997 : 2004- 89
996 : 1997-2005 41
993 : 1993-1998 6
Boxster : 1997- 16
Macan : 2014- 0
PHSSLL
PostPosted: Wed Sep 14, 2016 5:20 pm    Post subject: Porsche Trickle Charger Q. Reply with quote
Hi all can someone help me i have purchased a porsche Charge-o-mat trickle charger and it connects via the cigarette lighter socket and keeps the battery at optimum charge levels
My question is can i use the power socket/cigarette socket in the boot/trunck or does it have to be the cigerette lighter socket in the front ???
Thank you in advance
GT4
Nordschleife
Nordschleife
PostPosted: Wed Sep 14, 2016 7:22 pm    Post subject: Reply with quote
You can use any live socket.
So what you need to check is if the secondary sockets can power stuff after the key is removed (to be doubly sure, check after the car has been turned off for 30 mins - some newer DMEs/VW DMEs have a timer that allows a short period of use then shuts off)
PostPosted: Wed Sep 14, 2016 7:23 pm    Post subject: Reply with quote
Any cigar lighter that is permanently powered will do .. put a cigar lighter in it with no keys in the ignition .. if it works then its a permanent and will be ok.
Or check with a meter .. 12v no keys in ignition and all good .
PHSSLL
PostPosted: Fri Jun 30, 2017 1:48 pm    Post subject: Reply with quote
