997 : 2004- 68
996 : 1997-2005 34
Cayenne : 2003- 7
Macan : 2014- 6
Palladium
PostPosted: Wed Aug 31, 2016 7:22 am    Post subject: revs staying up between gear changes Reply with quote
Anyone know whats causing it, and how to solve it?
thanks.
Quickstop
PostPosted: Thu Sep 08, 2016 7:42 pm    Post subject: Reply with quote
It could be the fuel mix is too high.
There is a recessed knob ( triangular from memory) on the side of the ecu under the passenger seat. Try unscrewing the ecu from the floor, unplugging the ecu from its cable and retard the fuel mix by turning the knob a couple of turns then replace the ECU. ( sorry cant remember if its clockwise or anti) Trial and error.
Remember and disconnect the battery before taking out the ECU
Regards
Quickstop
PostPosted: Thu Sep 08, 2016 7:53 pm    Post subject: Reply with quote
Its not something stupid like a sticking throttle cable / pedal is it ?
Get someone to operate the throttle while you look at it and see if its fully returning perhaps .
kas750
Shanghai
2006 Porsche 911
PostPosted: Thu Sep 08, 2016 8:29 pm    Post subject: Reply with quote
I would check for an air leak before making any adjustment.
Palladium
PostPosted: Thu Sep 08, 2016 11:12 pm    Post subject: Reply with quote
thanks for the replies, I tried lubricating the throttle and thought I had cracked it, but when the engine is up to temperature it starts again, going to go down the air leak road. Thumb
grbspeedster
PostPosted: Fri Sep 09, 2016 5:57 am    Post subject: Reply with quote
Get onto impactbumpers.com it's a superb site for these cars , do a search it will have been covered before
Good luck
Geoff
996 X50 turbo cab
