997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
rusape
PostPosted: Mon Nov 21, 2016 7:53 pm    Post subject: Precision Shift Coupler Reply with quote
Hi there, I'm a new owner of a 1983 3.0l sc, having come back to Porsche after some years away.
First owned one and a few others in the 80's and 90's, but fell out of love with Porsche with the demise of the 964.
Anyway my first post on here and wondered if anyone had fitted a precision coupler to their shifter in place of the sloppy OEM part and any feedback .
THIS TYPE[/img]
I have a sloppy lever and have tried in vain to adjust the OEM part with any measure of success.
Would welcome any guidance or advice.
Thanks all.
Soundbud
PostPosted: Wed Nov 23, 2016 10:27 pm    Post subject: Shift coupler Reply with quote
Hi, don't know if this is any good to you?
http://forums.pelicanparts.com/porsche-911-technical-forum/613632-shift-coupler-shift-lever-bushings-replacement-tutorial-made-easy-step-step.html
I got my 79 911 sc last month and it also needs doing.
When I got the car, the gears wouldn't go in properly, another member on here said I need to completely press the clutch pedal down which has helped and also the fan belt was loose (725mm belt). Now fitted 715mm belt with the same spacer setting and fits perfectly and the gears now go in as they should do. But they selector still feels a bit sloppy, so I think changing these bushes as mentioned in the link above should be a nice maintenance task.
Be nice to hear from other members of a nice upgrade here? Short shifter kit or something?
