991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
Nik
PostPosted: Thu Aug 17, 2017 10:28 pm    Post subject: Reply with quote
Phil 997 wrote:
Nik, It was for just the items that made up the centre console which depending on man or auto was 6 or 7 pieces .
Guys that had other things done negotiated prices for those items directly with WC
look forward to seeing pics of your items done Thumb
Thanks Phil. Appreciated! I think I added the trims on the doors (which apparently you did too!) as well as the centre "T" section of my steering wheel trim. So an extra couple of bits.
Mine is a PDK so thinking of getting the coloured bits as per pics above.
Question
Nik
PostPosted: Thu Aug 17, 2017 10:30 pm    Post subject: Reply with quote
DerbyJim wrote:
Nik
I'm interested in getting some bits done and based in Surrey too.
Might be worth having a chat - PM?
Jim
Sent you my number sir!
PostPosted: Thu Aug 17, 2017 11:36 pm    Post subject: Reply with quote
Question
I have seen G2 PDK with the custom coloured bit up close, its a great job they did , the fine detail was done by hand .yes I got the door spears done as well, I went body coloured with my interior console etc. trying to be a bit more reserved with the gen2 as the gen1 had acid green accents everywhere in and out Grin Thumb
G2
PostPosted: Fri Aug 18, 2017 8:16 am    Post subject: Reply with quote
Cheers Phil.
Jim/Nik link to thread with picks of finished interior. http://911uk.com/viewtopic.php?t=121123&postdays=0&postorder=asc&start=0
Pm your email if you want any hi res pics. Also happy to meet as not far from you guys.
Edit: PDK gate needs separating the moving parts before you send to wicked.
I also had these bits done...bit more colour and pattern as it's a VW Cool
 Filesize:  1.59 MB
 Viewed:  3287 Time(s)
Nik
PostPosted: Fri Aug 18, 2017 8:23 am    Post subject: Reply with quote
Yours looks amazing !!! Thx for the link.
Will PM you my details.
I'm torn between carbon to match my seat backs vs something brighter to liven up the interior.
Question
wildej
PostPosted: Tue Feb 06, 2018 6:08 pm    Post subject: Reply with quote
Chaps, Is the small rear storage cubby part of the centre console or a separate part ?
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
PostPosted: Tue Feb 06, 2018 7:15 pm    Post subject: Reply with quote
it comes off in one piece but slides off once the console is out,think it slided down but it may be up lol
wildej
PostPosted: Tue Feb 06, 2018 7:40 pm    Post subject: Reply with quote
cheers Phil, wasnt sure if you could remove it on it's own as I've got a spare console but not with the rear bit on it, which is a pain in the arse as I'll have to remove it from the car now PC
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
PostPosted: Tue Feb 06, 2018 7:54 pm    Post subject: Reply with quote
check the spare is not a boxer one as not totally sure if the rear cubby can be fitted to that , a question for Demort or one of the others Thumb
KJD
PostPosted: Tue Feb 06, 2018 8:32 pm    Post subject: Reply with quote
Yea you can only remove the rear cubby once the whole consol is removed.
Arctic Silver 997 Manual Carrera 2s
wildej
PostPosted: Tue Feb 06, 2018 8:36 pm    Post subject: Reply with quote
job for this week then, is there a good guide about to remove the console ?
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
KJD
PostPosted: Tue Feb 06, 2018 9:36 pm    Post subject: Reply with quote
In this thread somewhere is a very good downloadable guide .
G2
PostPosted: Tue Feb 06, 2018 11:04 pm    Post subject: Reply with quote
J. The cubby out of your 997 will fit with the consol you got from me... I checked it before I mailed it. The rear cubby boxes are like rocking horse poop to get hold second hand.
The removal thread mentioned in the above is easy to follow. But let me know if you have issues when removing the original.
997 Gen2 Turbo S - Speed.
ex 991 C4S - Riviera.
wildej
PostPosted: Tue Feb 06, 2018 11:14 pm    Post subject: Reply with quote
Thanks mate I didn't even think about the cubby till today when I was taking it to get painted, school boy error on my part.
wack
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
G2
PostPosted: Tue Feb 06, 2018 11:17 pm    Post subject: Reply with quote
What colour are you going for?
wildej
PostPosted: Tue Feb 06, 2018 11:57 pm    Post subject: Reply with quote
White to match the car.
I assume you need to remove the PDK selector and surround to remove the console ?
All the guides seem to be for manual cars.
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
PostPosted: Wed Feb 07, 2018 12:36 am    Post subject: Reply with quote
yes you will mate Thumb
G2
PostPosted: Wed Feb 07, 2018 12:52 am    Post subject: Reply with quote
1. You need to put the car into neutral before disconnecting battery as the PDK gate wont go over the lever later on without this. Key will not release until everything is back in place and battery re connected
2. Disconnect battery
3. Rotate bottom of the PDK knob to free it, then lift the knob.
You won't be able to remove the PDK trim until the front coin tray and the leather side cheeks of the PCM consol are out and loosened.
The PDK trim lifts straight up to loosen the spring clips, you need to lift it backwards once free. The paint on the legs of this unit will crack if you spread them too wide when you refit it.
Rest of the centre consol removal is as per the clips.
wildej
PostPosted: Wed Feb 07, 2018 7:32 am    Post subject: Reply with quote
Cheers fellas Thumb Thumb
997 GTS
Previous
991.1 C4S
997.1 Turbo
997.2 C4S
997.2 Carrera
Nik
PostPosted: Wed Feb 07, 2018 8:43 am    Post subject: Reply with quote
Before I put an ad in the classifieds, anyone interested in a wicked coatings carbon-coated centre console. As new, as it was only installed a few months back.
Goto page Previous  1, 2, 3 ... 30, 31, 32, 33, 34  Next
Page 31 of 34
