wilpert said:Given that the engine size is same as 3.4s
What has been done to give more power, is it just the mapping of the ecu?
pix882 said:wilpert said:Given that the engine size is same as 3.4s
Yep I expect so, same engine after all, I expect they have tweaked a few other bits to make it feel more responsive too.
Log in, add 15, job done
Phil 997 said:pix882 said:wilpert said:Given that the engine size is same as 3.4s
You may also find a bigger throttle body and plenum as that seems to be one of Porsches favourite tricks to reduce power so they don't compete with the more expensive versions. I am sure that it's as easy to retro fit on the 981 as it is on the 997 and a remap then you are there. :thumb: :grin:
isysman said:Has a different exhaust system as well.
wilpert said:isysman said:Has a different exhaust system as well.
for more power?
wilpert said:Phil 997 said:pix882 said:wilpert said:Given that the engine size is same as 3.4s
tempting but i wouldn't do it, as Im under warranty and Im sure that would invalidate it.
Gorsh said:I have a BGTS and the exhaust is certainly different, sounds deeper and louder than a S with PSE off or on.
I've often wondered out of curiosity if there are known tuning mods that can be done on 981 models - lots about for 986 and 987. I would have thought tuning firms would have been offering power upgrades by now, or owners would have been posting information of what they've done to increase power. If the car is out of warranty I don't see it matters if the OPC knows what has been done.
wilpert said:Gorsh said:I have a BGTS and the exhaust is certainly different, sounds deeper and louder than a S with PSE off or on.
Hmmm.... well that is quite interesting, if the exhaust is louder even with pse button off, i think I would struggle. I'm sure it sounds fantastic but I already feel that the cabin noise is loud enough for me for daily driving.
Mine is not out of warranty, it's a new car but I was just curious, as the increase is not that much i wondered if it was just an ecu tweak. In fact, I'd have thought if they tweaked ecu plus other things and the exhaust, it would actually produce more than it does over the 3.4S :?:
