991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
Zub-911
PostPosted: Fri Nov 25, 2016 9:11 am    Post subject: Idler / Tensioner bearing replacement Reply with quote
For those of you interested;
The correct bearing can be found here for a good price;
Manufacturer: FAG / SFK
Type: Double Row Angular Contact Bearing, Sealed
Side; 15 x 35 x 15.9 mm
Part number: 3202-BD-2HRS-TVH / 3202 2RS /
https://www.bearingbasement.com/product/bearings/3202-bd-2hrs-tvh-fag-double-row-angular-contact-bearing-sealed/
~ £18 / each and free shipping. Beats £60+ replacement items from porsche or OEM...
Just a case of pressing out the old and pressing in the new..
Freezing the bearing and heating the pulley may help.
I'll post some info when i do mine.
Neil
MY03 - 996 - C4S
Marky911
PostPosted: Fri Nov 25, 2016 9:14 am    Post subject: Reply with quote
Great tip, thanks. I'll save that link for future reference. Thumb
EGTE
PostPosted: Fri Nov 25, 2016 9:43 am    Post subject: Reply with quote
Great tip, but mine failed 2 months ago Smile
Ended up doing all 3, plus belt!
sneezebreeze
PostPosted: Thu May 30, 2019 8:18 am    Post subject: Reply with quote
Hi thanks for the tip here.
Does anybody you know if the bearings above are the correct spec for both idlers, and the tensioner.
I have a 996.2 C4 manual
I was previously looking at the Hamburg ones on design911 for £50 each, these all have different part numbers, so assumed there was a difference.
99710211700/1: https://www.design911.co.uk/fu/prod139542/Drive-Belt-Tensioning-Roller-Porsche-996---Boxster-987---Cayman-987C---997/
99710211900/1: https://www.design911.co.uk/fu/prod6704/Drive-Belt-Deflection-Roller-Porsche-996---987---997_2/
99710211800/1: https://www.design911.co.uk/fu/prod6702/Drive-Belt-Deflection-Roller-Porsche-996---987---997/
Many thanks
Zub-911
PostPosted: Thu May 30, 2019 9:43 am    Post subject: Reply with quote
The bearings can only be replaced in the metal pulleys.
I can’t remember how many are metal, 1 maybe 2.
The plastic moulded over the bearing cannot be replaced.
The bearings I specify are the correct spec. Identical to originals for the metal pulleys.
Very simple to press out and in.
MY03 - 996 - C4S
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu May 30, 2019 11:29 am    Post subject: Reply with quote
rockauto.com will do a pair of new dayco brand idler pulleys complete for about £50 delivered, I fitted some to mine 10 minute job and quietened the engine down (old bearings dead).
sneezebreeze
PostPosted: Sat Jun 01, 2019 11:25 am    Post subject: Reply with quote
Many thanks for the advice
skinny_monkey
PostPosted: Sun Jun 02, 2019 2:26 pm    Post subject: Reply with quote
£50 delivered from the states? Rockauto are US based right?
Zub-911
PostPosted: Sun Jun 02, 2019 3:00 pm    Post subject: Reply with quote
Or £18 each shipped? For the same FAG / SFK bearings hat Porsche use..
Question Dont know why would you use a more expensive non standard bearing?
MY03 - 996 - C4S
Rosselder83
PostPosted: Sun Jun 02, 2019 7:07 pm    Post subject: Reply with quote
Probably a stupid question but are the turbos the same?
sneezebreeze
PostPosted: Sun Jun 02, 2019 10:34 pm    Post subject: Reply with quote
Which ones in this pic can be replaced with the bearings you mention.
996.2 C4
Boxster S 550 Anniversary - for sale http://911uk.com/ads_item.php?id=9097
Carbon fibre seats X2 with black leather, and fittings - for sale http://911uk.com/viewtopic.php?p=1494798
Zub-911
PostPosted: Mon Jun 03, 2019 7:14 am    Post subject: Reply with quote
3, 8 & 7.
But check you don’t have the newer type plastic moulded in place of these.
https://www.mecatechnic.com/en-GB/poly-trip-rear-belt-idler-pulley-for-porsche-996-997-boxster-and-cayman-987_RS13447.htm?utm_source=google_shopping&utm_medium=cpc&utm_campaign=acquisition-produit&utm_content=RS13447&gclid=EAIaIQobChMI-Jqc3eHM4gIViLbtCh32NQyMEAQYByABEgI41fD_BwE
MY03 - 996 - C4S
P911X50
PostPosted: Mon Jun 03, 2019 11:24 am    Post subject: Reply with quote
Hi
Would these fit a 996 tt?
thumbsup
Porsche 996 Turbo X50 with 9e exhaust,
BMW M6 V10,
Previous
Evo 4 with Evo 8 MR Engine 360 bhp - Road Legal Track car
Previous
MR2 Turbo 280 bhp - Road Legal Track Car
PostPosted: Mon Jun 03, 2019 7:37 pm    Post subject: Reply with quote
996 Turbo is different ...well .. different engine anyways .. parts here ..
https://www.deroure.com/diagrams.asp?TBL=3208&MAK=3&MDL=28&SMA=0&SMO=0&ST=&SC=0
grbspeedster
PostPosted: Thu Jun 06, 2019 1:55 pm    Post subject: Reply with quote
Hi. Just had to replace one of mine, didn't see this until after I had bought one. Quick measure up and the bearings are the same in the turbo. I'm going to get a set in and replace the others during winter
Thanks Neil Thumb
Geoff
996 X50 turbo cab
Rosselder83
PostPosted: Thu Jun 06, 2019 2:05 pm    Post subject: Reply with quote
Thanks Neil Thumb
Handy to know, i think ill do the same.
P0tential
PostPosted: Sat Jun 08, 2019 9:24 am    Post subject: Reply with quote
Thanks for the bearing type! I need to inspect a few of mine to try and hunt down a slight whine from the aux belt area.
996 Carrera 4 Coupe
Locosaki
PostPosted: Sat Jun 08, 2019 11:57 am    Post subject: Reply with quote
I’ve just done as Wasz mentioned above. 2 idler pulleys delivered from rockauto for £50 delivered. Thanks for the head up Wasz.
Carrera 4 MY99 with full Hartech rebuild
Hertsdriver
2004 Porsche 997 Carrera 2
PostPosted: Thu Jun 27, 2019 3:51 pm    Post subject: Reply with quote
I love this forum! was about to shell out for 3 new idlers, but as I have the metal type I think i'll be ordering the bearings..... thumbsup
thank you!
Luddite
PostPosted: Thu Jun 27, 2019 5:00 pm    Post subject: Reply with quote
I have replaced a few bearings but not come across one that did not have it`s manufacturers I.D. etched on one of it`s sides as a series of numbers.
Of course Porsche will have their own part number for the bearing which will appear on their packaging or perhaps SKF or whoever manufacture the bearing will number it with a Porsche specific I.D. but I doubt it...?
With the manufacturers number it should be a simple matter of ordering it from somewhere like :-
https://simplybearings.co.uk/shop/?gclid=EAIaIQobChMI-tCeiI-K4wIVgQvTCh2n-wn5EAAYAiAAEgLUSvD_BwE
I have rarely purchased bearings from a main dealer unless they were other than standard in appearance...
