infrasilver
Moderator
- Joined
- 4 Oct 2010
- Messages
- 9,933
I've taken delivery of this 182k miler 944S 2.5 16v, one of only 207 on the road in the UK in 2015, the other 200 left are SORN. It was advertised as "in original condition" it certainly is and does look 30 years old but unmolested original condition.
It was also advertised as rust free and when I inspected it, it was structurally sound and going through all the electrics, the only thing I found not working was the sunroof, although the motor is turning, usual suspects for this issue are the plastic gears.
The paintwork is mostly original and looking oxidised in places with a few little dings all around, in pictures it looks fine but its not as good close up and the colour is not my favorite (2 Porsche's similar colours) and I'm considering a colour change whilst the opportunity is there, (Maritime Blue, Speed yellow) not sure how this will impact any values, not that they are huge anyway.
I bought it on condition and having a top end engine rebuild in recent miles history and a cam belt change 12k miles ago the engine seems to run sweet with the gearbox also fine, main three goals being running gear, electrics and bodywork.
The interior is not as good but I am probably being too critical, the seats are in good condition, the two front seats have been reupholstered but with a slightly different centre material to the rear seats and the rears seats have a cig burn, the whole carpets set needs a good shampoo but again it's mostly in decent condition apart from one rip on the front passenger sill.
To some pictures of the work required,
Wheel refurb required, looks like they've never been done.
Rear hatch glass delaminating from the frame and seal not sealing.
Surface rust on both sills and lower front wings.
Various dash plastics cracked with some bits missing.
Seat lifter missing.
Under bonnet sound deadening crumbling onto engine bay and melting on manifold.
Power steering reservoir leaking and waterpump hose leaning on the chassis rail, assumed failed engine mount on the O/S.
Stone guards all cracked, removal and replacement after paint.
Original Ventiler airbox missing and some aftermarket cone filter fitted.
Any tips, tricks or advice appreciated.
