Hi all
After a long search I bought a 964 C4 in June. The car is a 1990 manual coupe, with lots of work done but more still needed. The heater is one of the problems and I am looking for advice. It has a mind of its own and sometimes blows hot air instead of cold, but with no obvious pattern.
A first attempt hasn't solved the problem but it turns out that a linkage arm and ball-joint from one of the servo/valves is missing. I'm told that you can't buy them without the servo.
I would like to try to find a linkage before further testing. Does anyone know if the linkages can be bought? Or does anyone have linkage I could buy?
Chris
Chris
