Permanent live to electric seats and windows?
deutschland-dobson
23 Apr 2008
2,460
Gents,
Should I have a permanent live to my electric seats and windows, or is this the cause of battery drain? Both work with no key in the ignition at the moment.
Mucho ta
Chris
Don't the seats and windows operate when a door is open??
I'd make sure your door switches are working correctly if that's the case. It sounds like the car thinks the door is open all the time?? :dont know:
Sounds like a faulty door switch as closed my windows wont operate but drivers door open they will without ignition. Not tried seats but I suspect they are the same :dont know:
IIRC this was an issue for some 993 owners leading to a flat battery so suspect we're in the same area. ToreB has sort of answered it http://911uk.com/viewtopic.php?t=106070&highlight=door+switch
Thanks gang :)
Better check if my door was open when testing..,
Chris
The cause of my battery drain was a faulty window relay. Because as said, the window relay should only be live with a door open or the ignition on.
Hi Gents,
Door was open at the time, so it looks to be nothing suspicious :thumb:
Chris
124,563
1,441,544
48,979
Lb456
