997 : 2004- 76
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
PostPosted: Tue Apr 28, 2015 7:27 pm    Post subject: Reply with quote
Data collected so far for 72 cars (28th April 2015).
Here's a couple of bar charts showing which engines and models have sustained a failure:
Total number of failures - 8.3% (Not including the LN as a original failure)
of which 3.4 - 0% and 3.6 - 11.3%
of which all X51 - 0%, C2 - 11.8% and C4S - 13.3%
Last reported failure was July 2014 (not including the LN failure).
I'm starting to wonder if the reported failures are anything to do with Porsche moving to a 2 year/20,000 mile service plan around the same time they were registered Dont know
GT4
Nordschleife
Nordschleife
PostPosted: Tue Apr 28, 2015 9:59 pm    Post subject: Reply with quote
Clean oil and proper levels contribute to mitigate IMS failures, so that is not a bad hypothesis.
jm24
PostPosted: Tue Apr 28, 2015 11:35 pm    Post subject: Reply with quote
Agree two year intervals are likely to be a contributing factor, but find it unlikely that all those cars which had IMS failure wouldn't have if they'd had more regular oil changes.. I reckon a fair few 04 owners still go for annual servicing anyway.
Midnight blue '04 C4S
PostPosted: Wed Apr 29, 2015 6:08 am    Post subject: Reply with quote
For what an oil change costs it's a no brainer (price of filling a tank of fuel). Why risk the cost of an engine failure Dont know
Chris_in_the_UK
Estoril
PostPosted: Wed Apr 29, 2015 7:25 am    Post subject: Reply with quote
You are contradicting yourself?
2006 Cayman S PCCB's
jm24
PostPosted: Wed Apr 29, 2015 5:11 pm    Post subject: Reply with quote
I simply meant that of those 2004 cars that did switch to bi-annual servicing and had IMS failure, the less frequent oil changes were still only a contributory factor. I.e its an inherent design fault (albeit over hyped) for which oil change frequency can influence the risk of failure.
It would be interesting to know the service intervals of those 2004 models that have failed to see what proportion had annual/bi-annual servicing Question If they all had the bi-annual servicing it would certainly give more credence to the hypothesis
Shurv
PostPosted: Thu Apr 30, 2015 3:23 pm    Post subject: Reply with quote
It is interesting to see how many bearings were replaced and noted to be perfectly sound. I've been reading an interesting thread on Rennlist where the Merkins seem to fanatically replace the IMS as the stateside 996 engine guru states it is essential to do so. They are investigating a failure of the ceramic bearing solution which has lunched an engine. Our own 996 engine guru (Baz Hart) doesn't advocate changing is essential, even though he has a solution himself. It'd be interesting if the ceramic solution turns out to be as risky as the original Porsche design.
It is also interesting to note that the majority of failures are with cars serviced every 2 years.
Great work Alex, the bore score one will be even more interesting, but, can we pick up whether manual or tip? Thumb
996 C4S Arctic Silver Black leather
jm24
PostPosted: Thu Apr 30, 2015 7:13 pm    Post subject: Reply with quote
But we don't know that the majority of cars were serviced every two years do we? We know the majority had 2 year service schedules, but theoretically could have all had annual services in this sample..
Chris_in_the_UK
Estoril
PostPosted: Thu Apr 30, 2015 7:57 pm    Post subject: Reply with quote
Which, again given your earlier contradiction may be largely irrelevant.
jm24
PostPosted: Thu Apr 30, 2015 11:54 pm    Post subject: Reply with quote
I don't see any contradiction and went on to explain what I was getting at. Feel free to explain what you specifically see as contradictory, but I'd just like to have as much understanding of the contribution of oil change frequency to IMS failure as possible.
Unless we know how many of the failed 04 cars were serviced bi-annually, we are making assumptions about the extent to which oil change can/does influence IMS failure. Perhaps they were all bi-annually serviced in which case it would look like a very significant factor. If though say half still had annual servicing, then its a somewhat different story. I'd just like to have as informed idea as possible.
911munKy
PostPosted: Fri May 01, 2015 7:11 am    Post subject: Reply with quote
JM24,
I think there may be some confusion over 'bi-annual'.
Bi-annual = Occuring twice in a year, I believe you are referring to servicing every 2 years/20,000m having an impact on IMSB longevity.
jm24
PostPosted: Fri May 01, 2015 10:21 am    Post subject: Reply with quote
911munKy wrote:
JM24,
Thanks 911Munky, technically that's right, although it is often used both ways.. not helpful though so will avoid it for service interval related discussions!
PostPosted: Thu Jun 25, 2015 2:13 pm    Post subject: Reply with quote
Data collected so far for 77 cars (25th June 2015).
Total number of failures - 7.8% (Not including the LN as a original failure)
of which 3.4 - 0% and 3.6 - 10.9%
of which all X51 - 0%, C2 - 10.5% and C4S - 12.9%
[/quote]
PostPosted: Fri Oct 09, 2015 8:40 am    Post subject: Reply with quote
Data collected so far for 87 cars (9th October 2015).
Total number of failures - 6.9% (Not including the LN as an original failure)
of which 3.4 - 0% and 3.6 - 9.4%
of which all X51 - 0%, C2 - 9.5% and C4S - 11.1%
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Oct 09, 2015 9:26 am    Post subject: Reply with quote
It would be interesting to invite Boxster/Cayman owners to contribute too- presumably they share the same IMS bearing.
Are we brave enough to start a Bore Scoring survey for Alex to run his spreadsheet magic?
We could update our original posts with bore scoring yes/no.
PostPosted: Fri Oct 09, 2015 9:42 am    Post subject: Reply with quote
I was planning on doing a bore score thread but think that should be kept separate. Only thing not motivating me to do it is the fact I don't have a 3.6 Wink
PostPosted: Tue Mar 08, 2016 10:27 am    Post subject: Reply with quote
12 Month Review
Data collected so far for 92 cars (8th March 2016).
Total number of failures - 6.52% (Not including the LN as an original failure)
of which 3.4 - 0% and 3.6 - 9.1%
of which all X51 & C4 - 0%, C2 - 9.1% and C4S - 11.1%
Last reported failure on a 996 was July 2014 (not including the LN failure).
Niall996
PostPosted: Tue Mar 08, 2016 11:30 am    Post subject: Reply with quote
I'd love to see the correlation between 'failures' and 'first time posters' on 911uk as well. Could be my imagination but it often seems to be someone who never posted before or who posted minimally who suddenly pops up on a Porsche forum with IMS issues. And then quietly vanishes a short while thereafter. Along with their car, their story, the outcome etc.
Costelles
PostPosted: Thu Mar 10, 2016 7:08 am    Post subject: Engine failure Reply with quote
My 2002 Targa had a new engine from Porsche in late 2011, reason was cracked cylinder #6
54k miles at the time
Shurv
PostPosted: Thu Mar 10, 2016 4:29 pm    Post subject: Reply with quote
It also looks like the later the car, the more it fails. Could this be something to do with the 2 year service intervals being brought in?.
Goto page Previous  1, 2, 3, 4, 5  Next
Page 2 of 5
