997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
adbett
PostPosted: Mon Jun 15, 2015 10:25 am    Post subject: 996.2 GT3 front splitters - 3 versions? Reply with quote
Need to get another new splitter and trying to find the correct part number...there are lots of references to 'standard' and the 'cup' versions online but I think my previous one was a different version again? Are there 3 OEM versions available?
'standard' 996 505 986 92 01
The bottom lip gets shorter around the side of the car and blends into the PU just ahead of the front wheel. Expensive
'the last one I had'
Same depth as the standard but bottom lip protrudes all the way around and does not blend. Would like to get this one assuming cheaper
'cup' 996 505 986 91 ??
Deeper lip and extends all the way around (worse for speed bumps!)
You can just about see three versions in this old thread:
http://www.6speedonline.com/forums/996-turbo-gt2/319019-996gt3-rs-cup-lip-996gt2-bumper.html
red car = 'the last one I had'
orange tape = standard
white car at bottom = cup
Can anyone help with the missing part number or have I confused the versions out there?
Stuart
2004 Porsche 996 GT3 Mk2
PostPosted: Mon Jun 15, 2015 12:08 pm    Post subject: Reply with quote
Only 2 versions, regular which has smooth finish hence more expensive, and cup/motorsport version which is deeper, less well finished, and cheaper.
Stuart
PostPosted: Mon Jun 15, 2015 1:30 pm    Post subject: Reply with quote
Little bit more info.
What you are seeing is 3 different splitters but the smallest is actually for the 996.1
The 2 larger are 996.2
The orange tape is on the standard 99650598602 part and the larger cup/motorsport is 99650598691
kas750
Reims
2006 Porsche 911
PostPosted: Mon Jun 15, 2015 2:08 pm    Post subject: Reply with quote
On a side note are there different versions for the 997 GT3 does anyone know?
Cunno
PostPosted: Mon Jun 15, 2015 7:45 pm    Post subject: Reply with quote
Yes same for 997, normal and cup.
Porsche is for driving not for washing.
Present Car: 2006 3.6 Porsche GT3 997(White)
Ex: 2006 3.4 Porsche Cayman S (Silver)
Ex: 2001 2.7 Porsche Boxster (Seal Grey)
kas750
Reims
2006 Porsche 911
PostPosted: Mon Jun 15, 2015 8:07 pm    Post subject: Reply with quote
Thanks for that.I seem to remember reading about 2 types a while ago.
I rang my local OPC last week and he seemed to think there was only one and it was listed at £220?
Cunno
PostPosted: Mon Jun 15, 2015 8:24 pm    Post subject: Reply with quote
Cup part is between £100 -£120, but is deeper so will ground a lot more. OPC will only see standard parts on PET.
kas750
Reims
2006 Porsche 911
PostPosted: Mon Jun 15, 2015 8:35 pm    Post subject: Reply with quote
Can I order the cup part from OPC then if I can find the part number?
Cunno
PostPosted: Mon Jun 15, 2015 8:42 pm    Post subject: Reply with quote
Yes
Part No 997.505.983.91 (including air ducts)
kas750
Reims
2006 Porsche 911
PostPosted: Mon Jun 15, 2015 8:53 pm    Post subject: Reply with quote
Cheers Jon.I really appreciate that.I'll get on to them tomorrow. Thumb
Cunno
PostPosted: Mon Jun 15, 2015 9:03 pm    Post subject: Reply with quote
Just be aware that the cup parts sits 20mm closer to the ground than a standard splitter and therefore you will be scraping it a lot more. I gave up using a cup splitter on the road.
NLW73
PostPosted: Tue Jun 16, 2015 8:27 am    Post subject: Reply with quote
there are a few on ebay from 9apart which are OEM and good money delivered.
just have a look on their shop or do a search on GT3 splitter front
good outfit for spares and have used in the past well.
about 1/3 of price of new from OPC and looks like OEM parts too!
997 C2s Schwarz
adbett
PostPosted: Tue Jun 16, 2015 8:59 am    Post subject: Reply with quote
Stuart - thanks for the detailed answer, I may have a very firm grasp on the wrong end of the stick but I still think I see two different non-Cup versions in the photos though?
Both of these are normal (non-Cup) depth but on one the lip protrudes all
the way to the end but on the other it blends back in the bumper? I think both are for 996.2 model
I'm not fussed which one I have but if there is a cheaper version out there which isn't as deep as the Cup it would be good to find!
adbett
good tip for 9apart, not used them before, will have a look
Stuart
PostPosted: Tue Jun 16, 2015 9:16 am    Post subject: Reply with quote
The one with the pre-applied tape is standard and the extended edge version is cup (on red car), same as I currently have fitted. I'm pretty sure that's correct from memory. Every cup splitter I've purchased hasn't come with pre-applied tape and is definitely not as well finished as the standard.
If you read the rennlist link within the 6speed link it does mention that there is an aero version available but can't find part number, this may be the smaller of the 3 in pictures. Possibly the same size/shape as the MK1 GT3 splitter.
adbett
PostPosted: Tue Jun 16, 2015 9:43 am    Post subject: Reply with quote
NLW73
PostPosted: Wed Jun 17, 2015 7:11 am    Post subject: Reply with quote
mate of mine with a white/blue 6.3 RS is fed up with his cup splitter scraping on the new speedhumps in his area and garage forecourts!!
if you are interested in that? its not wrecked but he just hates that scraping sound. he is going back to a normal smaller front lip and I know he got one recently from 9Apart.
PM me and I can connect you if you like.
defo some stuff on flea bay that would work. OEM and new.
997 C2s Schwarz
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Wed Jun 17, 2015 7:17 am    Post subject: Reply with quote
The flatter splitter used to be about £85 from OPC, but that part number no longer exists and has been superseded by something which is now £220 ish. Disgraceful price-hiking.
I bought one of someone on here that they had bought for £150.
I get few a fair amount of them, but taking twice as much care now (making my annual splitter bill the same as before)
If your looking for a secondhand one there is one in a some woods in France, although it has been ran over by Cunno!
kas750
Reims
2006 Porsche 911
PostPosted: Wed Jun 17, 2015 8:46 pm    Post subject: Reply with quote
I will bear that in mind.I ordered 2 today. Thumb
NLW73
PostPosted: Thu Jun 18, 2015 7:20 am    Post subject: Reply with quote
top tip....ebay.de is your friend.
stuff in Germany is about half the price of rip off Britain. am a fluent german speaker so that helps but can help to get you stuff if needed.
some places will ship to UK but some Germany only. no bother as friends runs a hotel near the ring so I get stuff sent there and always people coming back to the UK who I know to get dropped off.
couple of options here...
1. smaller front lip splitter by CSR:
http://www.ebay.de/itm/CSR-Cup-Spoilerlippe-Porsche-911-996-GT3-2003-2005-/191528691591?pt=LH_DefaultDomain_77&fits=Year%3A2000%7CMake%3APorsche%7CModel%3A911&hash=item2c97ffe787
129 Euros is about £95!
2. slightlu larger front lip splitter (more like cup one?)
http://www.ebay.de/itm/Spoilerlippe-Porsche-911-GT3-Typ-996-Bj-99-06-Frontspoiler-Spoiler-Diffusor/201345122913?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140117130753%26meid%3D37c47de19dd44245a4cc62fbf2ffc0f1%26pid%3D100005%26rk%3D1%26rkt%3D2%26mehot%3Dlo%26sd%3D191528691591&rt=nc
144 euros is just under £105! delivered is 170 euros.
Nick
997 C2s Schwarz
