Help - rear top mounts
MarkGolf
Sao Paulo
13 Nov 2012
930
I'm in the middle of fitting my rear H&R coilovers and I've just removed the drivers rear and swapped the top mount over to find it doesn't leave enough of the threaded top part of the piston to poke through in order to get the top nut on it....
What's going on?? Disappointed as something clearly isn't right.
Not my area of expertise but this is all i have ..
I assume you mean with the coil compressed with spring compressors the actual shaft thread that goes through the top mounts is not long enough ..
I think there are 2 types of rear top mount so perhaps you have the wrong shocks for the mounts or visa versa .
There are two different types of rear shocks for the 964 for the early and later cars you need to check you have the right coilovers
Mark
Sorry to be the bearer of bad news however I`m pretty sure the top mounts are not interchangeable if you have the wrong coilover kit you need them changed for the right ones
Gaz
Hi Mark,
I had to have Redline Racing manufacture adapters for my rear (Rennline) top mounts so you're not alone. :bye:
Cheers,
Paul
Thanks guys, I'm reluctant to remove the kit and sell on to then go and buy another kit suited to the early 964, what a pain. So it looks like I'm going to get a hold of some late top mounts along with those US adapters with £50 delivery charge, doh!
Thanks for the help.
124,604
1,442,012
49,037
PC Saros
