997 : 2004- 63
Carrera SC : 1977-1983 3
Cayman : 2005- 23
Macan : 2014- 7
Boxsey
Watkins Glen
1990 Porsche 964 Carrera 2
PostPosted: Wed Apr 01, 2015 9:08 am    Post subject: Reply with quote
At the moment it does indeed sound like the CCU. What is the part number on the it (should be on a sticker)?
Steve
Racing Yellow Cayman GT4
History of my now gone 964
ras62
PostPosted: Wed Apr 01, 2015 10:08 am    Post subject: Reply with quote
Take a look at Tore B's site under servo driver failure. http://www.bergvillfx.com/ccurepair.html
jgj
PostPosted: Wed Apr 01, 2015 8:56 pm    Post subject: Reply with quote
If or when you isolate the problem to the CCU and if all else fails, I can highly recommend Frazerpart talk to Max. I sent him up my unit with blower fan working but no temp control. I don't know what he did but he sent it back working when everyone else had failed. Obviously a fraction of the cost of a new or even a 2nd hand working one.
MarkGolf
PostPosted: Thu Apr 02, 2015 3:19 pm    Post subject: Reply with quote
Josh, I used a black primer on the damaged area, once dry, I painted on black plastidip. When near dry, I used a needle to shape out the end part of the arrow on the recirc button. Works brilliantly.
I'll find out the part number on the unit over the weekend, I had a break from trying to troubleshoot it last night... I have been on Tore's site so many times and for some reason, never seen that page!! Question Thanks, will have a good read later.
Thanks for the tip jgj.
I only had an hour on the car last night so I thought I would tackle a nice quick yet satisfying job. When I first got the, only 1 bulb was working in the centre console, now none work. I had ordered some replacement bulbs thanks to Zingari.
I set about changing the 3 bulbs which cover the Hazard, central locking and warning lamp. A 10 minute job which has really made a nice difference.
When refitting this panel, I noticed that there was a similar PCB with a bulb fitted for the rear spoiler. This also didn't work, so I quickly swapped this out.
The results, a fully lit switch panel Smile
If anyone knows where I can get hold of a trim panel for the rear spoiler unit, please let me know! I don't want to buy a whole new switch, I literally want the casing so that I can swap with mine due to someone drilling a random hole in it!
The start of the parts for the repaint were ordered today. Side skirt seals, wing/scuttle panel seals, front bumper smile seal, cabin light switch covers etc etc. All from Design911 Smile
Some new front tyres too, spent ages trying to decide what would be good for the car. Something for all round road use, the normal choice for me are Michelin PS2's but they do not offer a 16" tyre so I was a bit lost, harking back to my first days of buying tyres for small wheels, wondering if Toyo T1S's were still good... I ended up reading a fair few reviews and went for Goodyear Efficient Grip Performance's in the end. They had great reviews all round. Probably a waste of time as I will only end up fitting some bigger wheels in the end. frustrated Grin
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
Gazc2
Watkins Glen
PostPosted: Thu Apr 02, 2015 3:39 pm    Post subject: Reply with quote
If you want good service try Matt at www.type-911.co.uk for your parts
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
mrsimpson
PostPosted: Thu Apr 02, 2015 4:54 pm    Post subject: Reply with quote
Hello fellow South Londoner, I'm in Brockley, give me a shout if you fancy an early morning drive. Your car looks great, loving the thread. Stick with the D90's they look perfect, and welcome to the 964 club.
Definitely use Matt at Type911 he's a good guy and stocks genuine Porsche parts, his shop's in Beckenham.
I can also recommend Project Nine Engineering down in Marden, it's a nice drive out there, and they too are decent guys, Clifford knows his stuff.
bye
MarkGolf
PostPosted: Thu Apr 02, 2015 8:39 pm    Post subject: Reply with quote
Cheers guys. I'll be sure to check out their website later!
Up for meeting other porscheophiles!! Since the only 2 close mates with them have now sold up!
In regards to my hearing issue. I'm out with the car now and just discovered that there is NO power going to the servos and the slider controls don't seem to do anything, nothing appears to come out of those footwell vents that are hanging down from under the dash(if that's what that is)
Anything else I can check? Just to be sure, there isn't a fuse or relay in the circuit is there?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
MarkGolf
PostPosted: Thu Apr 02, 2015 11:08 pm    Post subject: Reply with quote
I have just run some continuity tests and found that I am getting nothing across the temperature sensor... Does this play a roll in the trouble I am experiencing?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
Boxsey
Watkins Glen
PostPosted: Fri Apr 03, 2015 8:32 am    Post subject: Reply with quote
Fuse number 1 (25 amp) in the main fuse box is for the heating and ventilation system. If that's good and you've still got no power to the controls I would suspect the CCU - dead, wrong one or not plugged in.
This link gives a nice overview of the whole HVAC system:
http://www.964uk.com/Documents/964%20Heating.pdf
Steve
MarkGolf
PostPosted: Thu Apr 16, 2015 11:23 am    Post subject: Reply with quote
Thanks again Boxsey. I have had a break from the HVAC problem at the moment, I believe the problem is with the unit but I have been using my time to crack on with other things. I plan to pull the HVAC out and probably send it off to someone for repair, in the meantime, I am hoping some one has a unit that I can use to test..
So, I have been keeping busy and totally distracted from everything else recently. My main goal has been to get the 964 as clean as possible, MOT'd and everything working (Minus the heating, for now)
This will be pretty picture heavy, I'll let them do the talking.
I had a cap which fits in the lock, it helps disguise it and stop it standing out so much on the black handle, I'll be getting another for the other side.
The carpet was a complete state, spent a fair while cleaning oil and various crap from it. 3 of the fasteners have been pulled off and are missing so I need to sort this out. I've seen that I need 15mm female button things.
The car is very dry underneath, infact, there doesn't appear to be any leaks apart from above the passenger side rear trailing arm. When previously looking through the invoices I have, I could see that the gearbox pipes to the oil cooler were noted as being "Heavily corroded". I worked out that these pipes looked new and obviously replaced the corroded lines.. Evidence of the leak was coming from the coupling, so I tightened the suspect line up and 1 week later, still no leak, so job done! Smile
While poking around, I discovered the car has some height adjustment!! Not much I know Sad
Are these standard fitment?
Some before shots, not as bad as I expected...
Some new brake pads, much required!
The tiptronic surround had some wear to some of the lettering, so I swapped this with the new one I had.
What a tiptronic shifter looks like.
While at it, all of these were jammed, so a good clean and grease and it works like new!
Old Vs New
My first aftermarket part for the car arrived.
A nice sound proofing tidy bar from Germany, thanks to a link seen on world 964 owners.
A bunch of other bits turned up from Design911..
Before the bar..
After
This should have been a 2minute job, but I dropped one of the clips and had to remove the heater blower to find the thing!!
Off for an MOT, passed without a single advisory!
Met an old school friend while there
New tyres being fitted
Sunday just gone, it was time to really put some time into it, jobs like painting up bolts and small details, listing out what new parts I need to buy etc.
Thorough cleaning
While under the arches, I wanted to investigate my oil level sender not working.. Pulled the sender out and gave it a clean, it still didn't work.. I had heard that these can suffer from bad earth, after running a earth from the sender itself to the chassis, I discovered that it worked!! So, I need to work out how you earth the oil tank, or how it should be earth, as earthing the sender to the oil tank did nothing. If the oil tank is earth or is the sender has it's own earth, I don't know... Any advice?
Old seal
New Seal
It now works (This was a shot after the car had been in heavy traffic)
On to the body work. I had already spent some time, mainly by hand, seeing how much work it would need... Alot and by machine was the answer.. I had taken some of the oxidation off by hand but not much and in the dark, it looked better than it did in the below pic.. Smile
Time for the body
Ready for a cutting session
And after, I am still yet to tackle the bumpers and some panels need another session but for now, it's looking presentable.
A high shot from my office, the clouds aren't helping the now non faded look
Some random interior shots, only given this a quick hoover and treated the seats to some conditioning.
No way near where I want it to be as yet, still need to polish the bumpers.
Xquisite Automotive should be taking the car in for a full repainting in June but I am hoping they can do it sooner. Smile
I have been using the car and put around 260 miles on it so far, I am really enjoying it, there is a sense of occasion everytime. I had a run on a local test track against my old E46 M3 and was totally shocked at how it didn't fall too far behind it, really impressed us both.
I love the soft, hugging seats, the chunky steering wheel and the tiptronic isn't that bad. Still not my choice but for driving in town, it's quite nice. My girlfriend loves it.
The car does feel heavy, even without a full tank of fuel, perhaps I'm used to the light steering on my MX5 and 997. It wouldn't be my choice for a track car out of the box but I'm sure some low profile tyres, suspension and manual box, it would be a different car. This car is going to stay a cruise, it's nice to pop it into D, windows down and sunroof open and listen to the sound of the engine just rumbling away, some extra noise would be nice though..
Overall, after 260 miles, I am loving this car and cannot wait to see it restored, it's been a fun experience so far and thankfully, it's a perfect solid base car. The garage I took it too for an MOT couldn't believe how good of a condition it is in, they see and even own a 964, amoungst other porsche and air cooled cars, they really commended it. worship
As she stands as of 15 mins ago
Front end high as anything! I did notice a difference in my driving position after going from an empty tank to a full one though Smile
I changed the clear silicon piping to black and I can't for the life of me, get that bloody heaterpipe into the new rubber arm above the fan!!
I have some questions...
Is it worth using V power, I have just put in my 2nd tank of it and its the fuel of choice for me, is the car setup for 95 ron or will it respond to the 98 V power?
My oil level sender, should this earth through the oil tan or does the earth go along with the feed wire and earth out on the car somewhere?
I have a gap between the carpet and bonnet pull (see above pic). It doesn't seem like I can close the gap as the air pipe behind the carpet is stopping it, is this normal or am I missing something?
How do I check my coolant level.... Floor
Upgrades wise;
Is it worth fitting a BMC/DesignTek panel filter for more noise under acceleration?
The upturned air intake pipe, does this add any benefit? I do find it crazy that the OEM pipe is pointed toward the engine..
Thanks,
Mark
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
Boxsey
Watkins Glen
PostPosted: Thu Apr 16, 2015 1:17 pm    Post subject: Reply with quote
A common problem with the ducting is that the blower motor has been replaced with the later 993 version. This has longer bushings so doesn't fit close enough for the ducting to reach. See this Rennlist article on what you have to do to fix it:
http://rennlist.com/forums/964-forum/772742-heater-duct-doesn-t-quite-reach-engine-fan-shroud.html
Steve
MarkGolf
PostPosted: Fri Apr 17, 2015 8:25 am    Post subject: Reply with quote
Thanks for the link, I'm not sure if that's my issue, I couldn't get the blower pipe into the rubber arm even when off the car, I put the rubber arm in hot water to soften it up and it just wouldn't stretch over! Question
Do you have any mods to you air intake system and do you run V power?
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
PostPosted: Fri Apr 17, 2015 9:26 am    Post subject: Reply with quote
Great work on cleaning the heat shiled to the cat Thumb What did you use?
Pity I cant do my inner arches but they're covered in that thick underproofing stuff what
The game's afoot. It's time to put a bit of (Colini) stick about......"Shall I open her up Miss Jones and show 'em a clean pair of heels?" "Do you think that's wise Mr Rigsby this is a very old car"
Boxsey
Watkins Glen
PostPosted: Fri Apr 17, 2015 12:28 pm    Post subject: Reply with quote
I'm a strong believer in keeping the engine standard so have no mods to the intake and have not 'chipped' it. The air intake pipe is angled to stop water filling the air box. The ECU was designed for 95 RON so there's no advantage in running higher octane. I've tried it and not noticed any difference. However, chipped cars (especially ones re-mapped on a rolling road) will likely have been optimized to run with higher octane.
The only engine mod I've got is a de-cat which was put on because the original cat fell apart.
Steve
paul284pt
PostPosted: Fri Apr 17, 2015 7:58 pm    Post subject: Reply with quote
Hi MarkGolf,
This thread takes me back to when I'd just purchased mine and brought it home. I can see the serious amount of hours and sheer effort you've made. Nice work Thumb
Cheers,
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
freddie44
2007 Porsche 997 GT3
PostPosted: Wed Apr 29, 2015 9:42 am    Post subject: Reply with quote
Great work Mark. Love reading all about it Thumb
New997buyer
Banned
PostPosted: Wed Apr 29, 2015 10:13 am    Post subject: Reply with quote
Cloud 9
MarkGolf
PostPosted: Wed Apr 29, 2015 4:29 pm    Post subject: Reply with quote
Cheers Zingari – I used AutoSmart G101 for initial cleaning, followed by Tardis which melts the tar spots off, a good scrub with a stiff brush and it is back to being shiny 
Thanks Paul, I have been through your build and love what you have done. I am a sucker for detailing a car, love nothing more!
Cheers Freddie, I don’t suppose you fancy a 964 and 997 for your GT3? Wink
Nothing too much has been happening, I had yet more seals and bits and pieces arrive ready for when the car has been painted, otherwise, just a couple of small jobs which needed ticking off of the list.
Calipers before
Calipers after
I had always planned to have the calipers refurbished in red when the car goes in for paint but now they are glossy, I am not so sure..
A night time drive
I was itching to get the fan out, I had always loved the idea of changing the colour of the engine fan as it gives such a big change to the appearance of the engine bay with such little effort.
Fan/Alternator removed from the car
After discovering that I needed a bearing puller, £18 and a Mcdonalds later, I was able to pull the fan off..
After alot of prep and a minor bead blasting, I was ready..
I was going to paint the fan red but I decided that it has been done and it would detract from the original look of the car which I want to go for.
[/url]
I went for a texture effect paint which I use on most rocker covers, it's durable and retains that tough look. Once baked, it forms to a nice factory looking textured finish. Brilliant stuff.
I also polished the belt things
[/url]
[/url]
[/url]
As I refrained from going red on the fan, I thought I'd add some detail to the alternator internals...
[/url]
[/url]
It was dark so no decent full on pictures as yet! Need to paint the manifold now!
Last update was a change to the peeling gauge face...
New face from Germany and an easy swap!
[/url]
[/url]
All done Smile
[/url]
Not sure what's next Dont know
Current fleet
1991 964 Carrera
2005 997 Carrera S
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
stucart
PostPosted: Thu Apr 30, 2015 10:08 pm    Post subject: Reply with quote
Love Mark's attention to detail, any car is lucky to have him as an owner worship Top marks on these posts thumbsup
Now - Jaguar F-Type 2014 3.0 S Quickshift ,White/ Red interior (theme here!) Loving it .
Previously - 997 C4S Tip-S, 2007, Silver/Red and Black Leather, PSE, Sports Chrono, Turbo wheels.
keithrobinson
PostPosted: Mon May 04, 2015 7:28 pm    Post subject: Reply with quote
Car is transformed already, awesome stuff
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Page 3 of 9
