997 : 2004- 60
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
ScoobyDoo555
PostPosted: Tue Feb 16, 2016 4:22 pm    Post subject: Steamy windows.... and not from Valentines Day shennanigans! Reply with quote
Yes, still getting wet carpet and windows.... BUT I *think* I might have got somewhere..... however I need the 996-massive to clarify something for me.....
Now MY (VERY) limited understanding was that there are drains in the frunk - however, I only thought there were 2 - one either side.
Looking at these photos, there appears to be FOUR - 2 per side.... can anyone confirm this is the case because check out these pics:
Offside 1 - closest to the drivers wing-mirror CLEAR - water pours through
Offside 2 - drivers side, but closer to the battery
This looks completely blocked with silt/crud...... do we have a winner?
Nearside 1 - closest to the passenger wing-mirror CLEAR - water pours through
Nearside 2 - passenger side, closer to battery CLEAR - water pours through
Not done anything about it yet, as I want clarification that I'm not digging around a grommet Very Happy
Thanks in advance,
Dan thumbsup
Porsche 996 Carrera 4
Mods: "new car" magic tree. Pioneer F900bt, Alpine SPG10C2 x 4, JBL GTO 804 8" subs x 2, Shiny new rads & AC! Hartech-rebuilt engine & Sports exhaust
997 C2s discs. She stops quite nicely!
Daviebrown
PostPosted: Tue Feb 16, 2016 5:28 pm    Post subject: Reply with quote
Look under the passenger side dashboard in the footwell you will see a foam type panel, remove this and you will see the bottom of the heater unit. Just to the right of the fan unit you will see a rubber drain tube. This is a drain that allows water that goes in through the pollen filter to drain from the box. The joints on the tube were loose and allowed water to pool on my passenger floor. After being sure that the tube was clear i cable tied the joints and it remained dry. I put a fan heater in the car for a couple of hours with the window down an inch to dry the floor.
ScoobyDoo555
PostPosted: Tue Feb 16, 2016 5:40 pm    Post subject: Reply with quote
Thanks Thumb, but there's no water-build up in the passenger side..... will check it anyway Smile
Dan
ScoobyDoo555
PostPosted: Tue Feb 16, 2016 5:55 pm    Post subject: Reply with quote
question still stands though - should that one "tube" be clear of debris?
Chris_in_the_UK
Estoril
PostPosted: Tue Feb 16, 2016 6:12 pm    Post subject: Reply with quote
I am sure the drains you picture only drain into the wheel arch area, so unless the water is collecting to the extent its getting in, the leak might be elsewhere.
All 4 should be clear - I replaced a couple last year as the rubber 'rots' and sticks together with age assisting in the blockage process.
2006 Cayman S PCCB's
ScoobyDoo555
PostPosted: Tue Feb 16, 2016 6:56 pm    Post subject: Reply with quote
Interesting - the only confusion is that whenever you type into the search engine about wet carpets, (aside from the door card seals), ALL pointers lead to the 4 drain holes.
If this isn't the case, where else is there to look at on the drivers side then?
Dan Smile
Chris_in_the_UK
Estoril
PostPosted: Thu Feb 18, 2016 8:12 am    Post subject: Reply with quote
There should be drain grommets on both sides Dan - the first picture you show has it missing. They are basically a rubber grommet with a small open ended flexible 'nose' underneath which allows the water to drain away.
This what they look like - the picture in the link shows it pointing up, it actually points down underneath.
http://www.autoatlanta.co...-99970347641-srch.html
Is suspect the first picture - where all the silicone is 'clagged' around where the wires and hose go through is the culprit?.
ScoobyDoo555
PostPosted: Thu Feb 18, 2016 10:26 am    Post subject: Reply with quote
Thanks Chris - the link needed editing:
http://www.autoatlanta.com/99970347641-srch.html
FWIW, the water ingress isn't in that 1st picture - that just water I stuck extra silicone around my audio install cables that are going through the grommet into the frunk.
The water there is just where I was testing the flow through - got a bit carried away with the water jug Very Happy
out of interest, just to confirm - the grommet shown in the pic is upside down - it should fit the other way into the hole?
But yes, it looks like one is missing - will check to see if the old one's been pushed into the hole...
Would that make much difference to water ingress into the car?
DAn Smile
Chris_in_the_UK
Estoril
PostPosted: Thu Feb 18, 2016 10:30 am    Post subject: Reply with quote
Yes Dan the cone on the should point downwards through the panel.
The drains you point to do not drain into anywhere that could leak into the passenger compartment unless there is another problem hidden underneath?
It might be worth taking the front (rearmost) wheel arch liner out to see if all is in order.
I know its a pain but sometimes leaks (especially small ones) can be a pig of a job to find!.
ScoobyDoo555
PostPosted: Thu Feb 18, 2016 11:05 am    Post subject: Reply with quote
lol - ***** Very Happy
Yeh, will have a look today and see what I can find thumbsup
ScoobyDoo555
PostPosted: Thu Feb 18, 2016 4:45 pm    Post subject: Reply with quote
OK - update.
All carpets are dry with exception of point around the pedal. I've cleared out the drain - lots of crud and now free flowing*
*scoop out and then use a syringe with hot water.
I checked around the foam on the passenger's side - all fine: no issues with the pipework there.
Not had chance to get the wheel off and the liner, but that's my next plan IF this doesn't work.
I've also looked further at the drain that looks like it isn't there: it IS in place - just part of the flange has worn off. Seems to be working fine.
The only other things I can think of is the door seal (not an obvious, but they're not too expensive to replace.)
or getting the windscreen re-seated....... I noticed a bit of the scuttle trim is a little loose.
might just simply be that with the sheer amount of rain we've had, these minor issues are joining forces.....
Will report back.
Dan Smile
modz1r
PostPosted: Thu Dec 12, 2019 2:37 pm    Post subject: Reply with quote
just had the same problem and yes both drains full of crud and blocked. quick poke and a flush with a hose and now all good. Pleased I remembered this thread and thanks.
The member formerly known as CHRISU
ScoobyDoo555
PostPosted: Thu Dec 12, 2019 3:14 pm    Post subject: Reply with quote
thumbsup thumbsup thumbsup thumbsup thumbsup
