997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
alex yates
PostPosted: Thu Mar 10, 2016 5:10 pm    Post subject: Reply with quote
Yes, I stated that a while back. Long time is 2 years and 24000 miles for a car running on the oil it came off the production line with, especially when it's being run in.
alex yates
PostPosted: Fri Mar 11, 2016 3:12 pm    Post subject: Reply with quote
Just another thing worth noting. In the 2 years I've been a member of this site, I've only ever witnessed the posting of one IMS bearing failure.......on a 997 Question
Halcyon
PostPosted: Fri Mar 11, 2016 6:46 pm    Post subject: Reply with quote
Are we still waiting for the diagnosis on this one?
http://www.911uk.com/viewtopic.php?t=110239
You're doing a great job of giving people "real world" facts about the IMS issue that if you were to believe the interwebs, you'd think every single one failed! I'm sure there's lots of people that appreciate it as much as me Smile
But, of course, we all know that it's bore scoring that affects all the 3.6 engine ever made!! Evil or Very Mad
(maybe..) Grin
alex yates
PostPosted: Fri Mar 11, 2016 7:41 pm    Post subject: Reply with quote
Thank you kind sir Cap
Niall996
PostPosted: Fri Mar 11, 2016 8:44 pm    Post subject: Reply with quote
Are you sure about that? I seem to recall a few (generally newbies who then disappear) posting IMS failures?
alex yates
PostPosted: Fri Mar 11, 2016 8:59 pm    Post subject: Reply with quote
Links please Smile
996lee
PostPosted: Fri Mar 11, 2016 9:28 pm    Post subject: Reply with quote
There is a guy on the 997 forum on a bore scoring poll that says his ims failed alex
2001 Carrera 4 aero all the way!!
Chris_in_the_UK
Estoril
PostPosted: Fri Mar 11, 2016 10:03 pm    Post subject: Reply with quote
Cannot find the thread- any link?
EDIT - found it.
Did this ever get confirmed as a bearing failure - there was suggestions of a chain jump or shaft failure.
Either way it's bad news!.
2006 Cayman S PCCB's
alex yates
PostPosted: Fri Mar 11, 2016 11:16 pm    Post subject: Reply with quote
So is that 2 997s vs. 0 996s?
Harv
PostPosted: Sat Mar 12, 2016 8:08 am    Post subject: Reply with quote
[quote="Halcyon"]Are we still waiting for the diagnosis on this one?
Yes still waiting for an update on what has caused that.
I think so far I'm the only one who changed the bearing because play was found upon inspection.
Eldavo
PostPosted: Sat Mar 12, 2016 8:42 am    Post subject: Reply with quote
Is there any similar data for the 987 Boxsters?
Specifically the 2.7 earlier cars with the single row bearing.
Asking for a mate obviously Wink
944 Turbo S - definitely not standard (his)
987 Boxster 2.7 - standard for now (hers)
996 3.6 Coupe - tastefully tweaked
alex yates
PostPosted: Thu May 26, 2016 5:39 pm    Post subject: Reply with quote
Data collected so far for 102 cars (26th May 2016).
Still no 996 failures since July 2014. A couple of 997 failures in the last 6 months.
Here's a couple of bar charts showing which engines and models have sustained a failure:
Total number of failures - 5.88% (Not including the LN as a original failure)
of which 3.4 - 0% and 3.6 - 8%
of which all Anniversary, X51 & C4 - 0%, C2 - 8.7% and C4S - 9.5%
4b4
PostPosted: Thu May 26, 2016 8:42 pm    Post subject: Reply with quote
No problems showing with mine at the moment Alex, but the C4S statistics are seriously worrying!
Do you think this is a reflection of more replies, or more of the C4S's being Tiptronic or what?
Is there a percentage correlation between manuals vs Tips?
Not getting paranoid, promise!
2004 996.2 C4S Cabrio Tip in Arctic Silver
alex yates
PostPosted: Thu May 26, 2016 8:49 pm    Post subject: Reply with quote
A few of us came to the conclusion that the failures all happened around the time Porsche went to the 24k/2-year service intervals, and although this not being the culprit of the bearing failing (the culprit being the bearing itself not being borderline strong enough) may have played a major part in the failures. Dont know
trig_112
PostPosted: Thu May 26, 2016 9:37 pm    Post subject: Reply with quote
I don't think I have ever offered up the info on my car. 2004 996.2, 3.6 manual C2.
No documented failure or engine change. Up to 72k miles at the minute.
There is an invoice for a IMS replacement at 65k miles by Autofarm, using a part number 106-08.2IMSR6569. I'm not sure exactly what that is, the cost for the part on the invoice in £460.50 if that helps suss it out.
Oil changes:
17k
21k
32k
36k
52k
65k
72k
Garage:
2004 996.2 C2
2008 Alfa Spider
2016 Evoque
1987 Escort RS Turbo
Countless spares and push bikes
Past Porsche: 1983 924
alex yates
PostPosted: Sat Dec 01, 2018 11:57 am    Post subject: Reply with quote
3.5 YEAR REVIEW
Data collected so far for 132 cars (1st December 2018).
Still no 996 failures since July 2014 apart from 1 member with a 3.6 who won't enter his data so I'm unable to include it in the results.
Total number of failures - 4.5% (Not including the LN as a original failure)
of which 3.4 - 0% and 3.6 - 6.7%
of which all Anniversary, X51 & C4 - 0%, C2 - 5.9% and C4S - 9.1%
Ghianightmare
PostPosted: Sat Dec 01, 2018 5:08 pm    Post subject: Reply with quote
Hi Alex,
The PO of my car (VXBANDIT on this forum) suffered a dropped valve seat at 110k miles. Not sure if you want to include that as a non failing IMS... As it had a full rebuild I’m not expecting there to be an issue in my ownership if I look after it and change oil regularly.
The car had done a lot of motorway mileage in its life - about 50k in a specific 18 month period and was regularly serviced - which based on everything I read would mean the bearing was in an optimal environment.
Just some more info for you in case it is useful.
2002 Seal Grey C4S
alex yates
PostPosted: Sat Dec 01, 2018 5:12 pm    Post subject: Reply with quote
thumbsup
rdodger
PostPosted: Sat Dec 01, 2018 5:22 pm    Post subject: Reply with quote
Is this bearing failure or all bearing replacement failed or not?
Locosaki
PostPosted: Sat Dec 01, 2018 5:24 pm    Post subject: Reply with quote
Mine was on 149k when it developed problems, non ims related though it was lack of oil pressure at idle for me
Carrera 4 MY99 with full Hartech rebuild
Goto page Previous  1, 2, 3, 4, 5  Next
Page 3 of 5
