nevermind,
found the answer over at crcindustries.com
FYI (I guess the nickel stuff is the way to go) other than the castrol stuff, but nickell has higher temp resistance for those manifold bolts
quote:
I. Product Description
CRC Copper Anti-Seize and Lubricating Compound is a general purpose anti-seize lubricant that prevents seizing and galling caused by high temperatures, heavy loads, vibration and corrosion. This unique formula has a smooth texture, fine particle sizing and familiar copper color, making it an excellent choice for closely fitted parts that need extreme lubrication. Regular use of Copper Anti-Seize will increase performance and prolong equipment life.
II. Applications
Recommended to lubricate fittings, bushings, flanges, headers, nuts, screws, studs, threaded surfaces, pipes, plugs, and
manifolds to prevent seizing and galling of surfaces.
III. Features & Benefits
- Copper-Based. Safe for use on both ferrous and non-ferrous metals.
- High Temperature Resistance. Protects parts up to 1800° F.
- Electrically Conductive. Does not insulate and interrupt current flow.
- Good Choice for Use on Soft Metal Applications. Does not compromise integrity of soft metals.
- Will Not Harden. Heat aging won't affect lubricity of product.
- Facilitates Fast & Easy Disassembly. Saves time in taking apart components.
CRC
Nickel Anti-Seize and Lubricating Compound is a nickel-based formulation that is free of copper, lead, sulfides and chlorides. This premium high temperature lubricant protects metal-to-metal applications from seizing and galling caused by high temperatures, heavy loads, vibration, chemicals and corrosion. Chemically inert nickel formulation is safe for use with most chemicals that are unstable with copper. This product has extremely high temperature capabilities and excellent chemical resistance. Regular use of Nickel Anti-Seize will increase performance and prolong equipment life.
II. Applications
Recommended to lubricate metal-to-metal applications where a clean, chemically inert, copper-free formulation is necessary. Will not poison catalyst beds, reaction chambers, or special alloy fittings. May be used on fittings,
bushings, flanges, headers, nuts, screws, studs, threaded surfaces, pipes, plugs, and manifolds to prevent seizing and galling of surfaces.
- Copper-Free Formulation. For use where a clean, chemically inert and stable lubricant is required.
- Extremely High Temperature Resistance. Protects parts up to 2400° F.
- Safe For Use on Both Ferrous and Non-Ferrous Metals.
- Resistant to Mild Detergents & Alkaline Wash. Protects against rust and corrosion.
Also only £3 a tin delivered here :thumb:
http://www.ebay.co.uk/itm/390933340912?ssPageName=STRK:MEBIDX:IT&fromMakeTrack=true
