GT2 rear anti roll bar fitted to 997.1 GT3
Stuart Mackay
29 Apr 2013
323
Just fitted the GT2 thicker, and stiffer rear bar, took about ten minutes, used original rubber bushes, although GT2 bar is 2mm thicker than GT3, used middle hole as initial setting, track day planned at snett tomorrow, so will report back on results. :)
what geo are you running ?
All went very well, car was planted, cornered flatter, very neutral and Coram was able to be taken a few MPH faster, so pleased with that mod.
Just fyi, the bushes are actually a service item on gen 2 997, seems a bit odd but they are pretty lightweight items..
What was the p/n on the GT2 rear ARB?
part number is 997 333 701 96
Pic below
Excellent - cheers :thumbs:
Sweet! Looking fwd to doing this mod one day soon. You get more options with it, dont you?
Couple of pics from Snett in September
going through Bombhole, which loads the rear up
Nice pics! How did you find the new ARB then? I also have it, on the middle setting too with CoG geo settings, car is fairly 'neutral'. The softest setting on the GT2 bar is more firm than the hardest setting on the OEM bar from memory. Good cheap and easy mod to go, well worth doing
Thanks Roro, and I think you can see that roll is minimal and it certainly does turn in well, (car has been corner weighted and I am running a smidge of toe out at the front). Both ends of the car seem have similar levels of grip with no evidence of the front trying to "wash out". But I havent been brave enough to test the limits of grip to see which end lets go first. I need to test it more on a steady state corner, such as Coram, which allows the car to start drifting, it is appears to be a bit faster around there now compared to before.
On the road, the car is sublime. :thumbs:
124,562
1,441,538
48,977
GT3161
