991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 33
Boxster : 1997- 25
drabux
PostPosted: Tue Aug 11, 2015 8:17 pm    Post subject: Steering rack removal problems Reply with quote
Hi All,
I've run into a bit of a brick wall trying to remove the steering rack on my 996TT: I can't remove the high and low pressure lines from the rack. They seem to be stuck fast.
I removed the metal plate holding them in place and they seem to be lodged in the steering rack firmly. I've tried WD40, with the usual, predictable results. I've tried levering them out with 15mm and 12mm spanners around their collars, but no go. Any other suggestions? These lines are expensive and difficult to replace, so I don't want to damage them.
Cheers,
Alan
2008 Porsche 997TT
2007 Mazda 6 Derv
1977 Saab 99 with 900T engine and 9-3 Trionic engine control
Slutters
PostPosted: Tue Aug 11, 2015 8:47 pm    Post subject: Reply with quote
Yep! Changed the lines on mine years ago, same issue, they weld themselves to the rack, try a bit of heat perhaps if your getting a recon rack.
drabux
PostPosted: Tue Aug 11, 2015 8:57 pm    Post subject: Reply with quote
Slutters,
A bit scared of heat because the plastic fuel tank is very close by as well as other hoses/pipes. How did you remove yours?
2008 Porsche 997TT
2007 Mazda 6 Derv
Slutters
PostPosted: Wed Aug 12, 2015 7:52 pm    Post subject: Reply with quote
drabux wrote:
Slutters,
By changing all the pipes too.... Laughing
drabux
PostPosted: Thu Aug 13, 2015 11:06 pm    Post subject: Reply with quote
Well, an update. The pipes finally came out of the steering rack with much heat and much pulling. When I put them into the new rack, they leaked around their collars like the Amoco Cadiz. Clearly the pulling had damaged the connectors.
So, I now have both lines leaking like hell. They cost GBP500 and about another 600 to fit (subframe needs to be dropped). My plan: I've just bought a brazing kit in the hope that I can seal the awful leak that has appeared.
On a side note, the design of the lines going into the steering rack is appalling and so obviously will lead to corroded, hard to remove lines. what
2008 Porsche 997TT
2007 Mazda 6 Derv
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Aug 14, 2015 9:07 am    Post subject: Reply with quote
Were there any O rings on the pipes, I'm not sure there would be as I've never removed those pipes but if you heated them up they may of disintegrated?
Chris_in_the_UK
Estoril
PostPosted: Fri Aug 14, 2015 9:17 am    Post subject: Reply with quote
The parts drawing shows the pipes as having O rings.
2006 Cayman S PCCB's
drabux
PostPosted: Fri Aug 14, 2015 4:44 pm    Post subject: Reply with quote
It's not the o rings causing the leak. I replaced these.
The pipe goes into the connector and where the pipe joins with the connector is where it is leaking. The cause of this was that I resorted to tugging on the pipe in order to try to get the connector out of the steering rack. I'm surprised how fragile the fitting is as well as the ridiculous way the pipe is connected to the rack. What is wrong with a banjo connection?
Brazing kit due mid- next week. Will report again then. frustrated
2008 Porsche 997TT
2007 Mazda 6 Derv
Chris_in_the_UK
Estoril
PostPosted: Fri Aug 14, 2015 7:12 pm    Post subject: Reply with quote
Can you post a picture of the offending area?
drabux
PostPosted: Fri Aug 14, 2015 7:29 pm    Post subject: Reply with quote
Chris,
I'm not near the car now but here's a picture from the internet showing one of the connectors which push fits into the rack. I've pointed out where the leak is coming from. The pipe is aluminium covered in black plastic. I've removed some of the plastic in the hope I can get a decent braze between aluminium and what looks like brass.
2008 Porsche 997TT
2007 Mazda 6 Derv
 Filesize:  55.16 KB
 Viewed:  4515 Time(s)
Chris_in_the_UK
Estoril
PostPosted: Fri Aug 14, 2015 7:41 pm    Post subject: Reply with quote
Hmm - I had a similar issue with clutch line which is wholly unrelated except for the fact that Porsche had chosen to use an aerospace fitting for the joints. This was a pain since the fittings were not available separately blah, blah, blah.
It would be useful to know if they have done the same for the steering lines - if they have there may be a seal inside the body of the part you posted?.
drabux
PostPosted: Fri Aug 14, 2015 8:19 pm    Post subject: Reply with quote
I suspect there is a seal, but I cannot see how I can get to it.
Brazing brass to aluminium is not going to be easy but I don't know what else to do...
2008 Porsche 997TT
2007 Mazda 6 Derv
Chris_in_the_UK
Estoril
PostPosted: Fri Aug 14, 2015 8:32 pm    Post subject: Reply with quote
I had the same - the fitting I dealt with had a section that unscrewed but there were no flats to get hold of.
The photo looks as though the end that is radiused where the pipe comes in from the left may have a seal underneath it.
I suspect trying to braze it may be troublesome (sorry - I know this is not what you want to read!) if it has a seal inside.
Have you read this related thread?
http://www.911uk.com/viewtopic.php?t=59694&sid=45f4fd1590a13ad760ec1e83054f1678
drabux
PostPosted: Fri Aug 14, 2015 9:18 pm    Post subject: Reply with quote
Chris, Thanks for that. I had already read that post. I'm going to try to solder the joint using this http://durafix.com/index.html
If it fails, I think I will buy some second hand lines with decent connectors, cut the pipes and use compression fittings to join to my current pipes. Does that sound mad?
2008 Porsche 997TT
2007 Mazda 6 Derv
Chris_in_the_UK
Estoril
PostPosted: Fri Aug 14, 2015 9:22 pm    Post subject: Reply with quote
TBH, no.
Had I not been able to solve my clutch hose issues I had realised it was far cheaper to use a hose specialist to make a braided one with the correct fittings. I was quoted less than £100 for what would have been £600 using Porsche parts. Thankfully I managed to sort it using a combination of the old pipe fittings and the new pipe.
Personally I would go down the compression fitting route with assistance from a local hydraulic hose specialist.
Your call mate - I feel your pain!!!
wasz
1999 Porsche 996 Carrera 2
PostPosted: Sat Aug 15, 2015 12:56 pm    Post subject: Reply with quote
This is what I did for a similar problem on a mk2 golf.
Take a picture to a local specialist, of they can get the fittings they will make something up. there will be one on an industrial estate near you!
997 Funch
PostPosted: Mon Aug 19, 2019 2:25 am    Post subject: Reply with quote
Sorry for opening this up again, how did this turn out? I have the same issue and cannot see how long this section of pipe is?
