997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
Stoo.c
PostPosted: Wed Nov 01, 2017 2:43 pm    Post subject: Reply with quote
In which case that's a great price. I'm about to fit my Top Gear exhaust and cats and fully expect the existing sensors to be completely seized in.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
The Lone Ranger
PostPosted: Wed Nov 01, 2017 5:17 pm    Post subject: exhaust change. Reply with quote
When my exhaust and cats were changed I bought new 02 sensors to make the job easier. Removing old ones can be a nightmare, and can break. Thumb
Harv
PostPosted: Wed Nov 01, 2017 5:32 pm    Post subject: Reply with quote
I'd simply change the pre cat sensors but maybe try and save the post cat ones if you can, their function isn't important providing they work.
galahad
PostPosted: Thu Nov 02, 2017 3:36 pm    Post subject: Reply with quote
Stoo.c wrote:
Top gear silencers and 200 cell cats arrived yesterday - very pleased and looking forward to finally getting them fitted.
X-pipe Cats or regular?
2003 C4S Black/Black Manual
BChivs
PostPosted: Thu Nov 02, 2017 8:23 pm    Post subject: Reply with quote
Had a little blow out this week.....I've bought -
Dr Colourchip Kit
Ctek 3.8
Genuine Porsche Fitted indoor cover
Brembo front/rear discs and pads
Braided hoses
OPC top mounts
Front bottom/coffin arms
Front & rear drop links
RUF lowering springs
Low temp thermostat
6 x coil packs
Drive belt
FRP
PostPosted: Thu Nov 02, 2017 8:32 pm    Post subject: Reply with quote
jebesus BChivs,,,,,some list, you must have been flush !!!
2002 996tt x50 manual in bassat black - 9eXX
Diablos-666
PostPosted: Thu Nov 02, 2017 10:42 pm    Post subject: Reply with quote
Where did you get the RUF lowering springs from?
Stoo.c
PostPosted: Fri Nov 03, 2017 11:13 am    Post subject: Reply with quote
Just regular. I need to replace the silencers as they are split anyway so decided to change the cats for a small performance gain and a bit of future proofing anyway but without spending too much.
I will try and get my existing sensors out as I have the correct sensor sockets but even so it may well be a challenge. Will probably get the new pre cat ones as a minimum anyway.
02 996 C4S
91 CRX vtec turbo
01 986 Boxster S
Harv
PostPosted: Fri Nov 03, 2017 11:43 am    Post subject: Reply with quote
Today's bargain seems to be crank position sensors, easy to swap and you'll not be stranded by the side of the road when the existing 15year old plus item goes open circuit
https://m.ebay.co.uk/itm/PORSCHE-CAYMAN-2-7-RPM-Crankshaft-Sensor-06-to-09-M97-20-Crank-Flywheel-Speed/332408063517?hash=item4d6510861d:g:KQ8AAOSwhwBZ3QJ6
crash7
PostPosted: Fri Nov 03, 2017 11:58 am    Post subject: Reply with quote
Suspension Upgrade
JRZ Cup Dampers with Cup monoball top mounts F&R
GT3 F&R Anti-roll bars (Powerflex Bushes)
Cup Rear Toe Links
Cup LCA's F&R
Cup Droplinks Front
Adjustable Droplinks Rear (Cup rears are non adjustable)
Tuning Fork Arms.
Now to get it all fitted!
BChivs
PostPosted: Fri Nov 03, 2017 12:59 pm    Post subject: Reply with quote
I Ordered them direct from RUF Germany....only a few days to arrive. £350ish delivered Thumb
Ex 996C4S, manual, Polar Silver - Gone to the dogs!
Y2K
PostPosted: Fri Nov 03, 2017 1:16 pm    Post subject: Reply with quote
crash7 wrote:
Suspension Upgrade
Cup Rear Toe Links
Cup LCA's F&R
Cup Droplinks Front
Tuning Fork Arms.
Tasty Cool
2005 996 GT3 mk2
1999 Integra DC2
Diablos-666
PostPosted: Sat Nov 04, 2017 12:32 pm    Post subject: Reply with quote
Is this the part number you ordered:
SKU: R96 300 333 10
Thinking about getting some rather than the H&R ones. I did order a PSS9 coilover kit but was told it was on back order and wouldn’t be delivered until Dec/Jan. Now thinking I’ll just get the lowering springs instead.
Dammit
Watkins Glen
PostPosted: Sat Nov 04, 2017 1:58 pm    Post subject: Reply with quote
I have a set of four Ohlins springs - the ones that come with the Ohlins R/T shocks - which came out of their box for me to take a photograph and then went back in again.
They're on a shelf in my garage and will likely remain there for the rest of time unless anyone wants them, or I finally get round to eBaying them.
Give me a shout if you want them.
Scully
PostPosted: Sat Nov 04, 2017 2:23 pm    Post subject: Reply with quote
As I've not got a garage to keep the car (I do have one, but it's not big enough) I've just bought an outdoor Carcoon cover for the worst of the winter months. Very impressed in tests so far. Although the fans are very low power, the bubble inflates to a surprisingly solid pressure.
Dave
Stoo.c
PostPosted: Thu Nov 09, 2017 4:52 pm    Post subject: Reply with quote
4 new sensors ordered - they were seized solid. Decided to swap the engine mounts at the same time. One of them was doing next to nothing - it's only function was stopping the engine from dropping out. Looking forward to drive it again with new silencers, new cats, new O2's, new rear mounts and gearbox mount insert.
02 996 C4S
91 CRX vtec turbo
01 986 Boxster S
JS1500
PostPosted: Thu Nov 09, 2017 6:35 pm    Post subject: Reply with quote
OEM spec water pump and gasket
Wahler low temp thermostat kit
6x Bosch plugs
2x HAAS coilpacks
From ECP with a discount code. Was £400, now £240 all in.
Edit: anyone used the HAAS coilpacks before? Thought they'd be worth a punt.
2000 996 C4 - Guards Red
BChivs
PostPosted: Thu Nov 09, 2017 6:43 pm    Post subject: Reply with quote
SKU: R96 300 333 10
I'm not sure on part numbers.....I just emailed and they were really helpful. Even gave vlub discount!👍🏻 H&R looked too low for me so opted for these.
Just bought myself some replacement gas bonnet struts and replacement centre caps.
thecarfixer
PostPosted: Thu Nov 09, 2017 7:24 pm    Post subject: Reply with quote
Six coil packs, longer bolts and some NGK iridium plugs as I dropped a coil last night and now have a five cylinder 996 with a flashing CEL.
Car got jealous with me rebuilding a motorbike for commuter usage, clearly!
Diablos-666
PostPosted: Fri Nov 10, 2017 5:12 pm    Post subject: Reply with quote
I’ve just got some RS Engine Mounts and RUF lowering springs. I did order the pss9 coilover kit but was told delivery would be in Jan so bought the springs instead.
I did send an enquiry to RUF about a set of their wheels but it seems their wheels are now forged and the cost is about £5k! 😳
Goto page Previous  1, 2, 3 ... 76, 77, 78 ... 89, 90, 91  Next
Page 77 of 91
