991 : 2011- 20
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
Cayman : 2005- 16
Dammit
PostPosted: Sat Oct 28, 2017 3:50 pm    Post subject: M509 - Feuerlöscher AKA Fire Extinguisher Reply with quote
This is a somewhat silly project that has started to take on a life of it's own, so I thought I'd try to assemble all the information in one place should anyone else wish to add factory option M509 to their 996.
This is the diagram showing a 996 sport seat and the bracket, cradle and associated fixings:
And this is an (incomplete) parts list:
999 141 028 02 x 3 = screws to mount metal bracket to seat frame
996 521 674 00 (LHD) or 996 521 673 00 (RHD) x 1 = metal mounting bracket
900 067 137 02 x 2 screws to mount extinguisher cradle to metal bracket
900 151 027 02 x 2 washers for the above screws
996 521 607 00 x 1 Plastic red cradle to hold extinguisher
What is missing from this list is identified as part 17 on the diagram - you'll need two of these, they're little metal clips that are threaded, and are needed in order to attach the cradle to the bracket.
Always fun getting your order in a thousand small plastic bags:
And here's the expensive part:
Which, when you receive it, you'll note is a Mercedes-Benz part:
This is important, and will help later!
Here's the bracket that fits to the seat, with the Torx headed bolts in place:
They're T25 for reference:
The cradle is retained by both a hook and some bolts:
Said bolts should locate/fasten into 2xpart 17 from the exploded diagram, which currently I don't have:
Dammit
PostPosted: Sat Oct 28, 2017 3:54 pm    Post subject: Reply with quote
Now that's not the annoyance which it could have been, as we now encounter a somewhat larger problem:
It turns out that the 996 was specified with a 1.3 litre fire extinguisher - and that this unit is now NLA.
Here's an example (that I've ordered, as I may have a disorder):
Ignore the sites that tell you that the 1kg unit will work, as they are fibbing (although they have their part 17's, damn them):
Dammit
PostPosted: Sat Oct 28, 2017 4:00 pm    Post subject: Reply with quote
So what to do? Well, if you recall, we found that the cradle is a Mere part, so lets see if there's something from the Merc catalogue that fits the 1kg unit (Porsche changed the type of bracket/cradle interface when they moved to the 1kg units in the 997, so they won't work for us).
Possibly, is the answer:
My understanding is that this continues to use the hook+two bolts fixing method, so should mount onto the bracket that fits the 996 seats.
So I've ordered this:
Purely for the cradle - I have a brand new 1kg extinguisher.
I'll report back when it arrives and I find out whether my studying of Google images was accurate (and it works!) or wasn't (and it doesn't).
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Sat Oct 28, 2017 5:38 pm    Post subject: Reply with quote
excellent Thumb
FOLLOW 911UK ON TWITTER
Marky911
PostPosted: Sat Oct 28, 2017 11:02 pm    Post subject: Reply with quote
Yes brilliant.
Pure, obsessive Porsche nerdyness, and I mean that in the nicest possible way. Grin Exactly what I subscribe too. Thumb
I was all set to follow your lead on these but will have to wait and see if it will mount to those bucket seats I've bought.
Great info for people.
crash7
PostPosted: Sun Oct 29, 2017 10:35 am    Post subject: Reply with quote
Marky911 wrote:
Yes brilliant.
Will only mount to bucket seats if your using the original Porsche runners.
Failing that you will need an aftermarket solution
Marky911
PostPosted: Sun Oct 29, 2017 12:39 pm    Post subject: Reply with quote
Yep thanks Crash, that's what I'd read. I have both options there so just need to see what effect they have on seating height when I get around to fitting them.
A fire extinguisher is a sensible mod for me personally as I had a car go up once. Luckily I had one then and got away with no major damage.
Dammit
PostPosted: Sat Nov 11, 2017 1:15 pm    Post subject: Reply with quote
I did mention that I might have a disorder - you chaps should bear that in mind before reading the rest of this post.
So! I have been (somewhat) busy using a variety of classified add sites - first time I've bought something from Russia, but it went very smoothly.
I now have four (4) cradles, two specific to the 1.3 litre extinguisher which is NLA (the new one came with said NLA extinguisher) and two that are specific to the still-available 1 litre units.
Here are the two that work with fire extinguishers that you can buy today (for very little):
They're both from Mercedes - based on what Google translate made of the adverts.
These cradles came with fittings, and you can see that Mercedes specified a screw with a conical head which matches the profile of both the washer and the cradle:
So I'd ignore the Porsche part list I put in the first post - I'll create a more accurate list when I have confirmation on part numbers and so forth.
This is the metal bracket which fits to a Mercedes seat - you can see that the tab which retains the cradle is identical to the Porsche bracket, as is the location of the tabs - and the metal clips which fit over the tabs and provide a thread for the screws to locate in.
(Please forgive the rather blurry photographs!)
What does this mean? It means that the all the cradles will fit onto the Porsche bracket, as it's a standard fitting shared with Mercedes - and likely others.
Dammit
PostPosted: Sat Nov 11, 2017 1:44 pm    Post subject: Reply with quote
Here's a 1 litre Gloria extinguisher in one of the newer cradles:
Here you can see the mounting method of the cradle to the bracket - note the retaining tab, the two screws - exactly the same as the Porsche parts:
Dammit
PostPosted: Sat Nov 11, 2017 1:55 pm    Post subject: Reply with quote
Here's the '90's extinguisher that fits in the OEM 996.1 cradle:
As you can see, it's taller, wider than the 1kg unit that replaced it, and now fits perfectly in the cradle:
So I have some options here - I can use the older (OEM correct) one, or the newer, but still OEM (just not wholly Porsche OEM) version with the 1kg units.
The 1.3kg extinguisher shows as full on the little gauge - but it's old, so I don't trust it.
What that means is I'll use the 1kg units that are in date, I suspect - but the 1.3kg unit can go on the shelf in the garage.
Next job is to fit the whole assembly to a seat - something that's likely to happen in a couple of weeks as I'm travelling for a most of the rest of November.
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Sat Nov 11, 2017 6:01 pm    Post subject: Reply with quote
Why am I loving this post so much?
In over 45 years of motoring I have never needed a fire extinguisher in anything but a racecar.
But now, strangely, I am strongly drawn to totally needing one eh!
160dmb
PostPosted: Sun Nov 12, 2017 7:30 am    Post subject: Reply with quote
Nice work fella - now how about you do a 997 version!
I think the whole post is actually a subliminal advert for Swiss Tools 🤣🤣🤣.
Dammit
PostPosted: Sun Nov 12, 2017 9:58 am    Post subject: Reply with quote
Hah! That isn't intentional- but they do make very nice tools.
I suspect you can probably order the 997 parts straight from Porsche, which rather takes away a degree of the enjoyment.
Kryton
PostPosted: Sun Nov 12, 2017 2:47 pm    Post subject: Reply with quote
Think mine would be an easier fit for any Porsche, supplied with my .2 GT3 it's 2kg and could be bought from OPC's
2019 Gen 2 Macan
Dammit
PostPosted: Sat Jun 02, 2018 2:27 pm    Post subject: Reply with quote
Cradle is in, but I’ve misplaced the 1litre Gloria unit frustratingly.
Dammit
PostPosted: Sun Jun 03, 2018 6:35 pm    Post subject: Reply with quote
Found it!
911munKy
PostPosted: Sun Jun 03, 2018 11:39 pm    Post subject: Reply with quote
Phoooaarrrr,
2000 C2 996
Marky911
PostPosted: Mon Jun 04, 2018 7:01 am    Post subject: Reply with quote
Very neat! Cool
I aim to blatantly copy you once I know I'm definitely using stock seat rails with my buckets. Wink
Will you be rounding up the thread with the part numbers for all components required to fit the 1kg unit?
Excellent thread.
This type of extinguisher is far less intrusive to passenger footwell space than the huge GT3 item.
Dammit
PostPosted: Mon Jun 04, 2018 9:43 am    Post subject: Reply with quote
Copy away - a large part of the enjoyment for me is putting the information out there so others can do so.
I'll try to make a full list of parts and part numbers, I'll need to some research for some of the parts first.
It's a small thing, but seeing it all fitting together "just so/OEM" is satisfying.
911munKy
PostPosted: Mon Jun 04, 2018 10:24 am    Post subject: Reply with quote
Would you mind adding costs as well if you have them as well please?
Much appreciated.
2000 C2 996
Goto page 1, 2, 3  Next
Page 1 of 3
