997 : 2004- 70
Boxster : 1997- 22
Cayman : 2005- 15
LaSource
PostPosted: Thu May 21, 2015 12:59 pm    Post subject: Reply with quote
freddie44 wrote:
Is there a final "shoot out" chart comparing supposed factory BHP with actual BHP on the day?
Wow Thumb
The results are all mentioned earlier in the thread...but we could do a clearer model by model chart...
997 GT3 RS 3.8 Grey/Red
996 GT3 Mk2 Clubsport Guards Red
KTM XBOW RR Superlight Spec
BMW E39 M5, BMW E46 M3
Land Rover Discovery 4 HSE
Previous:
981 GT4 3.8 Clubsport
2x 997 GT3 RS 4.0 White and White
2x 997 GT3 RS 3.8 RHD and LHD
2x 996 GT3 RS Blue and Red
2x 996 GT3 Mk2 Clubsport and Comfort
LaSource
PostPosted: Thu May 21, 2015 1:04 pm    Post subject: Reply with quote
harveyn wrote:
My 997.2 GT3 was slightly down on power. I normally use Shell V Power, but had BP super unleaded in there on the day. Not sure if that explains it.
Personally I very much doubt that a brand X 97 RON is significantly lower than Shell VPower (Which IIRC is 99 RON).
As an example my 996 GT3 and Shakman's 996 GT3 both had 97 RON fuel from Esso in it (left over post the previous Silverstone trip) and both cars posted a very healthy 396hp and 399hp respectively. We were lamenting not having Shell VP beforehand.
I suspect there is more to it than that which could be - tyres, tyre pressure, state of rear diff, cam sensors, some contribution from fuel brand, etc
Previous:
Roro
PostPosted: Mon Dec 19, 2016 8:22 pm    Post subject: Reply with quote
Little thread resurrection... Very Happy
My car made 399.9 last year, and today I popped back in to SRR. I was interested to know whether there was something in the air that day which is why my car didn't achieve the 415 it's supposed to make (although in Evo magazine they state the output as 410, not sure why)
Pleased to report my car produced 409.9 on the dyno today
Not sure how to explain the improved figures though. All I've done is a major service since the original dyno last year, so maybe new spark plugs (Charlie's initial thought...). Actually that would be 2 services - one major last June after the dyno run, and then a minor in June this year. The car is otherwise exactly the same with the H&S bypass being the only engine-related mod. Only other difference is the increased mileage (an extra 3 or 4K now maybe, not been using the car much over the last year or so)
2007 997.1 GT3
2017 F87 M2
Cunno
PostPosted: Mon Dec 19, 2016 8:26 pm    Post subject: Reply with quote
Cars like cold air
Porsche is for driving not for washing.
Present Car: 2006 3.6 Porsche GT3 997(White)
Ex: 2006 3.4 Porsche Cayman S (Silver)
Ex: 2001 2.7 Porsche Boxster (Seal Grey)
Roro
PostPosted: Mon Dec 19, 2016 9:48 pm    Post subject: Reply with quote
Well that's that then Judge
2007 997.1 GT3
2017 F87 M2
LaSource
PostPosted: Tue Dec 20, 2016 2:51 am    Post subject: Reply with quote
Yep. Suspect it would be all of the above.
IE new plugs, loser engine with the mileage, potentially higher Ron fuel, different tyres(?), and most of all colder temps. Although Charlie will compensate for colder ambient, some contribution will still seep through.
So basically your car is now putting out same power as my standard 6RS Cool
Previous:
Roro
PostPosted: Tue Dec 20, 2016 11:12 am    Post subject: Reply with quote
Actually yes good point re colder air. Indeed it was colder outside, but Charlie did close the doors and put the fan on, I presume (now) partly in an attempt to replicate the conditions of the previous test which was saved on his systems. So maybe it wasn't much colder than the previous test after all. Also tyres were the same (I thought they were different but I checked and they're the same MPSS I used last time)
2007 997.1 GT3
2017 F87 M2
Richyd
Watkins Glen
PostPosted: Tue Dec 20, 2016 11:25 am    Post subject: Reply with quote
A good dyno (and I'm sure SRR's will be a good one) will produce an adjusted power figure, taking into account air temp and atmospheric pressure, which changes day to day as well.
For example, my GT4 (after some mods) was dyno'd in Germany last month at 425bhp, which was adjusted to 415bhp. Apparently, the German standard is to give a power figure at sea level and 20 degrees (or something like that). It was a very cold day when I was having the work done, 3 degrees or something like that.
This was at Germany's biggest Maha installation. Really slick operation where they took a mate and I through how the RR works, how they adjust for transmission loss, tyre slippage, all sorts of things. Made me realise how inaccurate some (most) RR's are. For example, the RR we used is calibrated by Maha every 3 months.
Out of interest, my mate had a full tank of 105 octane, mine was 2/3rds 105, 1/3rd 97. My friend has a Akrapovic exhaust fitted, mine has a standard exhaust. The baseline reading for both cars was within 1bhp of each other (399bhp). After a little work though, his was an adjusted 425, mine was 415.
The engineers reconed the difference was a combination of the fuel quality and the Akrapovic....
At Spa the next day, running identical fuel, there was literally nothing between the cars on the Kemmel straight.
1997 993 C2S
2018 Macan GTS
ex - 2018 991.2 GTS
ex - 2016 GT4
ex - 2015 Macan S
ex - 2009 997.2 GT3 CS
ex - 2006 997.1 GT3
ex - 1997 993 Carrera 4
ex - 2006 987 Boxster S
Disco
Estoril
2010 Porsche 997 GT3
PostPosted: Tue Dec 20, 2016 6:26 pm    Post subject: Reply with quote
The air of late hasn't just been cold, but also damp and that has an effect on the charge going into the engine too.
Colin
Black 997 GT3 3.8 CS - Acquired for the 2012 season and beyond
Black 996 GT3 Mk2 - Gone, but will never be forgotten
kingston
PostPosted: Wed Dec 21, 2016 10:02 pm    Post subject: Reply with quote
So what your saying is that Roro's cars still broken?
Ive got the vod footage somewhere showing Roros lil face seeing the dyno read out Evil or Very Mad
I really must learn to spell check and proof read my posts Smile
Roro
PostPosted: Wed Dec 21, 2016 11:14 pm    Post subject: Reply with quote
I'm happy with my new dyno readings Cool
2007 997.1 GT3
2017 F87 M2
Y2K
PostPosted: Mon Sep 17, 2018 5:19 pm    Post subject: Reply with quote
Booked mine in at SRR on Sat 29th Sept.
Anyone else interested?
2005 996 GT3 mk2
1999 Integra DC2
LaSource
PostPosted: Mon Sep 17, 2018 7:20 pm    Post subject: Reply with quote
Hmm I do need to visit Charlie with the XBow plus take a friend with a manthey 996 GT3
Previous:
Y2K
PostPosted: Mon Sep 17, 2018 7:42 pm    Post subject: Reply with quote
11:30 & 11:45 for mine and my friend’s slots. Thumb
2005 996 GT3 mk2
1999 Integra DC2
Y2K
PostPosted: Wed Oct 10, 2018 6:32 am    Post subject: Reply with quote
Open Youtube Page
Standard engine, with 2/3 Esso and 1/3 V-Power
403.3 bhp & 314 lb/ft
2005 996 GT3 mk2
1999 Integra DC2
LaSource
PostPosted: Wed Oct 10, 2018 6:44 am    Post subject: Reply with quote
Yep - healthy engine. Same as what mine would get.
996's are punchy.
Previous:
Y2K
PostPosted: Wed Oct 10, 2018 7:41 am    Post subject: Reply with quote
Yeah very consistent with other mk2s. Thumb
2005 996 GT3 mk2
1999 Integra DC2
Goto page Previous  1, 2, 3, 4, 5, 6
Page 6 of 6
