996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Sun Feb 03, 2019 8:39 pm    Post subject: Reply with quote
infrasilver wrote:
chriscoates81 wrote:
I'm sure the suspension setup is different I.e. the numbers so I wonder if the parts are the same or would that make the wheels not point in as much?
With the car as low as it is, -30mm, I run out of adjustment and as others have explained to me you need more on the toe arm to push out to get the desired amount on the eccentric bolt at the coffin arm. I was wondering how the factory X74 was able to be adjusted correctly if it didn't use different coffin or toe arms, I wonder what is included in an X74 kit if bought from OPC?
I believe the answer is that X74 is -30mm or less and aftermarket -30mm springs are more like -40 or 45mm so it's why you run out of toe.
Pictures of X74 cars look like about -20 or 25mm off standard, aftermarket spring equipped cars look more like gt3 heights, significantly lower than the X74 cars
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Feb 03, 2019 9:09 pm    Post subject: Reply with quote
It's an old thread when I was first trying to work out my geo issues, a lot of this has now been solved and we've come to realise that it is lower than X74 and GT3 settings and other things need to be changed/adjusted to get the geo required.
Goto page Previous  1, 2, 3
Page 3 of 3
