996 : 1997-2005 40
Boxster : 1997- 13
Cayman : 2005- 10
Macan : 2014- 0
Motoring Editor
Motoring Editor
PostPosted: Sun Sep 06, 2015 10:55 pm    Post subject: New 2016 Gen 2 991 Carrera revealed with all Turbo line up! Reply with quote
And so the next chapter of Porsche 911-kind begins. Stuttgart has confirmed the worst-kept secret in motoring: the second-generation 991 will sprout a pair of turbochargers on lowly Carreras, boosting power and torque significantly and lowering emissions and fuel consumption.
Open Youtube Page
This is downsizing in action. The new 2016 model year 991.2 will shrink the flat six to 3.0 litres in capacity, but swell outputs through forced induction. Key figures are:
# Porsche 911 Carrera 365bhp, 332lb ft from 1700-5000rpm, from £76,412
# Porsche 911 Carrera S 414bhp, 369lb ft from 1700-5000rpm, from £85,857
In both instances, that’s 20 horses more than their predecessors. Both models share the same capacity; the Carrera S’s extra power comes from modified turbos, a separate exhaust and tuned engine management.
This move for the first time in the Porsche 911’s 52-year history to move the Carrera and Carrera S models to a turbocharged flat-six engine will be met with some degree of resistance among purist sports car enthusiasts, but the switch to forced induction has resulted in the fastest and most powerful Carrera and Carrera S models to date.
Four years after the arrival of the seventh-generation 911, codenamed 991, Porsche has overhauled the mainstream models with new engines, revised chassis settings, facelifted bodywork and a new infotainment system. The mid-life refresh is intended to keep the 991 competitive in the sports car marketplace until a new model arrives in 2018.
Both the Carrera and Carrera S use an all-new 3-litre, twin-turbocharged six-cylinder boxer engine. Both versions boast 20bhp increases over the outgoing normally aspirated models, with peak outputs now having risen to 365bhp and 414bhp respectively. The Carrera S’s additional power can be attributed to its pair of turbochargers boosting at 1.1bar rather than the Carrera’s 0.9bar. The turbochargers are fixed-vane items rather than the 911 Turbo’s clever variable vane type.
Torque outputs have risen more substantially – by 44lb ft on each model – but peak torque is now available from just 1700rpm, right up to 5000rpm. For reference, the previous Carrera S delivered its peak torque at 5600rpm. The figures are 332lb ft and 369lb ft for each model.
With more power than ever the Carrera and Carrera S are faster than ever, too. With the PDK twin-clutch gearbox and Sport Chrono fitted the entry-level model will reach 62mph in 4.2 seconds – two tenths quicker than before – while the Carrera S also cuts two tenths from its 0-62mph dash to clock 3.9 seconds. Top speeds are now 183mph and 191mph.
Fuel consumption has been reduced by around 10 per cent across the board. Porsche claims a Carrera with PDK will now return 38.2mpg, with the S capable of 36.7mpg.
Straight line performance and fuel efficiency have benefited from the switch to turbocharging, then, but logic suggests that throttle response, exhaust note and top-end fireworks – between them the three factors that can make an engine memorable rather than just effective – will have taken a backwards step.
Q&A with Erhard Mossle, 911 product line director
What was behind the decision to switch to turbocharged engines?
“Our normally aspirated engine is famous, but we have the challenge of regulations on fuel consumption and also challenges from competitors. It’s getting harder to get close to them with a normally aspirated engine.”
Will buyers be happy with turbo engines?
“There will be some discussion over the next six months as customers try the car. It’s similar to when we changed from the 993 to the 996, from air-cooled to water-cooled. Customers always look for the faster car, but we are satisfied with this package.”
Is there more power to come from this engine?
“There is more power we can get; it is easier to get more power from a turbocharged engine than a normally aspirated engine. In the 911 GT3 RS, we had to go to 4.0 litres to get more power. We tried to model a normally aspirated engine and avoid turbo lag as much as possible,’ he adds. ‘A lot of detail work has gone into the system to improve response. For instance, when you come off the throttle the turbos keep spinning, so they are running at a higher speed when you get back on the throttle. We also have a new sports exhaust system that sounds really good. Yes, it’s different to a normally aspirated engine, but it sounds better than the 911 Turbo, more emotional.’
Is there a place for the new four-cylinder engine family within the 911 range?
“I can’t imagine a four-cylinder in the 911.
Quote:
20 THINGS TO KNOW ABOUT THE NEW (TURBO) PORSCHE 911
SEP 7, 2015
1. It’s turbocharged (but it’s not called the 911 Turbo; that’s a separate model). It’s the first time in the 911’s history that cooking models have used forced aspiration. It’s a twin turbo set-up and the engine’s all new. Still flat six, of course.
2. It revs! The red line is 7500rpm which is astonishing for a turbo.
3. The new engine is more powerful by 20hp. The new 3.0-litre churns out 370hp for the 911 Carrera and 420hp for the Carrera S. Not much, eh? But then the the extra torque…
4. It’s torquier. Much. With 60Nm (that’s 44ft lb) extra for both Carrera and Carrera S, the peaks are now 450Nm and 500Nm respectively. 911 flat sixes have always been torquey engines but now all that twist starts working from just 1750rpm.
5. It still sounds like a 911. They say. We believe them. Can you imagine the outcry if it didn’t sound like a 911?
6. It’s quicker than before. Every generation of 911 has been faster than the previous one and the new turbo range is no exception. 0-62mph time for a PDK Sport Chrono Carrera is 4.2secs (two tenths up on its predecessor) while the S just sneaks in under 4secs. No figures yet for the manual; yes there will still be a manual ‘box.
7. Top speeds are up. The base Carrera is now a 183mph car, the S hits 191mph.
8. With the new rear-axle steering option on the Carrera S improving turn-in, the Nordschleife time is cut by 10 secs.
9. Going down… Every new Carrera automatically sinks by 10mm to improve high speed stability, a feature of the latest Porsche Active Suspension Management chassis. Porsche say it offers the best balance yet between everyday comfort and track driving performance, a balancing act that new dampers all round are said to help with too.
10. Going up… A new option is a hydraulic lift system in the front struts that raises the nose 40mm so you can negotiate pesky sleeping policemen and steep driveways without expensive graunching sounds.
11. Bigger rear wheels and tyres. Rears are up half an inch at 11.5 wide, wearing new 305 (instead of 295) rubber.
12. A tighter turning circle! Not an expected one this, and to be fair it still doesn’t put the 911 in the London taxi class. But… a by-product of that rear axle steering option is 0.5m off the kerb to kerb distance, useful for those back street U-turns.
13. There’s a new button: the Sport Response Button. Push this for a burst of max thrust for 20secs. It might be a bit like KERS but here there’s no more power, just an early wake-up call to the engine management system, selection of optimum gear and ‘pre-conditioning’ of the drivetrain, whatever that means. You only get the button with the optional Sport Chrono pack though, which also gives you a new mode (normal, sport, sport plus and individual) switch on the steering wheel.
14. The 375mm diameter steering wheel (360mm for sport option) is based on the design of the wheel in the 918 Spyder hybrid.
15. Smart-phone style multi-touch gestures and handwriting input are now possible for the revamped infotainment system; smart phones can now be connected by Wi-Fi and Bluetooth (and there’s a new tray in the centre armrest for your phone to go in!).
16. It still looks like a 911. This is a just a design freshen up, not a new body though there is a new look front and back with new lights… and we approve of the new black vertical slates on the engine cover.
17. It’s available in the UK from December.
18. It costs from £76,412, with the Carrera S from £85,857.
19. Included are leather, sports seats, satnav and touch screen, universal audio interface, Porsche Active Suspension Management and a driving course at Silverstone.
20. Did we mention efficiency? Here’s the main reason of course for the turbo turnaround. Porsche say the new model is almost 12 per cent more efficient than before, with the 911 Carrera with PDK returning 38.2mpg (and for the tax conscious, 169g/km of CO2) on the combined cycle. That’s 3.8mpg better than before.
Connect Plus: web-connected
As standard: innovative infotainment centre with online navigation, Apple CarPlay®, telephone module and Connect apps.
Sport: fit for the racetrack
Mode switch on the multifunctional GT Sports steering wheel for four driving modes – plus SPORT Response button for maximum responsiveness.
Design: sharpened
New front and rear design with fourspot LED daytime running lights, threedimensional taillights and four-spot brake lights.
Power and efficiency: increased
New twin-turbo engines for more power, considerably more torque, high rpm limits and lower consumption.
Sound: more 911
New sports exhaust system with central tailpipes announces where the 911 feels at home: on the racetrack.
Safety: reinforced
Lane Change Assist and further reinforced brake system – greater driving pleasure as well as greater safety.
Stress-relief: daily
New lift system – for increased ground clearance. Adaptive dampers on all vehicles – for greater comfort during everyday driving.
Driving dynamics: tremendous
New rear-axle steering improves driving stability and agility.
Chassis: comfortable
Standard on all models for the very first time: the Porsche Active Suspension Management (PASM), which electronically adjusts the shock absorber system.
Official 991 Gen 2 Carrera Brochure, "the 911"
Like 911UK ON FACEBOOK
 Filesize:  59 KB
 Viewed:  36809 Time(s)
 Filesize:  34.98 KB
 Filesize:  66.88 KB
 Filesize:  69.7 KB
 Filesize:  74.71 KB
 Filesize:  52.2 KB
 Filesize:  44.69 KB
RyDog
PostPosted: Sun Sep 06, 2015 11:07 pm    Post subject: 991.2 Shocking New Detailed Pictures - The New Porsche 911 Reply with quote
New 911 991.2 Carrera turbo kickstarts Porsche's turbocharged future, revealing exactly what every OPC Salesperson has been tight lipped on in recent months!
All 911 non-Turbo owners/lovers, you'll certainly remember Sept 2015!
Have you placed a recent order for a 991?
What do you think of the look / updates?
Also, what does it mean for the distinction of the 'Turbo' model?
What does it mean for the allure of the growlingly rarer N/a models?
PS - 2 Facts:
1. New Carrera models will be launched in Germany on Dec 12, 2015.
2. Think that's quick, the new C2S model is the first to hit 60 in under 4 seconds.
New order 911 due summer 2016
Ex - 911 (996 C4S x2 and 997 S Cab), Maserati GT, Range Rover, etc... and started from the bottom with a wee rusty Mini Metro Turbo (albeit a good lookalike!)
PostPosted: Sun Sep 06, 2015 11:27 pm    Post subject: Reply with quote
Surprised
I have to say everything about the new cars is more impressive than I thought it would be. worship
For some reason I thought the new 'Carrera Turbos' would only have one. Looks like the new Carrera 'S' is very similar to the 996T regarding bhp and performance but with double the mpg.
ragpicker
Estoril
PostPosted: Mon Sep 07, 2015 12:00 am    Post subject: Reply with quote
Now that I like!
i love the styling and the exhausts!
Would be interested to hear how it sounds...
isysman
PostPosted: Mon Sep 07, 2015 7:03 am    Post subject: Reply with quote
Wow both Carrera and Carrera S will have the same engine with just different turbos and other bits.
Never mentioned the GTS retaining a NA engine. That's most likely going to be a big release. I think they are going to make that car my GT3 like but with a manual option retained for the 'purists'.
911 GT2RS Build - 981 Boxster S
Sold ~ 987 Boxster S 3.4, 997.1 3.8 Cab, 987 3.2 Boxster S, 986 Boxster 2.5
New997buyer
Yas Marina
PostPosted: Mon Sep 07, 2015 11:57 am    Post subject: Reply with quote
Surprised wow...........love it. Need to get some GT3RS intercoolers and a new exhaust on mine pronto if I want to keep those whippersnappers off my heels! Driving
Ragpicker, you might need those defibrillator paddles handy for the 993 brigade Old with yet another substantial leap forward for them to deal with.......? Wink
“Forum signatures with quotes from famous people is a form of pretentiousness beyond compare, Sir!” Abraham Lincoln in conversation with Groucho Marx.
997.1 turbo man
Ex 997.1 turbo tip S, 996.2 turbo tip S, 996.1 C2 man
Outliar
PostPosted: Mon Sep 07, 2015 12:25 pm    Post subject: Reply with quote
New996Buyer, we 993 drivers will be grinning too hard to care as we bask in air-cooled, normally aspirated, authentically glorious 911 heaven.
At least I like to think that will be the case. In reality it will be pretty annoying if a well driven 993 can't make a 991 driver at least try a bit on a twisty road, without risking absolutely all. I'll have to resort to pretending I'm not trying, whilst testing if I can inch away... and looking as though I couldn't care less if they overtake (or safer, turning off down a road that I know not where it goes).
Must say I like the subtle styling changes: it looks cleaner to my eyes, especially the rear bumper on the new base carrera. And I like the new grille design on the rear lid: more motorsport than the current 991 bling...
It's a shame Porsche won't take a page out of the Mazda MX5 book and go lighter and less power... will the 2018 911 be bigger than my 2005 model BMW 5 series touring?! Just joking... though I hope they don't get any bigger.
Shanghai
PostPosted: Mon Sep 07, 2015 12:46 pm    Post subject: Reply with quote
So it's still a flat six, stupidly quick and practical, crazy mpg, how have they made a facelift look so good?? The rear pic of the S with the exhausts looks Sverige nice.. Surely will have a big effect on pre facelift 991 prices?
991 C2S X51 powerkit PDK in racing yellow, PCCB, PDCC, PSE, Sports design kit, ducktail.
EX 997.2 Carrera 4S PDK
EX 997.2 Carrera S PDK
EX 997 C2 gen 2 PDK
EX 993 Targa
EX 993 Carrera 4 manual
EX 996 3.4 Cabriolet
spyderman
PostPosted: Mon Sep 07, 2015 12:56 pm    Post subject: Reply with quote
They have - its called the Boxster.
2004 Boxster S 550 Spyder Anniversary Edition
Outliar
PostPosted: Mon Sep 07, 2015 1:01 pm    Post subject: Reply with quote
Yes that's true, but my gybe was at the increasing size of 911s, rather than a like-for-like comparison. I rather like the new Spyder actually, saw one yesterday at the Classics at the Castle.
gred
PostPosted: Mon Sep 07, 2015 5:10 pm    Post subject: Reply with quote
I'm a bit confused by the three different exhaust configurations. The base Carrera has the rectangular ones, the 'S' the twin outlets on either side, so what's the 'S' version with two outlets closer to the middle - is that an option? Certainly looks the part.
New997buyer
Yas Marina
PostPosted: Mon Sep 07, 2015 5:16 pm    Post subject: Reply with quote
Nice Grin Salut
997.1 turbo man
gred
PostPosted: Mon Sep 07, 2015 5:21 pm    Post subject: Reply with quote
Answered my own question - sports exhaust is an option on the S. Configurator working on porsche.com, should have looked first Confused
MJA911
2012 Porsche 991 Carrera
PostPosted: Mon Sep 07, 2015 5:33 pm    Post subject: Reply with quote
Glad you answered that, I was just about to ask Embarassed
These look awesome machines, being a 991 fan I'm now hopeful that these puppies will help the prices of all those 991.1 that people trade in for them to come down a little faster than they would have done. Selfish I know.
991.1 C2 PDK, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
Maxie
Yas Marina
PostPosted: Mon Sep 07, 2015 5:39 pm    Post subject: Reply with quote
My guess is that the quad exhaust set-up is the PSE option; where the two inner exhausts are only active when the PSE is switched on.
~ Maxie
Currently Porscheless, 2018 BMW 640d M Sport +
ragpicker
Estoril
PostPosted: Mon Sep 07, 2015 6:03 pm    Post subject: Reply with quote
The GT3 doesn't have intercoolers dear boy with it being N/A and all that! But then I'll forgive a slip of the finger just this once! Grin
This is the first time since the 981 was released that I've actually considered buying one new from OPC. I normally can't stomach the depreciation so always buy once this has been eliminated...
I was wondering about the exhaust config too, I much prefer the two pipes closer together, I think that looks ace!
Oh, N996B, I don't even think the defib would work on the 993 beardy brigade with this new technology.... We might have to resort to Cheshire911's smelling salts! Floor
Winny911
PostPosted: Mon Sep 07, 2015 6:27 pm    Post subject: Reply with quote
So would that engine fit in my 996? If so I will have a car that is faster than the 996 turbo without the ugly air intakes Wink
Shanghai
PostPosted: Mon Sep 07, 2015 7:56 pm    Post subject: Reply with quote
+1 another selfish one here! Doubt the 991 turbos (err big turbos lol) and the 991 GTS will fall that quick mind.....
EX 997 C2 gen 2 PDK
EX 993 Targa
New997buyer
Yas Marina
PostPosted: Mon Sep 07, 2015 8:06 pm    Post subject: Reply with quote
It's where I store my packed lunch Dont know
997.1 turbo man
New997buyer
Yas Marina
PostPosted: Mon Sep 07, 2015 8:16 pm    Post subject: Reply with quote
I'm such a numpty - I meant 'GT2RS'..... Duh Embarassed Get Me Coat
997.1 turbo man
