996 : 1997-2005 42
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
6appeal
PostPosted: Sat Jan 28, 2017 8:17 pm    Post subject: Reply with quote
8,600 miles and nearly 5 months under its belt, the daily driver is doing a grand job.
Rear tyres at 4mm inside, 5mm outside... Front tyres at 6mm. Nearly time for a 10k oil change.
Grip is excellent, had a third gear wheelspin on a slip road which was rather tasty. Car is beyond addictive, no idea what mpg is, the counter stops counting it seems at 100 hours driving.
Rim protection is epic with the tyres, dare i say it, but the alloys are very well protected and still as new.
Stone chips fairing well... ironically the only two chips I've had are bottom corner of the passenger side of the windscreen, and no film nor wax would prevent that! had them both repaired swiftly.
Finding that the phone PCM stuff is neither use nor ornament; never use it. the connect app is good though and use that quite a bit.
Left the car standing for a week for ski trip, sweet jesus the brakes were savage after a week standing, sounded & felt horrific. I had to hit a dual carriageway and do a few high speed brake manoeuvres to get them back to normal.
When the car is dirty, the muck tends to trigger the parking sensors occasionally, they are sensitive little fellas, but no issue.
Am very very happy with the spec I chose. Thank god, as that was tough to decide. Love the dark blue leather interior, and the sapphire blue looks great regardless of weather conditions, satin alloys suit it very well. Rear camera is a godsend, standard seats are oh so perfect. This is such a balanced practical car. Dare i say, there is more than enough power, anything else being top-trumps Wink I'd without question stick with the mere Carrera 2 as my next 911. Sport Chrono and PSE are epic additions. You can't fault the balance of power and efficiency. Front boot is much bigger than i expected.
A couple of questions:
1) Any idea if you can change the setting of what happens when you turn the ignition off; i would prefer that the interior lights turn on and the stereo turns off. Present setting is that they only occur when you open the car door.
2) Any idea on the mpg thing beyond 100 hours? or do you simply reset?
Things I'd change: (first world problems)
- Handbrake switch is deffo the wrong way round.
- Wing mirror glass noticeably attracts water, would either change design or have the heater on constant instead of manually.
- Link the apple car play and PCM functions so they are more synchronised and not one or the other.
- Wish there were a choice of exhaust tip arrangement for the PSE.
- Cup holder is too shallow, and only just holds my morning brew, despite shallow cup.
- Would be nice to be able to see more of the engine when you open the cover...
Present:
991.2 Carrera, SC, PDK, Toys Smile
Yamaha MT01
VW T2 Bay Window 1976
Past:
640d GC, 635d Coupe, RS6 C5, Audi TT 225 Coupe, Astra with wind up windows, Citroen ZX, Rover 213, yes behold, a Rover 213... Renault 5
thedarkknight
PostPosted: Mon Jan 30, 2017 12:17 am    Post subject: Reply with quote
Here is the answer to the over-engineered hobbit cup holders:
http://www.ultimatecupholders.com
I have mine on the passenger side and it works a treat.
991.2 C4S, Agate Grey, Bose, SC, PSE, Sport Tex
6appeal
PostPosted: Tue Jan 31, 2017 9:09 pm    Post subject: Reply with quote
sound, cheers!
Present:
Yamaha MT01
Past:
6appeal
PostPosted: Tue Jan 31, 2017 9:55 pm    Post subject: Reply with quote
First service booked for next month! 5 months old Very Happy
Present:
Yamaha MT01
Past:
6appeal
PostPosted: Sun Feb 26, 2017 8:43 pm    Post subject: Reply with quote
Had my 10k mile oil service yesterday... reassuringly uneventful. Haven't had any faults or issues at all. Car has been perfect. Was simple oil change and quick check over and that was it. All was well.
Did have one surprise, being how little the consumables are wearing...
- Rear tyres at 4 to 5mm; front tyres at 6mm.
- Brakes hardly worn at all, all disc and pad thicknesses pretty much as-new.
From my RS6 experience of a performance car, I'd be not far off tyres and brakes and a multi-thousand pound bill every 15k'ish. Makes the 911 look a bargain!! (Porsche oil change was cheaper too, as simply less oil needed).
At this tyre rate, i reckon rear's will be due a change around 16k-18k, fronts due a change around 25-30k. Wasn't expecting them to last as long as that, although i expect wear rate will increase in dryer months.
Whilst my car was in at the Porsche Garage, I had them do the paintless dent removal for the small car park rash that i had picked up on the OSR wheel arch. Incredible result, can't see a thing, back to new... £90 bargain!
Fuel consumption averaging 28mpg, could be much higher with a lighter foot, I reckon if you were more saintly, you'd be well into the 30's.
Proving to be a cheaper daily runner than i'd forecast... so far!
On to the next 10,000 miles.
Present:
Yamaha MT01
Past:
 Filesize:  55.47 KB
 Viewed:  6162 Time(s)
Curious2
PostPosted: Sun Feb 26, 2017 9:58 pm    Post subject: Reply with quote
Very interesting to read this as I have 1500 miles on my 991.2 C2 and it gives me a good indication of what to expect. Many thanks.
Current : 991.2 C2 SC PDK
Previous: 2015 Cayman 2.7.
weejimmy
PostPosted: Mon Feb 27, 2017 11:19 am    Post subject: Reply with quote
Great result with the ding. People are so thoughtless. Dont know
VAP
PostPosted: Mon Feb 27, 2017 4:10 pm    Post subject: Reply with quote
Can you tell me why you had the oil changed at 10K and not the recommended 20K?
Reason I ask is because I've also been wondering whether I should.
6appeal
PostPosted: Mon Feb 27, 2017 8:56 pm    Post subject: Reply with quote
Oil technology has developed massively in the last 10 yrs alone... however... manufacturers are under great peer pressure on service intervals in the marketplace. Theoretically fine, but new engine, in a 911, mechanical respect and sympathy I couldn't bring myself to do 20k on first oil fill as it all beds in. If I was owning short term for a year or so, then you'd do by the book, but as son of a mechanic, no way I'd do 20k miles without an oil change. Plus it's pence in the scheme of things.
Likewise, it's even worse if you're doing low mileage with a garage queen and not getting the oil up to temperature often... then going on Sunday blasts! Horrific. Minimum annual oil change, not 2 yrs etc.
Present:
Yamaha MT01
Past:
6appeal
PostPosted: Mon Feb 27, 2017 8:57 pm    Post subject: Reply with quote
Loving the red bezel. Tempted.
Present:
Yamaha MT01
Past:
 Filesize:  23.75 KB
 Viewed:  6059 Time(s)
Curious2
PostPosted: Tue Feb 28, 2017 8:09 am    Post subject: Reply with quote
Love that Red Bezel, where can I get one ?
VAP
PostPosted: Tue Feb 28, 2017 1:26 pm    Post subject: Reply with quote
Thanks.
Mine has only 5K on it, but once it starts getting close to 10K, I'll book it in.
weejimmy
PostPosted: Tue Feb 28, 2017 2:56 pm    Post subject: Reply with quote
VAP wrote:
Thanks.
As an alternate view, I waited until 17k for my first oil change with my991.1 C4S - so inline with the manufacturer/car indicator. I figure if Porsche think its fine, its fine. If mine had taken any oil I might have though differently, but it hasn't used more than 0.25l in 22k miles.
VAP
PostPosted: Tue Feb 28, 2017 6:45 pm    Post subject: Reply with quote
weejimmy wrote:
VAP wrote:
Thanks.
Thanks for letting me know your experience Thumb
I still have a good few miles to go, so I'll revisit it closer the date.
Lasrblueexige
PostPosted: Wed Mar 01, 2017 4:07 pm    Post subject: Reply with quote
Come on where did you get that from.....very, very tempted
6appeal
PostPosted: Fri Mar 03, 2017 7:02 pm    Post subject: Reply with quote
Taken a fair few emails but got to the solution of the red bezel...
Techart in Germany charge 95 euro to paint the bezel. plus tax & postage.
I tried to buy a mode switch from Porsche parts dept, to send to Germany, but the conclusion was that Porsche do not sell the part!!! the only way you can get one is to buy a whole steering wheel from Porsche, as that is the minimum they will sell you. lol how ridiculous!
So if you want it painting as the image from the techart website, you can have it removed and post it to techart and they will paint it and return it to you. if you can live without the switch for a couple of weeks, then fire on!
Present:
Yamaha MT01
Past:
6appeal
PostPosted: Sat Mar 25, 2017 8:57 pm    Post subject: Reply with quote
Measured my tyre tread depths today... ordered a new set of rears for in a few weeks time, so it will be new rears at 14,000 miles. Fronts still have loads left, so going to be well over 20k for them. Pretty good!!
Went to the Geneva Motor Show... aside from the god awful bling cars that are deemed attractive to oligarchs, there were some very nice cars to see. That 1960's Ruf!! proper car porn.
Not so good is the delicacy of the 991.2 windscreen, i've had the odd stone chip over the years of various cars, but this things screen chips at the nearest whisper of a grain of dust. Have already had couple of repairs to passenger side, but last week had a tiny chip in middle of the screen one journey and awoke the next morning to a lovely cracked screen. First time I've ever had a car thats screen has gone. Its a small crack, one for the 20k service in a few months.
Present:
Yamaha MT01
Past:
 Filesize:  46.8 KB
 Viewed:  5658 Time(s)
 Filesize:  88.43 KB
 Filesize:  109.84 KB
 Filesize:  136.79 KB
 Filesize:  135.95 KB
6appeal
PostPosted: Tue Apr 04, 2017 8:58 pm    Post subject: Reply with quote
New colour tyre options released for the 911... thumbsup
Present:
Yamaha MT01
Past:
 Filesize:  50.5 KB
 Viewed:  5569 Time(s)
 Filesize:  50.65 KB
DRZ911
PostPosted: Tue Apr 04, 2017 9:29 pm    Post subject: Reply with quote
Very Max Power indeed. Not my cup of tea I'm afraid. nooo
Wish Pirelli would put as much effort into getting a tyre that equals or surpasses the best from Michelin rather than putting lipstick on a pig - still a pig without the gaudy sidewalls. Surprised
991 Gen 2 GT3 Racing Yellow
Yamaha R1 and BMW R100RS
Jay.
PostPosted: Tue Apr 04, 2017 11:04 pm    Post subject: Reply with quote
The car is lovely! I'm very jealous, and can only dream to be in your position. Fingers crossed for more happy miles!
Goto page Previous  1, 2, 3 ... 9, 10, 11, 12  Next
Page 10 of 12
