997 : 2004- 77
Boxster : 1997- 18
Cayman : 2005- 18
declandio
PostPosted: Sun Dec 06, 2015 9:51 am    Post subject: Brake Master Cylinder- 1987 Targa Reply with quote
Hi All
My Dad has a 1987/D-reg Targa and is about to replace the brake master cylinder. He asked me to find a workshop manual online but I can't locate one. Will probably buy one soon.
In the meantime- would this be a suitable guide for replacing the part?
http://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/52-Master_Cyl_Repl/52-Master_Cyl_Repl.htm
He has already ordered the cylinder... I'm not convinced that the cylinder is actually kaput, but there's no point trying to reason with him!
Basically- we had the front calipers refurbished and when we fitted them and bled the system, the pedal won't stay hard... when you pump it, it will harden up... but afterwards, leaving it for a few seconds results in it going very light again... so his diagnosis is the master cylinder.
phelix
PostPosted: Mon Dec 07, 2015 10:27 am    Post subject: Reply with quote
Have just rebuilt all 4 calipers and had to bleed all 4 calipers twice before getting a firm pedal. And am just about to bleed them once more just to be sure. Other than the cost of the fluid you can't really bleed the calipers too much. I would bleed the rear calipers at least once as well.
declandio
PostPosted: Mon Dec 07, 2015 2:53 pm    Post subject: Reply with quote
Thanks Phelix
That is what I also suggested! I will suggest to him again that he bleeds the rears as well as the fronts and does it a few times on each wheel.
Thanks again.
phelix
PostPosted: Mon Dec 07, 2015 3:49 pm    Post subject: Reply with quote
For manuals have a peek at http://www.adrive.com/public/aQ2Rxk/911%20Stuff%20all%20years.zip
declandio
PostPosted: Mon Dec 07, 2015 3:56 pm    Post subject: Reply with quote
Thanks!
worship Thumb
