964 Door Pocket Repair
Georgestamos
11 Jun 2016
14
Hello all,
My door pockets are suffering from a common problem whereby they have become 'unfixed' from the plastic frame.
It bothers me as it looks untidy, the shadow gap junction between pocket and door pull looks excessive and uneven, and I can't rest my arm on it when my back is playing up!
I've sourced a replacement original bracket but at £75 a pair is a bit steep and requires stripping out and making good.
I have read somewhere that 3d printed brackets have been produced which offer a quick fix solution which braces up the fixing and closes the gap but I'm not sure where to source them, although I've attached an image from an old Reenlist thread.
Can anyone help?
Well as a follow up, I've tracked down a guy from the states who goes by the name Neffets over on Rennlist website- he 3D prints resin plates which are designed to perfectly slot in front of the existing weak plastic bracket and blend into place, I think he charges $10 for the pair (as per my image above).
If anyone's interested I can get hold of his direct email address & organise for him to make his product available to this forum?
He also makes them for older & newer models.
He is actually Norwegian, so a bit closer to home :)
I used his plate to fix the door pocket on my -93 964. Perfect fit. Highly recommended. The price was a bit higher if I recall, but still very reasonable.
Ah his name is Steffen, I suppose the name was a giveaway about his origins!
Thanks. Waiting for mine in the post.
124,562
1,441,534
48,977
GT3161
