997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 21
Cayenne : 2003- 4
timm996
PostPosted: Sat Dec 15, 2018 9:23 am    Post subject: Reply with quote
a brand spanking new Bosch ABS sensor, 50£ from ebay. It solved my abs light coming on after a mile. Mind you it did take me an hour to get the old one out, using chisel, drill, screwdriver, pliers. Interesting before, the sensor measured ok in resistance, 1600 ohms like the other three and connectors etc free from corrosion and toothed wheel in good condition, so no idea why it threw up an error. Made my day.
Kingb4
PostPosted: Sat Dec 15, 2018 10:21 am    Post subject: Reply with quote
Have treated the car to a service at the Porsche dealership in January. Found an OPC that will offer the classic service price - so only £310 and you get a courtesy car for the day.....was originally planning to service it myself, but decided it was worth keeping the FSH.
In preparation for the service have bought a Millers oil-analysis kit (so will get a sample before they change the oil). Have also bought a magnetic sump plug, which I will ask them to fit, when they change the oil....
2002 996.2 C2 Cabriolet
jockmog
PostPosted: Sat Dec 15, 2018 12:22 pm    Post subject: What did you buy your 996 this week? Reply with quote
A new clutch, flywheel and an EPS positively lubricated IMS bearing and, hopefully some peace of mind! Sleepy Happy
Dammit
Watkins Glen
PostPosted: Sat Dec 15, 2018 12:36 pm    Post subject: Reply with quote
Full set of winter wheels for the 996 part-fetcher.
Biovox
PostPosted: Tue Dec 18, 2018 7:01 pm    Post subject: Reply with quote
Rear wiper delete plug in Dark Olive Metallic from Alloy & Carbon, new light switch (lost licence plate lights and cluster illumination, A5 fuse OK) and some lovely new matt black with gold crest wheel centres from Maxspeed. Just need some nice weather to fit 'em Cool
996ttS (modified)
ex. 993 Carrera 2 (modified)
ex. 964 Turbo 3.3
bakerboy4s
PostPosted: Tue Dec 18, 2018 7:27 pm    Post subject: Reply with quote
Rear pu sprayed, looks way better
PostPosted: Tue Dec 18, 2018 7:50 pm    Post subject: Reply with quote
Is that all you have done in 13 years Dont know
Biovox
PostPosted: Wed Dec 19, 2018 10:00 pm    Post subject: Reply with quote
No, but it's all I can afford this week after last month's treat Very Happy
996ttS (modified)
ex. 964 Turbo 3.3
 Filesize:  178.15 KB
 Viewed:  1525 Time(s)
NedHan79
PostPosted: Wed Dec 19, 2018 10:06 pm    Post subject: Reply with quote
After seeing this, I bought myself a rear wiper delete. First step to loosing weight. Then it’s the New Years resolution to loose a few lbs myself to make me the quickest about Floor
PostPosted: Thu Dec 20, 2018 1:10 am    Post subject: Reply with quote
Enough said Judge
worship
Pickse
PostPosted: Sat Dec 22, 2018 2:05 pm    Post subject: Reply with quote
Amp Hound 2 from Cal-Van tools in the USA on ebay for £68.
The same company sells them on Amazon UK for £168. Hopefully import duty etc will be less than £100?
Fuel Filler Cap, seal was split
Front Lid Actuator;
It had become intermittent and fortunately failed open.
Upon removal I found the old one full of water Surprised
I'm now wondering if it might also be the cause of my intermittent flat battery problem. We'll see.
Next question is where the water's coming from..... Question
Pickse
2003 Arctic Silver 996 Turbo Tiptronic S
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sat Dec 22, 2018 3:03 pm    Post subject: Reply with quote
I bought 240l of 107 octane race fuel for my turbo Bandit
911tom
Watkins Glen
PostPosted: Sun Dec 23, 2018 5:43 am    Post subject: Reply with quote
Very nice! Judging by the rear badge it is clearly not standard... What is it running then?
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
718 Cayman GTS
350Bhp astra van for work, semi-retired from daily duties
2009 Ariel Atom 3 Supercharged SOLD but never forgotten
911tom
Watkins Glen
PostPosted: Sun Dec 23, 2018 5:45 am    Post subject: Reply with quote
Well worth keeping the service history up as you say. Hopefully you'll get a decent courtesy car. I got a macan S last time the family car went in. That alone makes it worth going to OPC IMO.
2011 Cayenne
718 Cayman GTS
thecarfixer
PostPosted: Sun Dec 23, 2018 5:21 pm    Post subject: Reply with quote
I bought a mega pile of bits:
AOS (being the tit I am I seemed to have ordered the 996.2 type though, so I'll have to return that)
Breather hoses that clip onto the AOS as both appear to have cracks and are oil misting at the AOS.
Cam chain tensioners - it's an original '98 engine that's been unopened, and the tensioners have gone through several revisions so seemed sensible to change
Drivebelt pullies - 997 plastic type as they're lighter, mine whine like mad, I could have just got bearings but every little weight saving helps
Alt>Starter>Battery post wire
Engine>body earth strap - as mine looks ancient
Battery>body earth strap - as the last time I had the battery off, it didn't look amazing
Various plenum seals/o rings - as I'll be having it all apart to clean up anyway.
Variocam solenoid caps - as mine leak
Replacement alternator - my charge current/voltage is rather low
The usual filters - ready for a service at the same time
So it'll be a big old job in the new year! I'm weighing up whether dropping the engine to get to the AOS might outweigh the time taken to operate through the engine lid opening to remove the plenums etc..
Biovox
PostPosted: Mon Dec 24, 2018 4:59 pm    Post subject: Reply with quote
Some makeup for the old girl Smile GTechniq Glass Care Kit - after removing the rear wiper and adding the delete bung (decent match given the original colour LM6X), ~30 minute job - I thought I'd just have some rain repellent insurance! 3 coats of G1 on the windscreen, 2 on the rear screen and 1 on the side windows. The 15ml bottles are good for 1 car
911tom - it's essentially the 9e35 package with rebuilt standard K24s plus uprated Do88 ICs. Kens calculated ~500RWHP with 18% transmission loss so that would suggest ~590BHP. Certainly feels it and very pleased with the results, sound is intoxicating Very Happy
996ttS (modified)
ex. 964 Turbo 3.3
Alloy+Carbon rear wiper delete bung
 Filesize:  139.54 KB
 Viewed:  1193 Time(s)
FRP
PostPosted: Mon Dec 24, 2018 5:31 pm    Post subject: Reply with quote
Hi Biovox. Sounds awesome. Congrats
2002 996tt x50 manual in bassat black - 9eXX
Mat138l
PostPosted: Mon Dec 24, 2018 6:00 pm    Post subject: Reply with quote
A pair of Porsche dealer plates as mine had other dealer plates on and bought some H&R 30mm lowering springs.
NedHan79
PostPosted: Mon Dec 24, 2018 6:15 pm    Post subject: Reply with quote
Where’s best place for springs?
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Wed Jan 09, 2019 10:18 pm    Post subject: Reply with quote
Three small bearings ready for yet another job that has cropped up Mad
Goto page Previous  1, 2, 3 ... 88, 89, 90, 91  Next
Page 89 of 91
