996 : 1997-2005 46
964 : 1989-1993 6
Boxster : 1997- 13
Cayman : 2005- 17
Cayenne : 2003- 8
912-914-924-928-944-968 3
pietrzj
PostPosted: Wed Sep 21, 2016 8:15 pm    Post subject: Instrument cluster bulb alternatives Reply with quote
If Porsche can sell a bulb smaller than my finger nail for nearly £7, there must be alternatives out there. I have broken the bulb down into its component bits and could probably solder in a glass unit if I could find a source, or maybe there are some other run of the mill cars out there that use the same bulb?
Anybody got an answer to help a Skinflint?
Citori
1996 Porsche 993 Carrera 2
PostPosted: Thu Sep 22, 2016 10:22 am    Post subject: Reply with quote
I replaced all my dial and heater control lamps with LED's.
Previously enjoyed Porsche:
1996 C2 Coupe.
1983 911 Carrera Targa Sport.
1981 911SC Sport.
1978 911SC.
1970 911E.
I have CDO. It’s like OCD, but the letters are in alphabetical order, LIKE THEY ARE SUPPOSED TO BE..
Aircooled or nothin....
madge
PostPosted: Thu Sep 22, 2016 3:33 pm    Post subject: Reply with quote
Those LED's look superb Citori. Is it an easy job?
Pietrzj. Is the pictured bulb the one to which you refer? If so, I bought 10 Osram 2721 from Amazon for a total of £6.61.
Current: 993 Carrera Coupé, Manual, Varioram
Previous: 987 Cayman S
 Filesize:  14.56 KB
 Viewed:  6519 Time(s)
Citori
PostPosted: Fri Sep 23, 2016 7:39 am    Post subject: Reply with quote
Very easy once you get the dials out of the dash. The dials just push out from behind. First one can be a bit of a bee-itch but others are then easy, The only one that will give you trouble is the Tach. It can be done with the steering wheel in place, but it's a bit of a squeeze, especially if you have an OBD tach.
LED's were £20 for a full set inc post. Enough to do all the dials, heater controls and a couple of spares.
1996 C2 Coupe.
1981 911SC Sport.
1978 911SC.
1970 911E.
ChrisT70
PostPosted: Fri Sep 23, 2016 7:57 am    Post subject: Reply with quote
How easy to get dials out of dash please? I have a lamp gone on the tacho
Afraid of dipping a toe- beware Sharks
Ex 993S now sold
Citori
PostPosted: Fri Sep 23, 2016 8:11 am    Post subject: Reply with quote
Tacho is the hardest to get out IF you have an OBD as i understand the dial is much deeper.
This is how I done it:
first buy some nylon bicycle tyre levers from eBay. mine cost £2 for 3 and they are just about the most useful thing I have spent £2 on.
Gently lever out the clock by working your way around it with the tyre lever. Don't lever it against the dash or you may mark it, but sort of "hook" the tyre lever under the edge of the dial and try and lift it. I also squirted a tiny bit GT85 under there to help. Once you get the clock out you can then push out the speedo from behind and then the tacho.
If they have been in there a while they may not just pop out so be patient and take your time.
I use GT85 because I think it doesn't stink like WD40.
1996 C2 Coupe.
1981 911SC Sport.
1978 911SC.
1970 911E.
madge
PostPosted: Fri Sep 23, 2016 8:41 am    Post subject: Reply with quote
Thanks Citori
This sounds like a job that I need to do. Do you recall which type of bulb we should look for?
Citori
PostPosted: Fri Sep 23, 2016 8:49 am    Post subject: Reply with quote
http://911uk.com/viewtopic.php?p=884338#884338
1996 C2 Coupe.
1981 911SC Sport.
1978 911SC.
1970 911E.
Markabanksy
PostPosted: Fri Sep 23, 2016 9:34 am    Post subject: Reply with quote
I had a bulb out in the Tach. Removal of the steering wheel is not essential but does make the job easier. The bigger Tach with the OBC is a tight squeeze past the wheel one the column surround. I have done this with and without the wheel being removed and found the wheel off routine less stressful.
Interestingly if a warning light bulb goes, there are what are effectively spares in the clock. There are a number of warning lights in the clock that, depending on which car you have, are not being used. For example there is a cabriolet roof warning light.
1996 Arena Red Tip
Pretzel
PostPosted: Fri Sep 23, 2016 11:39 am    Post subject: Reply with quote
Hopefully Citori still has some of the LED bulbs available, if not I have a spare set.
993 C2 Aventura
Nik
PostPosted: Fri Sep 23, 2016 6:04 pm    Post subject: Reply with quote
Citori, yours look like a "cool white" in the picture, whereas OE lighting looks a little warmer. Are there different options available ?
RobIpswichUK
1994 Porsche 993 Carrera 2
PostPosted: Sat Sep 24, 2016 7:33 am    Post subject: Reply with quote
There is a whole post about this on Rennlist
http://rennlist.com/forums/993-forum/475720-finally-a-plug-n-play-led-solution-for-964-993-gauges.html
Quite a good read with regards to people trying different types of bulbs and the results achieved. I've seen Steves for real at night and it does look great but like mine which I did same bulbs as Steves you do get minor dull patches as led bulbs are far more directional. The RL guys seem to have found some more bulbs that may resolve that minor foible.
If one of my bulbs go I might go the RL route but happy at the moment
Rob
'94 C2 Iris Blue (+ White Stripes!)
Cup 2's, Big Ovals, FSD's/Eibach, OMP Strut Brace, 200 Cell Powerspeed Cats, 1.75" Hollamby Exhaust bypass, Carnewal FPB.
Mercedes SL (R230 lowered + wheels)
Range Rover Sport (L320 chipped)
Mercedes E Class (W211 chipped)
TT Roadster (standard - wife’s daily!)
pietrzj
PostPosted: Mon Sep 26, 2016 7:56 am    Post subject: Reply with quote
Madge,
the bulbs do look like the one in you photo but the wire "legs" would have to be able to be bent out and up as they need to be soldered to little shaped tin pads that pinch the PCB when they are twisted in the clock.
I might try this on an old one I have in the garage.
Many thanks.
Nik
PostPosted: Mon Sep 26, 2016 11:56 am    Post subject: Reply with quote
have ordered the nylon tyre things, now just need to order some bulbs.
Anyone else on the verge of going down this path ? Happy to combine the order or compare notes if helpful!
pietrzj
PostPosted: Mon Sep 26, 2016 4:11 pm    Post subject: Reply with quote
Anybody done the bergvillfx centre console LED upgrade?
Nik
PostPosted: Mon Sep 26, 2016 4:14 pm    Post subject: Reply with quote
On my list also.... I have the parts but haven't been brace enough to attempt the install !
BenC
PostPosted: Mon Sep 26, 2016 4:19 pm    Post subject: Reply with quote
I have - superb mod and easy enough to do.
Well worth it I think.
1997 Ocean Blue metallic manual Targa
PostPosted: Mon Sep 26, 2016 4:23 pm    Post subject: Reply with quote
I think the issue is the wattage of the 'original' Porsche bulb and hence the expense Surprised. Cant remember if they are lower (0.6W) or higher? You can use the other wattage bulbs without issue. I used the latter when I sorted the knackered ones in the centre console backlighting.
I bougtht a packet of 10 - Here
BenC
PostPosted: Mon Sep 26, 2016 4:26 pm    Post subject: Reply with quote
Half way down this thread of my targa
http://911uk.com/viewtopic.php?t=99527&postdays=0&postorder=asc&start=20
motivator
PostPosted: Wed May 17, 2017 6:37 pm    Post subject: Reply with quote
Citori,
I know it was a long time ago, but do you have any the bulbs left, or can you tell me where to buy them?
I have ordered the Rennlist ones for the back lighting, but think i should do the warning lights as well, need to get some for that.
thanks
1997 993 Cab
Ex 1977 Minerva Blue 3.0 SC coupe
