997 : 2004- 74
Boxster : 1997- 14
Pork Chops
PostPosted: Tue Sep 06, 2016 4:52 am    Post subject: UK Delivered 1978 911SC Speedo and Tacho Reply with quote
G'day guys, I've got one of your cars over here is Australia. I'm refrurbing the gauges but considering the sketchy history of the car I'm not sure what I've got is what I should have.
It's the speedo I'm most concerned about as it's got an aftermarket kmh face on it and I'm not sure what's under it. It's got 280kmh as the top speed which is about 180mph. Part number on the gauge is either 91184153400 OR 91164153400[b][u] but I can't be sure and the stick on dial slightly obscures the 6/8. If you search these part numbers they do show a 180mph speedo, but would an SC have that from the factory? Surely 150mph would be more appropriate. Also if I look at the UK PET those part numbers are not there
Ideally I'd like someone with a totally original UK car to check their car and take an image of the speedo and confirm the part number.
Same with the tacho if possible.
My car is below after a fresh respray back to the original Copper Brown Metallic. Hope you like.
Cheers.
 Filesize:  185.98 KB
 Viewed:  5063 Time(s)
 Filesize:  516.13 KB
phelix
PostPosted: Tue Sep 06, 2016 3:12 pm    Post subject: Reply with quote
Nice period colour - looks v smart.
If you don't get any joy here you might try your luck on impactbumpers.com
Pork Chops
PostPosted: Tue Sep 06, 2016 9:49 pm    Post subject: Reply with quote
Is this it folks?
 Filesize:  52.06 KB
 Viewed:  4990 Time(s)
