997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
F9ank
2014 Porsche 991 GT3
PostPosted: Sat Oct 29, 2016 5:03 pm    Post subject: Which oil? Reply with quote
Hi All,
Have recently purchased a 1986 Carrera 3.2 Supersport with the 915 gearbox. Done a quick search on the forum, but haven't seen anything indicating which oil I should use?
A search of the web so far suggests 5W-40 and fully synthetic is fine?
Thanks!
911 Carrera 3.2 Supersport (Guards Red)
991 GT3 (White)
997.2 Carrera 2 S (White) - sold, and bought it back again 5 years later!
991 GTS (Carmine Red) - sold
Riviera Bob
PostPosted: Sat Oct 29, 2016 11:23 pm    Post subject: Reply with quote
Well with the clocks changing tonight you can spend your extra hour searching a much discussed subject online and sadly you'll probably come away with information overload. It's basically split into three groups....cheapo original mineral 'tractor' stuff, super expensive high tech nano type synthetic, or 10w40 semi. I've been using the latter (Mobil Super 2000 API SL).
Obviously someone from the other two groups will say my choice is wrong and I should go into a corner and hang my head in shame.
Palladium
PostPosted: Sun Oct 30, 2016 8:14 am    Post subject: Reply with quote
you should use mobil semi synthetic 10w 40.
Palladium
PostPosted: Sun Oct 30, 2016 8:18 am    Post subject: Reply with quote
needs to be a bit thicker than 5w 40
F9ank
PostPosted: Sun Oct 30, 2016 6:26 pm    Post subject: Reply with quote
Thanks guys. 10w 40 semi it is
991 GT3 (White)
