997 : 2004- 63
Boxster : 1997- 25
Cayman : 2005- 20
Macan : 2014- 3
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Oct 09, 2015 1:04 pm    Post subject: Grrr, suspension noise, help pls Reply with quote
So, spent a load of ££££ on new coffin arms, new top mounts and a new o/s longitudinal 'tuning fork' arm.
I'm still getting a patter/clonk/rattle from the front N/S at lower speeds over rough roads, e.g the 'dragons teeth' traffic calming raised road markings in villages, things that are raised rather than sunken.
It only happens when the car is warm after a bit of a drive.
I'm assuming the n/s 'tuning fork' is fine as I'm sure the bloke would have said when he did the other work.
Might it be the drop link? There isn't anything else left!
Would replacing either of those upset the full geo I've just had done?
Wav
PostPosted: Fri Oct 09, 2015 3:18 pm    Post subject: Reply with quote
Inner tie rods can do this once car has been warmed through?
Although I changed these due to a similar noise, but turns out it is actually my front control arms (forked). Geo should not need adjusting with tie rod or the forks, but will if changing coffin arms and/or top mounts.
I would get the n/s control arm fork changed first, makes sense to have done the pair.
Paul
03 Midnight Blue Metallic 996 Carrera 4S Manual
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Fri Oct 09, 2015 3:35 pm    Post subject: Reply with quote
Inner tie rods on the front. TRW parts are still out there and cheap.
As the steering fluid heats up the tolerance changes and you can feel it through the wheel and the floor. On mine they got worse pretty quickly.
May as well replace the track rod ends too.
Robertb
PostPosted: Fri Oct 09, 2015 3:37 pm    Post subject: Reply with quote
Thanks Paul, the coffin arms and top mounts are all new. Will try the n/s tuning fork arm- it makes sense as you say to have done both sides and its an easy job to change.
Robertb
PostPosted: Fri Oct 09, 2015 3:39 pm    Post subject: Reply with quote
Thanks- Oddly, you can't feel it through the wheel, or any harshness through the chassis. Its quite a gentle noise, but just enough to be irritating!
I can see I will end up replacing everything, and it will be the last bit.
paul987
PostPosted: Fri Oct 09, 2015 5:05 pm    Post subject: Reply with quote
Mine had these symptoms and it was the drop links. £18.00 each side, for the price I would change them anyway just to see Dont know
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
tb1880
PostPosted: Fri Oct 09, 2015 5:51 pm    Post subject: Reply with quote
I have just sorted exactly the same problem on mine. Most things had been replaced over the last couple of years except the forked arms because when checked, they always seemed fine. The noise on mine was always from the off side and as you report, you could feel it through the steering wheel. All only noticeable after a few miles of driving.
Anyway, I ordered two replacements and changed the os arm first. Hey presto the noise has gone. I will do the ns arm this weekend.
As an aside, they are ridiculously easy to fit, two bolts only and not a lot to wrong really, just take care not to break the plastic deflector when you are removing and refitting it. It seems pretty sturdy though.
Hope that helps.
glenwells
PostPosted: Fri Oct 09, 2015 6:27 pm    Post subject: Reply with quote
Would put money on it being the NS tuning fork control arm. Been through exactly what you are doing now. I went for the ESP upgraded tuning fork control arms as they were a good price and looked to be more substbatial.
When the car is on ranks etc they appear ok but when they were off the car it was obvious they were shot.
Hope you sort it
Glen
drabux
PostPosted: Fri Oct 09, 2015 10:10 pm    Post subject: Reply with quote
Sounds very much like drop links to me!
2008 Porsche 997TT
2007 Mazda 6 Derv
1977 Saab 99 with 900T engine and 9-3 Trionic engine control
Robertb
PostPosted: Sat Oct 10, 2015 1:02 pm    Post subject: Reply with quote
Thanks folks, will try drop links as they are so cheap, and the other tuning fork... less cheap sadly.
Mike!
PostPosted: Mon Oct 12, 2015 7:24 am    Post subject: Reply with quote
When you change the droplink, check the bush round the anti-roll bar where it mounts to the body/bracket (two points). Rare to break away but do perish and can split or walk out the housing. Easy/cheap to replace with some PU ones. Worth a look when your down there anyway.
Like this: http://www.ebay.co.uk/itm/Porsche-911-996-97-05-Powerflex-Front-Anti-Roll-Bar-Bushes-21-5mm-PFF57-501-21-5-/140920093930?hash=item20cf7dfcea
Robertb
PostPosted: Mon Oct 12, 2015 9:13 am    Post subject: Reply with quote
Cheers Mike, I'll have a look.
At this rate the car will have an entirely new front end! If it still rattles I will Sad
wasz
Paul Ricard
PostPosted: Mon Oct 12, 2015 9:32 am    Post subject: Reply with quote
My money is still on inner track rod joints Wink
Robertb
PostPosted: Mon Oct 12, 2015 10:38 am    Post subject: Reply with quote
Can someone help me with terminology here, or even point me toward a diagram...
inner tie rods
track rod ends
I think I'm ok with the two control arms and the drop links.
Question
C11BRA
PostPosted: Mon Oct 12, 2015 4:32 pm    Post subject: Reply with quote
Do 2wd cars have the tuning fork arms you mention? I have an annoying knock but no play in any component.
PS. 4WD front drop links are easy to fit. 2WD can be a nightmare as they double up as front strut pinch bolts. Mine were fused together. Needed drilling out both sides. 4WD uses a simple drop link.....so some good news.
2006 997.1. Project GT3C. C stands for ???
2018 Audi A4 Avant Black Edition.
Ex 996 C2 Man.
Ex Ram Cobra V8.
Ex Series 1 RS Turbo.
Robertb
PostPosted: Tue Oct 13, 2015 3:38 pm    Post subject: Reply with quote
The 2wd cars have the tuning fork arms too. Longitudinal control arm I think is their posh name.
Anyway, car booked in for minor service, and I've asked them to have a look for the noise.
The indy's first thought was droplinks, so we'll see.
wasz
Paul Ricard
PostPosted: Wed Oct 14, 2015 9:30 am    Post subject: Reply with quote
inner tie rods
track rod ends
Question
Tie rod and track rod are two names for the same thing. The "rod" that connects steering rack to hub. The inner joints (part 6) screw into the steering rack, covered by the rack boot. The outer joint (track rod end, part 8 ) connects it to the hub via a taper.
I reckon your knock is part 6. As the steering fluid heats up the tolerance of the ball joint changes and you get a knock, not present at all when cold. I had it and couldn't feel any play at all when the car was in the air. It almost drove me crazy trying to find the knock - I had replaced everything else.
Better to eliminate the simpler fixes first like roll bar joints etc (your car will probably need them soon enough anyway) but if it really only happens when the car is warmed up then I bet is these inner joints.
If you do them yourself be sure to use threadlock on them as for some reason they don't have a locking tab like every other car.....
Robertb
PostPosted: Wed Oct 14, 2015 9:42 am    Post subject: Reply with quote
Cheers, that makes sense now. I'm guessing that part could not be replaced without potentially upsetting the geo.
Typically, its all gone blissfully quiet now, perhaps because of the cooler weather. Needless to say it will make diagnosing the fault more tricky...
wasz
Paul Ricard
PostPosted: Wed Oct 14, 2015 11:31 am    Post subject: Reply with quote
Mine got steadily worse, until after a track day (and associated heat) I though my car was going to fall apart it was knocking so much.
The next day it was totally fine first thing until warmed up!
Robertb
PostPosted: Wed Oct 26, 2016 12:45 pm    Post subject: Reply with quote
OK, so got to the bottom of the noise, unexpectedly.
The winner is- a new front n/s coffin arm, to replace the new coffin arm I fitted only 4k miles ago, which must have been faulty. The rubber bushing had completely split and it failed an MOT on it.Mad
It might also have been the undertray rattling as he tightened that up, but he said it was unlikely to have been that but you never know.
Anyway its sorted, happy days.
