997 : 2004- 69
Boxster : 1997- 31
clinchy993
PostPosted: Sun Mar 06, 2016 7:31 pm    Post subject: Reply with quote
Nice to see a rare red one Steve
Keep up the good work it ,will be worth it
I have not done to much to mine, only drove it 500 miles total in the last year due the wallet busting gearbox rebuild and new lsd diff on my 993 Sad
Mr Bacchus
PostPosted: Mon May 02, 2016 7:37 pm    Post subject: Reply with quote
Well, after 4.5 months away I finally got the car back from Garry a couple of weeks since. After managing to screw it all back together I was not happy with the vinyl wrapped reflector and lights so I got those on order from OPC.
Unfortunately whilst the car was away it developed a fuel leak and on examination I found it to be squirting badly from a perished fuel hose, yes the little hose that is hard connected by tube all the way to the fuel pump.
I had already planned to sort the fuel lines as there is a bit of corrosion on the tube bend as it arcs up over the wheel arch. After further inspection today I'm going to replace most of the tube with braided teflon hose, connecting to the tube on the underside (most of the tube is sound) and then running all the way to the filter. Only difficulty may be joining the 10mm tube to the 3/8 tube adaptor but I think I can sort that.
Once it is running again the car has to go back to Garry for a final polish and then I'll take it to Chris at Total Detailing for some paint protection.
In vino veritas
MY89 964 C4 Guards Red, MY19 Evoque
paul284pt
PostPosted: Mon May 02, 2016 8:41 pm    Post subject: Reply with quote
Hi Steve,
Is that the same fuel line part which DD had a problem with last year?
Chris will make it look better than new Thumb
Cheers,
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
Mr Bacchus
PostPosted: Mon May 02, 2016 8:45 pm    Post subject: Reply with quote
Hi Paul,
From memory DDs went on the steel tube, probably the same place as where mine is corroded.
Chris does a cracking job, he's done a good few cars for me now including the Porsche last March for my daughters wedding. I could do with getting my Beemer in as the blue should shine up well.
In vino veritas
Mr Bacchus
PostPosted: Mon Jun 27, 2016 11:28 am    Post subject: Reply with quote
Hi all,
So, now I've made my new fuel lines and fixed the leak and had a few weekends play its now time to get back to replacing the suspension. I've been getting all the bolts loose in slow time so that when it comes to the big weekend it will hopefully be less of a fight. Only the big rear bolts still to defeat!
My question to those who have done the suspension swap thing, how do I get a baseline set-up in advance of getting the geo sorted ? Do I just fit the H&R springs to the Bilstein B6s as they come out of the box or do I have to make some adjustment to the collar position? I'll be honest and say I haven't read the documentation that comes with the dampers yet Rolling Eyes . I've read a few DIYs so I'm happy to do the swap just a bit clueless on the set-up.
FYI I'm going to try and get Redline at Thornaby to do the geo.
Any advice appreciated
Steve
In vino veritas
Johnd52
2011 Porsche Cayman 987
PostPosted: Mon Jun 27, 2016 9:26 pm    Post subject: Reply with quote
Hi Steve. Redline did the geo on my Cayman and I was very pleased with the result.
John
2015 Cayman GTS. No more PDK but still red.
Mr Bacchus
PostPosted: Sun Jul 17, 2016 4:55 pm    Post subject: Reply with quote
Cheers John, thats good to know.
So, I'm making slow but steady progress. Slow mainly because I can't stand to have the car off the road.
I've managed to free up all of the major suspension bolts, some with quite a fight, and then loosely build up the dampers. I seem to have bought way more parts than I will need for the job Rolling Eyes
I thought I'd check my ride heights and corner weights before I change the suspension - just because I like data and have suitable kit around me. A few pics below and I'll publish the data when I get it typed up, quite surprised it was close to book values.
Next job is to get the seat piping repaired. I've found a chap on Facebook local to me who is going to replace the piping on the drivers seat and then re-colour the piping on both. I'm not doing anything else on the seats as I quite like the 'driven in' look and the condition is canny.
My next choice is wheels, I've 'narrowed' the choice down to…..
Refurbished D90s (I'll do this anyway)
Fuchs - three choices of finish, maybe go for all silver or maybe silver petals
Outlaw 52 in gold/black - somewhat pricey but they are very pretty.
I have even thought about gold D90s!
Regardless of which, I'm going to go up an inch Laughing
Thats all for now.
Steve
In vino veritas
Gazc2
Watkins Glen
PostPosted: Sun Jul 17, 2016 6:08 pm    Post subject: Reply with quote
nice set of rims here Steve
https://www.gumtree.com/p/wheel-rims-tyres/18-porsche-911-964-993-996-944-968-alloy-wheels-and-tyres-krone-/1178225012
think I seen a 964 with a set of these and it looked cracking Very Happy
( Chris has my old ones up in the for sale section)
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
KP964
PostPosted: Tue Jul 19, 2016 2:04 pm    Post subject: Reply with quote
Looking great Steve , just letting you know we have run out planned for Sunday 31st , hope you can make it . Keith
Stone Grey Metallic 964 C4
Guards Red 964 C4 sold
Mr Bacchus
PostPosted: Fri Aug 05, 2016 8:37 pm    Post subject: Reply with quote
Oops, missed your post Kieth, haven't had a chance to get on here recently.
Bit of a set back with the work. I found a guy local to me who (claimed he) could replace the seat piping and recolour the rest of the piping. I gave him the back of the seat to take away but when he returned it, after too long, the leather was all puckered along the piping and the centre bit has gone all saggy. I had to pay him off.
It's so bad I can't bear to post a picture. Anyway, I've managed to massage it into an almost acceptable condition and it back in the car albeit now on the passenger side to hide it a bit.
Keep calm and carry on as the saying goes.
Steve
In vino veritas
Jcx
Estoril
2010 Porsche 997 Turbo
PostPosted: Fri Aug 05, 2016 10:18 pm    Post subject: Reply with quote
Steve
I feel for you. That would drive me nuts.
Mr Bacchus
PostPosted: Sat Nov 12, 2016 9:21 pm    Post subject: Reply with quote
Bit of an update on progress as I did little during the summer months and only recently picked up pace.
- Replaced rear dampers, springs, top mounts etc etc.
- Replaced rear anti-roll bar bushes with SuperPro.
- Cleaned and painted rear anti-roll bar.
- Replaced rear drop links.
- Removed front suspension.
- Built up front struts, springs, new top mounts etc
- Replaced track rods
- Replaced front drop links
- Replacing ball joints now, NS came of easy, still fighting OS!
- Bought new wishbone bushes last year but discovered from my service history the current wishbones are only about 20k miles old. Yay!
- Decided that all fasteners removed would be replaced with new.
- Considering replacing the front diff driveshaft seals whilst I have access as I've a bit of a leak, bought the seals already.
- Bought another set of D90s from a lad that works at Absolute VW and posted on Facebook 964 club, they came with remarkably good tyres that I didn't particularly want when I placed my order. I'm going to experiment with wheel colour!!!
The application of PlusGas to the suspension parts during the summer months paid off as their was little fighting with nuts and bolts - but the steering parts I changed without prior planning fought very hard.
The cars been on axle stands for about 4 weeks now so I'm getting withdrawal symptoms, hopefully I can get it back together next weekend. Progress also hampered considerably by the arrival of a 10-week old Boston Terrier.
Also, had my second bi-annual valuation for the agreed value insurance, now at 2.2 x what I paid in November 2012 - which ultimately increases my insurance a tad but it's nice to know.
I've loads of pictures but most are how knackered the parts I removed are, I'll post a few when time permits.
Steve
In vino veritas
deutschland-dobson
PostPosted: Sat Nov 12, 2016 9:33 pm    Post subject: Reply with quote
Wow, that's some work!
Hats off to you Steve, she's going to be great!
Chris
Porsche 911 (964) C4 - Project RED - Outlaw4
Guards Red & Linen, Custom Leather, BBS LM Split-rims, H&R Coilovers, Cleaned Bodywork, 90s audio instal...
KP964
PostPosted: Mon Nov 14, 2016 11:34 pm    Post subject: Reply with quote
Had my front wishbone bushes replaced a while back with standard powerflex.. boy did I notice the difference straight away , really tightened up the front end .
Worth doing but 20k they should still be fine , lots done there Steve , well done . Thumb
Mr Bacchus
PostPosted: Tue Dec 27, 2016 3:23 pm    Post subject: Reply with quote
Hi All,
Hope you all had a nice Christmas.
I'm needing a bit of moral support here. Whilst I was replacing the bits I listed above I also decided to replace the following (as you do):
- front hubs (bought some nice refurbished ones)
- All brake discs and pads (fronts done, rears still to do).
I planned, and achieved, getting the car finished before Christmas day (with exception of rear discs) but now I have a problem.
Took the car out for first drive with the new shiny bits and I have got quite a nasty vibration under braking(pulsation is a better description I think). It's not a violent shudder but very noticeable. Its speed dependant meaning if I brake from higher speeds the pulse frequency is high and vice versa.
I know disc run-out could cause this, even a few microns. I've had the discs off a couple of times to check run out as best I can and, as best I can tell without a dial indicator, they seem okay (I'm measuring with a steel rule from a datum and can't measure any run out). I also checked run-out of the hubs.
I noticed as I was putting the discs back on this afternoon that the front anti-roll bar does not seem to be seated properly in the bush - and the bush is probably past its best. I didn't change these during the works as I could not see how to get access to the front-most clamp bolts without major work.
So, would the front anti-roll bar not seated cause this vibration? I can't be helping but I can't help thinking that something rotational is the cause?
Has anyone changed the front bushes and is it a PITA? Confused
With having changed so many bits I'm a bit perplexed as to where to start other than the bush.
I was looking forward to getting a 4-wheel alignment in the next couple of days but have postponed that until I cure this frustrated
All the best
Steve
In vino veritas
KP964
PostPosted: Tue Dec 27, 2016 3:37 pm    Post subject: Reply with quote
I would first have the discs checked out at a garage , ive had this twice with new discs, "Pagid" both times replacements fitted and it was ok . atb
paul284pt
PostPosted: Tue Dec 27, 2016 6:08 pm    Post subject: Reply with quote
Hi Steve,
You are certainly going to town, I'm going to give you the "Trigger's Broom Award", I've had it long enough Grin
I would say discs would be the most likely culprit. Also, what pads are you using? I had some Pagid yellows (for track work) which were a bit iffy until they were fully warmed up. I changed them to a more suitable pad for roads.
However, I had a Subaru Impreza and the wobble under braking turned out to be a badly fitted suspension mount.
Hope you get it sorted.
Cheers,
Paul
deutschland-dobson
PostPosted: Tue Dec 27, 2016 7:25 pm    Post subject: Reply with quote
Hi Steve,
Not 964, but this may help
http://911uk.com/viewtopic.php?p=1007182&sid=d4cbdd3a4c341411f75d7d96e3c7825e
Hope you get it sorted Smile
Chris
igaffz
PostPosted: Tue Dec 27, 2016 8:20 pm    Post subject: Reply with quote
Hi Steve, if the pulse through the pedal is only under braking I would start with the discsbut don't count out the front calipers either.
Check the discs are seating properly, what happens when you spin the disc, dose it jam in the pads?
I have two spare new front discs if you want to borrow them?
Horizon blue, 964 carrera 2 tip, lowered on koni's, k&n, de-cat, cup pipe, leather trim and 18" 3 piece split rims.
Silver 928 S2, B reg, manual.
Guards red 944 lux, the new project!
Mr Bacchus
PostPosted: Wed Dec 28, 2016 2:32 pm    Post subject: Reply with quote
Hi Chaps,
Thanks for the advice. In answer to some of your questions:
Paul - Pads are Brembo (for no particular reason)
Discs although not used, were bought second hand with a bunch of other parts, mainly the refurbished hubs.
Ian - I tried spinning the discs and there is a slight tight spot on both discs. I guess this is the cause but I don't yet know if it is the discs or the refurbished hubs that has run-out. Thanks for the offer of the discs. I may just get some new as I can just pop to Team Valley - time is of the essence.
Today I re-seated the anti-roll bar without any change to the judder. Think I might try replacing the discs first as this is quite easy even if it costs a little bit.
I'm hoping it's not the hubs but thankfully I still have the originals (all other parts removed have been binned).
In vino veritas
Goto page Previous  1, 2, 3, 4  Next
Page 3 of 4
