997 : 2004- 69
Boxster : 1997- 13
Cayman : 2005- 14
adrian993
PostPosted: Fri Nov 11, 2016 10:30 am    Post subject: seeking some genuine cup wheels... Reply with quote
I've purchased Rays car and currently giving it a bit of TLC..
on my list is a set of genuine cup rims,
looking for x7.5 fronts and x9 rears
if anyone knows of a set I would be very grateful.
Thanks everyone!
cableguy
PostPosted: Fri Nov 11, 2016 10:47 am    Post subject: Reply with quote
Cup I's are getting difficult to come by and commanding strong money now. Cup II's seem to work and look well and a fair chunk cheaper.
I have a set of Cup II's but if it's Cup I's you're after then good luck with your search. Wink
C.
Pork!
Mondrian
PostPosted: Fri Nov 11, 2016 11:37 am    Post subject: Reply with quote
7.5 is rather rare so best to aim for 7. I think I saw a set for sale in mainland Europe, pm your email if interested.
adrian993
PostPosted: Fri Nov 11, 2016 2:46 pm    Post subject: Reply with quote
The 7.5s originate from the 928 i think... Any 928 forums maybe they are worth a try?
Mondrian
PostPosted: Fri Nov 11, 2016 2:56 pm    Post subject: Reply with quote
& 968
adrian993
PostPosted: Fri Nov 11, 2016 4:43 pm    Post subject: Reply with quote
Hmm where should I start looking Dont know
ras62
PostPosted: Sat Nov 12, 2016 9:30 am    Post subject: Reply with quote
Well done buying Rays car Adrian, its a good car and very sensible money. Why the need for the wheel change? The MM wheels it has are virtually identical, in fact I prefer them!
917k
1990 Porsche 964 Carrera 4
PostPosted: Sat Nov 12, 2016 9:49 am    Post subject: Reply with quote
Virtually identical, but they weigh an absolute ton
We come unseen
ras62
PostPosted: Sat Nov 12, 2016 10:11 am    Post subject: Reply with quote
A common misconception, size for size they are almost identical Hand
917k
PostPosted: Sat Nov 12, 2016 11:41 am    Post subject: Reply with quote
No misconceptions at all, merely facts
MM 48kg a set
Factory 42.2kg a set
As a comparison the 996 10 spokes on my car weigh 35.4kg a set (lighter than magnesium cup 1s even)
We come unseen
ras62
PostPosted: Sat Nov 12, 2016 12:46 pm    Post subject: Reply with quote
You are using the weights for a 7 inch original wheel not a 7.5 as the MM. In 7.5 fitment both weigh 10.5kg. The MM 9 inch rears are 1kg heavier due to the offset which spaces the wheel out by 3mm filling the arch better.
adrian993
PostPosted: Sat Nov 12, 2016 3:50 pm    Post subject: Reply with quote
Just have a penchant for oem products that's all, the wheels are in great condition and will be needing a new home soon so if anyone wants a good set of rims, mint condition, let me know!
Mondrian
PostPosted: Sat Nov 12, 2016 4:25 pm    Post subject: Reply with quote
For the record there is a good list on below link for size/weight/offset comparison.
http://www.944racing.de/felgengewichte.php
Mondrian
PostPosted: Sat Nov 12, 2016 4:59 pm    Post subject: Reply with quote
These are a bit on the expensive side so might want to wait & see if something more local pops out!
http://www.wichers-porsche.com/onderdeel/porsche-cup-2x9jx17-et-55-nieuw-en-orgineel-pw-591/
-Teme-
PostPosted: Sat Nov 12, 2016 5:52 pm    Post subject: Reply with quote
You can still buy the genuine Cup I wheels new if you want to: http://www.rosepassion.com/en/cat/porsche-964-1993-964-carrera-2-coupe-automatic-gearbox/M222/rims-and-track-wideners-and-accessories/rim/B545/wheel-rim-nut-antitheft-kit-inflator/I2343/alloy-wheel/Z65346/P47818
adrian993
PostPosted: Sat Nov 12, 2016 6:09 pm    Post subject: Reply with quote
doesn't look like the 7.5J is available and seems in the wrong offset
i believe for 964 they need 7.5J ET65 and 9J ET 55
Mondrian
PostPosted: Sat Nov 12, 2016 6:29 pm    Post subject: Reply with quote
7 & 9 offset on originals is 55, Rose passion list 7.5 as 55 too but not sure if it's correct. I don't think 65 would be a problem though but check with those in the know.
adrian993
PostPosted: Sat Nov 12, 2016 7:13 pm    Post subject: Reply with quote
learning something new everyday
for the 928 gts it's 7.5 et65
For 964rs it's 7.5 et55
For regular C2 it's 7.0 et55
-Teme-
PostPosted: Sat Nov 12, 2016 7:14 pm    Post subject: Reply with quote
The stock wheels for the 964 were 6x16 ET52 up front and 8x16 ET52 at the rear. The 17" wheels were an option at 7x17 ET55 up front and 8x17 ET52 at the rear.
I run a wider 9x17 ET55 rear wheel, which I believe was the 964 Turbo rear wheel size. But it fits without problems on a narrow body 964 at the rear.
Each to their own, but I would not put replica wheels on a Porsche. But that's just me.
ras62
PostPosted: Sat Nov 12, 2016 10:19 pm    Post subject: Reply with quote
The original wheels were made in Italy by MM and Speedline iirc so describing the MM as a rep is a mute point. The MM offsets 52/47 are better on the 964 than the original wheel's 55mm offsets as it means front and rear wheels sit further outboard by 3mm/8mm respectively. The 7.5 inch front also allows the fitment of a 225 tyre which many prefer as it adds front end grip.
The cup race car wheels also fit, these are 8 front with 52 offset and 9.5 rear with 65 offset that requires a spacer to work.
