997 : 2004- 64
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 10
Cayenne : 2003- 4
Macan : 2014- 1
lewisloo
PostPosted: Fri Nov 18, 2016 2:08 pm    Post subject: Rear fog Lights Reply with quote
Hi Guys
looking for any help on re locating the rear fogs on my 1984 3.2 Carrera from below the bumper to be included in the light strip, any ideas or fixes for this?
many thanks
Lewis
grbspeedster
PostPosted: Fri Nov 18, 2016 3:27 pm    Post subject: Reply with quote
If I remember correctly the later rear light strip has them built in. All you need to do is cut out the recess in the rear panel for the back of the light. Simple mod to do. Must be over 20 years ago I did mine😱 Must be getting old😀
Have a look on impactbumpers.com one of the guys on there deals in air cooled parts might have a later rear light in stock
Geoff
996 X50 turbo cab
Riviera Bob
PostPosted: Sat Nov 19, 2016 12:50 am    Post subject: Reply with quote
Just done this mod myself....lots of details on impactbumpers. You convert offside reverse light to foglight by extending and feeding foglight wire into light cluster through drainhole, disconnect reverse light feed and replace with foglight feed with female clip. Change white bulb to red led. No need to cut into wire harness and before anyone says anything, sails through MOT. May sound complicated but easy for even a dumbo like me....20 minute job!
BenC
PostPosted: Sat Nov 19, 2016 10:41 pm    Post subject: Reply with quote
as Bob says - easy enough to do.
Have a search on impactbumpers.com under 'reverse light mod' Smile
1997 Ocean Blue metallic manual Targa
lewisloo
PostPosted: Mon Nov 21, 2016 8:10 pm    Post subject: Reply with quote
Thanks for the info guys
