997 : 2004- 71
996 : 1997-2005 34
Boxster : 1997- 25
NickHappy
PostPosted: Mon Apr 03, 2017 9:05 pm    Post subject: Reply with quote
alex yates wrote:
The eBay link is posted above.
Good spot cheers Alex - didn't see that, think I'll also make the most of Kwik Fits re-gas policy too, sounds like a no brainier. Thumb
997 turbo Manual.
996 turbo Manual. ex.
kas750
Reims
2006 Porsche 911
PostPosted: Mon Apr 03, 2017 9:09 pm    Post subject: Reply with quote
alex yates wrote:
Did you change your drier too? I never have done and my mechanic reckons you don't need to in the UK (with our climate). Wondered whether it's worth it or not. Mine needs regassing once I sort my leak on my front to rear pipe.
No I didn't bother and it's icy cold.
I did wonder whether it's possible to pressurise a leaky system with a bike track pump and search for leaks at the joints with a soapy solution?
kas750
Reims
2006 Porsche 911
PostPosted: Mon Apr 03, 2017 9:14 pm    Post subject: Reply with quote
NickHappy wrote:
Great thread and good work on the condensers, I'm about to change mine on the turbo and DIY. Where did you source yours from? Also, I take it you just unscrew, replace and screw back up with new o rings? Did you have to release old gas from anywhere or do any other prep.
NH
The gas had leaked from the Condenser as you can see from the dye stains in the picture so when I released the union there was no gas to leak.A very straightforward diy job.
kas750
Reims
2006 Porsche 911
PostPosted: Thu Apr 06, 2017 7:28 am    Post subject: Reply with quote
This is the tour plaque that we have designed for the upcoming Euro tour. thumbsup
PostPosted: Thu Apr 06, 2017 7:35 am    Post subject: Reply with quote
thumbsup
diverzeusy
PostPosted: Thu Apr 06, 2017 10:20 pm    Post subject: Reply with quote
Great tour plaque,
who is producing them/how do I get one?
I'm part of the 'Ghent squadron'
kas750
Reims
2006 Porsche 911
PostPosted: Fri Apr 07, 2017 7:16 am    Post subject: Reply with quote
diverzeusy wrote:
Great tour plaque,
Although our small group will hopefully be seeing you guys at Dinslaken we are not part of the official gathering from 911UK.The plaques are part of a run of 10 which have already been allocated I think. Thumb
PostPosted: Fri Apr 07, 2017 7:25 am    Post subject: Reply with quote
diverzeusy wrote:
Great tour plaque,
Participants in the 'official gathering' will be getting two of these each.
kas750
Reims
2006 Porsche 911
PostPosted: Sat Apr 08, 2017 9:06 am    Post subject: Reply with quote
The Porsche works team will be in its usual place at Dinslaken.
Pop over and say hello. thumbsup
kas750
Reims
2006 Porsche 911
PostPosted: Tue Apr 11, 2017 9:10 pm    Post subject: Reply with quote
Today I took my car to have the wheels balanced and the geometry checked at kwik fit.
On raising the car on the ramp it became obvious what the clunking sound was when I jacked the car up to fit the condensers last week..
The rear anti roll bar had snapped.
So the geometry check was stopped and a quick call to Steve strange at Douglas valley breakers secured a mint low mile roll bar and bushes for £40.
30 minutes later and I was home with my new anti roll bar and the car was in the air and the old bar was removed.
There are advisories from Cath Burrows advising of a rusty anti roll bar and worn bushes but I didn't quite realise how bad it was.
The new bar was fitted in about 20 minutes with no seized bolt trauma to deal with!
And then for a quick test drive and a big change to how the car grips and turns.Its scalpel sharp in the bends.
I now need to return to kwik fit and get them to reset the geometry.
All in it was a quick,cheap job with pleasing results..
Oh and the air con is still blowing ice cold. thumbsup
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue Apr 11, 2017 10:24 pm    Post subject: Reply with quote
That'll defo make a clonking noise for sure.
PostPosted: Tue Apr 11, 2017 10:42 pm    Post subject: Reply with quote
Porsche Clonkster. Laughing
kas750
Reims
2006 Porsche 911
PostPosted: Wed Apr 12, 2017 3:32 pm    Post subject: Reply with quote
I got a delivery today,should keep me out of mischief for a while.
PostPosted: Wed Apr 12, 2017 3:54 pm    Post subject: Reply with quote
Don't forget to waterproof it after you've done the reviver.
kas750
Reims
2006 Porsche 911
PostPosted: Wed Apr 12, 2017 4:12 pm    Post subject: Reply with quote
kas750
Reims
2006 Porsche 911
PostPosted: Thu Apr 13, 2017 5:04 pm    Post subject: Reply with quote
Today I worked on the seats using the renovo.
The first step was to scrub the seats using flash multipurpose cleaner and a brush.This is how they looked.
The next step was to apply two coats of the renovo and then stand back and marvel at the results!!!
s70rjw
PostPosted: Thu Apr 13, 2017 6:49 pm    Post subject: Reply with quote
Wow. Seats look fantastic. You've taken years off them. I love these restoration threads. Your car is a credit to you, it looks fantastic. Keep it up, best of all it's your daily Thumb
kas750
Reims
2006 Porsche 911
PostPosted: Sat Apr 15, 2017 3:29 pm    Post subject: Reply with quote
Thank you Thumb
kas750
Reims
2006 Porsche 911
PostPosted: Sat Apr 15, 2017 3:35 pm    Post subject: Reply with quote
Today I used the renovo roof renovator.
I'm very pleased with the results and it looks far better in the flesh than these pictures suggest.
Another product that I would definitely recommend. thumbsup
Before
After
maldren
PostPosted: Sun Apr 16, 2017 8:30 am    Post subject: Reply with quote
Looks like you've gone from perforated leather seats to non-perforated, did it fill those holes too?!?!?
Mike
Goto page Previous  1, 2, 3 ... , 10, 11, 12  Next
Page 11 of 12
