jordo said:Thanks for that. How would I know if it is a 996. 1 or 996.2.
It is a face lift model.
Thanks Neil
Unless it is an early 996.2 which is pre MOST and will require a code. 2002 it could be pcm1 which is not coded to the car.T8 said:jordo said:Thanks for that. How would I know if it is a 996. 1 or 996.2.
Thanks Neil
The 'facelift model' is a 996.2 so you shouldn't need to input a radio code.
cheshire911 said:Mine is MY2002 facelift turbo. It has radio with cassette player and needed the Radio/PCM code when I replaced the battery. Luckily I had the DME download data printout that had the code.
So glove box yes, Facelift MY2002 yes, and cassette player so requires code meaning it is pre-MOST. I thought it was automatically MOST but not so.
