997 : 2004- 71
996 : 1997-2005 48
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 15
Cayenne : 2003- 9
Macan : 2014- 1
912-914-924-928-944-968 3
Stoo.c
PostPosted: Tue May 09, 2017 3:16 pm    Post subject: Reply with quote
Stoo.c wrote:
Just ordered brand new 997 C4S OEM Porsche front top mounts to fit to the 996 along with new front ARB bushes (changed the droplinks a few weeks ago) and Goodridge braided brake lines as I have already bought all the caliper hard lines from Porsche (old ones getting crusty).
Design911 sent the wrong ARB bushes - standard ones and not C4S ones Mad
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
clinchy993
PostPosted: Thu May 11, 2017 5:00 pm    Post subject: Reply with quote
From ebay Poland nice low cost improvement
Osh
PostPosted: Fri May 12, 2017 6:58 am    Post subject: Reply with quote
Clinchy - how much did they set ya back m8...??
Osh
clinchy993
PostPosted: Fri May 12, 2017 4:39 pm    Post subject: Reply with quote
Osh
£35 ish on ebay ,arrived within a few days
Osh
PostPosted: Sat May 13, 2017 1:57 pm    Post subject: Reply with quote
clinchy993 wrote:
Osh
take m8 Thumb
chriscoates81
PostPosted: Sat May 13, 2017 4:57 pm    Post subject: Reply with quote
Are those just clip on rings then? I've ordered a water pipe and some o-rings for the pipe. For those interested it's got a bung in it that's almost corroded thru, it's about middle of the car left to right when viewed from the back and maybe a foot under. It's worth check on turbos/gt2/3's (not such if carrera have thus pipe). In a week or 2 I will be ordering front top mounts and the long air-con pipes.
Old:1999 Carrera 2 3.4 in ocean blue with a savanna interior.
New:2002 Turbo in silver with black interior - the smile machine
msaif996
PostPosted: Sun May 14, 2017 1:37 am    Post subject: Reply with quote
New front OEM speakers. PSE switch fixed. Gearbox mount (the local OPC out here is wonderful. They advised me to buy the part from eBay as the entire unit would be 10x more).
clinchy993
PostPosted: Mon May 15, 2017 10:24 am    Post subject: Reply with quote
Dial rigs are push fit and grip well 👍
Paz
1998 Porsche 996 Carrera 2
PostPosted: Sat May 20, 2017 6:32 pm    Post subject: Reply with quote
Three months ago I had M030 suspension kit fitted to replace the factory fitted M030 kit (122,000 miles), installed by Pete at Center Gravity and setup just as I like it.
A month ago EMC Motorsport fitted new Brembo front discs & pads after the Sebro/Textar combo were past their best after 17,000 miles (perfectly worn pads so the calipers are working fine!). The Brembo setup is a huge improvement over the OE items.
Today they also fitted a lightweight flywheel, she now sounds like an RS with the gearbox chatter, it's still quite refined in the cabin but standing outside with the engine at idle it sounds quite racy!
Nightrain QDUN4
PostPosted: Sat May 27, 2017 5:35 am    Post subject: CV Reply with quote
Just fitted new front inner and outer cv boots, front coffin arms and control fork arms.
The grease in the front axels was definitely due replacing..very runny, 84k probably never been touched since new.
2004 C4S
2003 C4S
TimMiles0011
PostPosted: Thu Jun 01, 2017 1:38 pm    Post subject: Reply with quote
I bought the OPT7 type H7 LED headlights to replace my halogen low beams on my 996.2 which has projector-type headlights for the low beams.
https://www.bestadvisor.com/led-fog-lights
I had to cut open the seal rear of the sealed headlight assembly to allow cooling of the LEDs, which poses a reliability risk if it gets wet inside. The OPT7 LEDs are much much brighter and whiter than the stock tungsten bulbs!
deckster
PostPosted: Tue Jun 13, 2017 5:25 pm    Post subject: Reply with quote
Finally, finally sorted out the ABS pulsing that was happening under low-speed braking. Big shout to Paul at Northway who worked out that it was a split, well, something on the front driveshaft and nothing to do with the braking system per se. Quick (!) replacement driveshaft and ***** me, braking is now weirdly smooth. Nice. And they found and (hopefully) fixed the aircon leak that's also been bugging me since I bought the car.
All in all, today was a good day Thumb
Harv
PostPosted: Wed Jun 14, 2017 6:04 am    Post subject: Reply with quote
Pair of Febi rear drop links, paid £23 inc delivery
Good old eBay Thumb
BHZ661
PostPosted: Wed Jun 14, 2017 10:47 am    Post subject: Reply with quote
New waterpump and washer pump
Saint Matt
PostPosted: Wed Jun 14, 2017 2:16 pm    Post subject: Reply with quote
A new coffin arm for the front right to stop a creak it started doing on a recent 'ring trip. £59 later, back to silent suspension travel Very Happy
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Sat Jun 17, 2017 2:58 pm    Post subject: Reply with quote
Full major service, including accessory belt, brake fluid, plugs and diff oil plus an air conditioning service from ATS.
Somewhat wierldy I am a little dissapointed that the car feels and drives exactly the same as before, I know that if everything is correct to begin with it shouldn`t make any real change once the services are completed but all the same it always feels like a slight let down to drive the car after all that work/time/money and it is no different at all Dont know
Nightrain QDUN4
PostPosted: Sat Jun 17, 2017 4:23 pm    Post subject: Reply with quote
Seal in front diff nose cone replaced, new front coffin arms. MOT'd today 13 years old no advisarys Very Happy.
2004 C4S
2003 C4S
pooga
PostPosted: Sun Jun 18, 2017 7:49 pm    Post subject: Reply with quote
Set of side stripes!
Stripe
 Filesize:  894.11 KB
 Viewed:  3634 Time(s)
911tom
PostPosted: Sun Jun 18, 2017 8:49 pm    Post subject: Reply with quote
Nice to see something different. Not Sure how much I like it personally. I bet it looks better in the flesh?
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
2009 Ariel Atom 3 Supercharged
350Bhp astra van for work Surprised
C11BRA
PostPosted: Sun Jun 18, 2017 9:03 pm    Post subject: Reply with quote
Re-furbished fuel injector rails & 1 injector. Rotted away?????
Purists, look away.
Ex Ram Cobra
Goto page Previous  1, 2, 3 ... 73, 74, 75 ... 85, 86, 87  Next
Page 74 of 87
