996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Palladium
PostPosted: Sun Aug 28, 2016 8:12 pm    Post subject: drivers side wing mirror Reply with quote
when you fold them back when parking, I noticed that the mirror flopped back much easier than the passenger side, well today, its completely floppy now, you can lift it out of its housing.
Can anyone advise, looks like its worn out to me.
flag type electric mirrors.
PostPosted: Sat Sep 10, 2016 6:10 pm    Post subject: Reply with quote
Assumeing the internals are the same as a 993 then the spring or the locking lugs might have failed .. only way to find out really is remove and strip ...
No. 3 and 10 here is what im thinking .
http://www.deroure.com/diagrams.asp?TBL=2451&MAK=3&MDL=24&SMA=0&SMO=0&ST=&SC=0
Soundbud
PostPosted: Sat Dec 10, 2016 1:58 pm    Post subject: Floppy wing mirror Reply with quote
If it's anything like the SC mirrors, which I would have thought it be exactly the same. Then it's just a case of the large internal screw has come loose. You need to disconnect the mirror in order to see it, has it sits inside of the mirror.
I tightened mine up last week, it was very loose.
Undo the mirror Allen key bolt and pull the mirror off its supporting lug. Now the mirror is completely removed except the wires holding it to the door. You should be able to use thin nose pliers to turn the large screw bolt that is on the bottom of the mirror. This bolt has two slots in it, one either side for tightening looosening.
The wires run through the inside of the bolt. Very easy fix, only took about 20 mins.
Palladium
PostPosted: Sat Dec 10, 2016 2:22 pm    Post subject: Reply with quote
thanks, i had everything done back in September, new motors and lenses, wiring was all up the creek and the door had to be taken off.
