997 : 2004- 79
996 : 1997-2005 44
993 : 1993-1998 6
Boxster : 1997- 19
Cayman : 2005- 11
Macan : 2014- 1
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Aug 03, 2015 9:31 pm    Post subject: Comparison of Meyle Coffin arms VS TRW made Genuine Porsche Reply with quote
So here it is, the one you have all been waiting for. I replaced my originals with Meyle arms and noted the differences.
Are those ~ 45 quid Meyle brand coffin arms as good as the TRW originals?
    - Meyle arms are 200g (15%) heavier than TRW
    - Looking at the photos you can see the extra material in them.
That's about the only real functional difference I noted. So by using Meyle arms you are somewhat negating all the effort Porsche put into reducing unsprung mass by fitting alloy arms.
paul987
PostPosted: Mon Aug 03, 2015 10:20 pm    Post subject: Reply with quote
Great comparison sir! Thank you Thumb
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
Steve Gom
PostPosted: Tue Aug 04, 2015 12:06 pm    Post subject: Coffin Arms Reply with quote
Another job on my to do list...
Steve
Steve
Slow in fast out...
1997 996 C2 manual
2006 955 Cayenne 3.2 tip
1998 RS 50th Anniversary VFR 800FiW
Steve Gom
Steve
Steve
Slow in fast out...
1997 996 C2 manual
angry
PostPosted: Tue Aug 04, 2015 1:34 pm    Post subject: Reply with quote
Another difference!!!
Im not sure if it was just a bad batch, but I've just put Bilstien pss10 and lower arms (meyle) on my 996 Turbo and sent it to Precision to get set up.
Precision are saying they cannot get the correct camber, because the Meyle arms are so badly sized. They've had this before and wouldn't recommend buying them. Ive now had to shell out for genuine ones nooo
DONT GO NEAR THEM Hand
996 Turbo Previous
993 C2.
DaveR6
PostPosted: Tue Aug 04, 2015 5:06 pm    Post subject: Reply with quote
I replaced all mine now with Meyle, I'm at least 6 months in, had hunter alignment done with no issues.
So, got all 4 done with alignment for less than £300 .... bargain,
as for the extra weight, I also fill my petrol tank up, instead of leaving it half full, so I don't really worry about the weight issue.
But, I don't use my car on a track , it's a high days & holidays car,
so really,
you pays your money & you makes your choice.
Seal grey 996 Targa, 2003
996ttalot
Approved Trader
PostPosted: Tue Aug 04, 2015 5:59 pm    Post subject: Reply with quote
Correct - don't go near them. We have already made them aware that you cannot get standard settings with these lca because of the extra size. Complete waste of money.
Edit - you can fit them on the front and get the specs to standard. You cannot do it on the rear however.
nineexcellence.com
Tel: 01293 226911. Follow us on Facebook www.facebook.com/Nineexcellence
SALES, SERVICE, UPGRADES
Harv
PostPosted: Tue Aug 04, 2015 7:23 pm    Post subject: Reply with quote
Ewwww
At the back are you getting too much camber rather than not enough? Surprised
Jonathon555
PostPosted: Tue Aug 04, 2015 7:59 pm    Post subject: Reply with quote
I fitted TRW on the front(bought a year ago) £45 each and Meyle( bought year ago) £44 each on the rear
Car aligned to factory spec no problem at all.
The casting on the meyle ones i got looked very well finished comparable to TRW
Not sure if things have changed Dont know
Doctorima
PostPosted: Tue Aug 04, 2015 8:12 pm    Post subject: Reply with quote
Does anyone know if the cheaper arms are made from exactly the same material ? Maybe they have been made " beefier" because they are made from inferior aluminium ??
993 c4 1996
Lotus elan 1967
Audi S4 estate 2010
911 sc Targa in bits
2.5 Boxster 1997
Mercedes A class 1.6 cdi 2004
testdr
PostPosted: Sat Jan 13, 2018 2:54 am    Post subject: Re: Comparison of Meyle Coffin arms VS TRW made Genuine Pors Reply with quote
Bought a set of CTE for my 996t. Looks good in quality. Matt from type911 said these were the closest thing to TRW arms, since TRW don't make them anymore. They weight 1.47kg
timm996
PostPosted: Sat Jan 13, 2018 7:24 am    Post subject: Reply with quote
Agreed I had massive problems getting the alignment correct on the rear, they were so different I had huge toe in. In the end settled for a camber compromise.
ragpicker
Estoril
PostPosted: Sat Jan 13, 2018 7:38 am    Post subject: Reply with quote
Another difference - one looks nice and shiny, the other is a bit brown and dull... Dont know
996 turbo - slightly modified....
wasz
PostPosted: Sat Jan 13, 2018 8:11 am    Post subject: Reply with quote
I assure you the shiny ones are now dull after 1.5 winters of salty roads.
APL911
PostPosted: Sat Jan 13, 2018 10:15 am    Post subject: Reply with quote
Having just fitted the Meyle ones and having alignment done with no issues, I’d like to hear more on the size issue? I also lowered mine by 30mm so had the geo set to the x74 spec.
As for 25g difference in unsprung mass, I don’t think I’m astute enough to feel the difference?
I do now feel naive as I didn’t even consider that there would be a significant difference between these and OEM, but now you mention it, it seems obvious there will be some difference.
wasz
PostPosted: Sat Jan 13, 2018 5:40 pm    Post subject: Reply with quote
No one would notice.
I think the short arms were a bad batch a couple of years back they have now fixed it.
jimmy p
PostPosted: Sun Jan 14, 2018 5:04 am    Post subject: Reply with quote
Centre gravity fit meyle arms so cant be that bad, they wouldnt want to waste their time
987.2 Boxster Spyder manual, buckets, spyder alloys,pse
Ex
1999 996.1 c2 aerokit in white
1996 993 c2 polar silver
2002 996 c4s seal grey
maldren
PostPosted: Sun Jan 14, 2018 10:01 am    Post subject: Reply with quote
Anyone tried these, they seem vert cheap!?!?
http://www.ebay.co.uk/itm/4x-TRACK-CONTROL-ARM-FRONT-REAR-PORSCHE-CARRERA-911-996-97-04-BOXSTER-986-96-04/381524276963?hash=item58d49e76e3:g:O~IAAOSwqfpZw-iZ
Mike
I Rock
PostPosted: Tue Jun 26, 2018 6:34 pm    Post subject: Reply with quote
I was looking to get Meyle . The ATP looked total bargain and elsewhere I did read some folks happy with them . However , just stumbled across TRW pair new and bagged from ebay seller .
2002 996 Turbo
ex 1997 993 Turbo
ex 1996 Carerra 2
ex 1985 Carerra 3.2
ex 1989 944 Lux 2.7
ex 1987 VW Golf GTI 16V
IanG1
PostPosted: Tue Jun 26, 2018 6:56 pm    Post subject: Reply with quote
I took a punt on a pair, I measured them up to my originals and dimensions were spot on, mine is a sunny day car with low driven miles a year so if they last a couple of years its cheap motoring. Yhey fitted fine and 2 evenings in the garage had both my fronts changed.
1998 996.1 C2 manual/LSD with aero and a big smile
