well, most impressed with the work Matt has done on the car, as well as fitting the Cup diff plates, refresh of the gearbox, fitting the Alcons, and a major service, it was an absolute delight to be able to experinece the care and attention that Matt has lavished on the car over the past couple of weeks,
 Filesize:  960.94 KB
 Viewed:  13524 Time(s)
Stuart Mackay
PostPosted: Thu Dec 22, 2016 9:25 pm    Post subject: Reply with quote
380 diameter Alcons/ Pagid RS29s courtesy of Nick https://uber9s.com/997-gt-gen-1/.
Matt machined the calipersto fit the discs, made up spacers and fitted longer bolts to enable the fitment of the existing six pot calipers. Wow what a difference! thumbsup
 Filesize:  212 KB
 Viewed:  13522 Time(s)
Stuart Mackay
PostPosted: Thu Dec 22, 2016 9:32 pm    Post subject: Reply with quote
360mm Alcon rears, looks alone make it worthwhile!
Goodbye to cracked discs, hello brake feel and stopping power.
Thanks Guys! http://www.fearnsport.co.uk/
 Filesize:  203.45 KB
 Viewed:  13515 Time(s)
 Filesize:  203.45 KB
 Viewed:  13517 Time(s)
NXI20
Paul Ricard
PostPosted: Thu Dec 22, 2016 11:05 pm    Post subject: Reply with quote
Who says size doesn't matter Floor
Good to meet you today Stuart & glad you're pleased with the car. You just need to convince your wife that further upgrades are now justified...
Good luck!
BTW, the rears are 360mm not 362mm; 362mm are the largest we do for the front without having to mod the calipers.
Nick
1978 Carrera SC Barn Find in Red (restoration project)
Stuart Mackay
PostPosted: Fri Dec 23, 2016 8:16 am    Post subject: Reply with quote
Good luck!
Likewise, Nick! Was Great putting a face and a name together too!
Have corrected the size on the pics now.
Thankfully, Kay is very supportive of all things Porsche related, so hopefully, future tinkering support shall continue unabated!
Indeed, after we left you guys, we dropped into GPR and she bought me a nice Sparco race suit as a Christmas pressie, for when we do more trackdays, just need to learn how to "pedal" it now. Floor Floor
To save damage to her stilettos, these mats arrived today Very Happy
I reflected on your comments about ride height and that my car is set up for Green Laning in Norfolk Very Happy , you mentioned a webpage or site, where I could read a bit more info on GT3 set up, but in the excitement of collecting the car, I forgot the name, perhaps you could remind me of the name of it? Embarassed
 Filesize:  59.46 KB
 Viewed:  13443 Time(s)
NXI20
Paul Ricard
PostPosted: Fri Dec 23, 2016 8:58 am    Post subject: Reply with quote
Not really an "it", more a "he" Wink
Roland Kussmaul was a Porsche factory race engineer for 30 years. He came up with the optimal GT3 track geometry setup on the 996 & it's a good starting point for both the 996 & 997.
Roland Kussmaul Specs:
Front axle:
Camber: -2.5º
Max camber difference, left/right: 5'
Toe total: +5'
Toe difference at 20° lock: -1°20' +/- 30'
Caster: 8° +/- 30'
Max caster difference, left/right: 30'
Front height: 115mm
Rollbar – 1 from hard
Rear axle:
Toe total: 35’ +/- 2'
Max toe difference, left/right: 5'
Camber: -2.3° +/- 5'
Max camber difference, left/right: 10'
Rear height: 128mm
Make sure you have the rear GT2 rollbar installed; the original is too soft.
Front toe out can make it a bit twitchy on the road so I prefer 0 front toe.
Nick
Stuart Mackay
PostPosted: Fri Dec 23, 2016 10:22 am    Post subject: Reply with quote
Brilliant Nick, thanks.
I ll put it on our laser alignment rig in the New Year!
Where are you measuring ride height to? Underside of sill?
GT2 bar already fitted so ready to get spannering! thumbsup thumbsup
NXI20
Paul Ricard
PostPosted: Fri Dec 23, 2016 10:32 am    Post subject: Reply with quote
Nooo - nowhere that accessible!
Nick
 Filesize:  75.1 KB
 Viewed:  13407 Time(s)
Stuart Mackay
PostPosted: Wed Mar 15, 2017 12:53 am    Post subject: Reply with quote
Got round to fitting the Manthey and Michelin Pile Ups this week thumbsup
 Filesize:  104.28 KB
 Viewed:  12719 Time(s)
Stuart Mackay
Rear 3/4
 Filesize:  120.73 KB
 Viewed:  12717 Time(s)
Stuart Mackay
PostPosted: Wed Mar 15, 2017 12:55 am    Post subject: Reply with quote
Front with Nick's shiny Alcons peeking through
 Filesize:  176.95 KB
 Viewed:  12716 Time(s)
Stuart Mackay
PostPosted: Wed Mar 15, 2017 12:56 am    Post subject: Reply with quote
Rear
 Filesize:  173.03 KB
 Viewed:  12715 Time(s)
Stuart Mackay
PostPosted: Wed Mar 15, 2017 12:58 am    Post subject: Reply with quote
Finally some truly essential interior parts, dunno how I survived all these years without them! Floor
See Ya at Goodwood MM at weekend?
 Filesize:  91.77 KB
 Viewed:  12713 Time(s)
Stuart Mackay
PostPosted: Tue Mar 28, 2017 5:31 pm    Post subject: Reply with quote
Found a BMC filter at a good price on the Bay, so this now nestling in my (engine) bay:
www.ebay.co.uk/itm/BMC-FB195-01-Panel-Air-Filter-Element-Porsche-911-996-Turbo-GT2-GT3-33-2189/301683348502
Stuart Mackay
PostPosted: Thu Apr 06, 2017 12:41 am    Post subject: Reply with quote
Well the new Alcon brakes from Uber9S, Cup LSD both ably fitted by Fearnsport, as well as the Manthey wheel/ Michelin Cup tyre combination with the reset Geometry certainly proved themselves yesterday.
I was really able to lean on it under braking and in cornering on it's first Snetterton trackday of 2017 on Tuesday.
Great Fun! thumbsup thumbsup
 Filesize:  833.07 KB
 Viewed:  12190 Time(s)
Stuart Mackay
PostPosted: Fri Apr 21, 2017 8:42 pm    Post subject: Reply with quote
In car vid from Snetterton Trackday in April
https://youtu.be/lvUV-R3bTuA
Goto page 1, 2, 3, 4  Next
Page 1 of 4
