997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
DrIan
PostPosted: Thu Mar 19, 2015 2:48 pm    Post subject: Kenu airframe phone holder problem Reply with quote
Advice please.
Bought one of these for my Samsung S3 smartphone.
Fitted mount to nearer of the two central air vents in car.
Vent seems too loose, when I put phone into mount its weight moves louvre and makes screen droop down facing towards floor.
Tried all three louvres on both central vents -- same problem.
Are my vents too loose ? Is there a fix people have found for this ?
Am I unaware of some trick ?
Want to mount screen as near to eye level as possible for gps use etc
MJA911
2012 Porsche 991 Carrera
PostPosted: Thu Mar 19, 2015 3:03 pm    Post subject: Reply with quote
I mount mine (w/iPhone 6) on the top slat of the right hand vent as far over to the right side of the vent as possible and it stays put Dont know
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
gunner
PostPosted: Thu Mar 19, 2015 3:06 pm    Post subject: Reply with quote
I have a cheap generic version of this and mount it on the divider between the two centre vents which doesn't move.
Not sure if possible on your model but works for me.
993 C2 Tip Aventura
DrIan
PostPosted: Thu Mar 19, 2015 3:43 pm    Post subject: Reply with quote
Thanks very much.
Tried both of these suggestions and they are a big improvement.
ch3tman
1995 Porsche 911
PostPosted: Thu Mar 19, 2015 6:15 pm    Post subject: Reply with quote
I don't have mine to hand but take a look at the mounting 'clips', either horizontal or vertical will have a narrow, more tighter grip. Make sure you use the tighter gap to mount (you can turn it 360 degrees to suit). I had the same issue as you report before I realised this.
EDIT: The above probably isn't articulated well, I just found this pic which should help explain:
Also, try using it on the vent by the drivers door, seemed to work well for me and out of sunlight - if used for navigation (although charging isn't as simple when your phone is placed all the way over to the right).
Stuart7
PostPosted: Fri Oct 11, 2019 4:14 pm    Post subject: Reply with quote
Thread resurrection!
I use my phone as a satnav (Sygic) a lot and have been playing with various phone mounts and positions. I've settled on this unusual setup with a Kenu airframe:
- Open the ashtray and attach Kenu phone holder.
- Grip phone at the bottom, top of phone rests on the dash bottom lip.
It works well for me. I have decent peripheral vision and not found glancing down to be an issue.
Kenu airframe attached to ashtray
 Filesize:  147.68 KB
 Viewed:  1388 Time(s)
 Filesize:  132.18 KB
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Fri Oct 11, 2019 6:33 pm    Post subject: Reply with quote
I bought a kenyu airframe after extensive research and it was also too floppy, I put it down to my 997 vents.
Very annoying given the price.
I have now discovered YOSH magnetic mounts. Pack of two for about £7 on Amazon. I use both and it’s really secure, even with firm suspension.
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Fri Oct 11, 2019 7:10 pm    Post subject: Reply with quote
Bin it and get the Rennline item.
www.aircooledbug.co.uk
Shedman
PostPosted: Fri Oct 11, 2019 7:38 pm    Post subject: Reply with quote
Yep that.
1997 993 Targa Manual
AndyS
PostPosted: Sat Oct 12, 2019 12:22 pm    Post subject: Reply with quote
tyinsky wrote:
Yep that.
...no - get a Brodit thumbsup
Andy
James M-S
PostPosted: Sat Oct 12, 2019 1:54 pm    Post subject: Reply with quote
AndyS wrote:
tyinsky wrote:
Yep that.
Personally I prefer something closer to the eyeline (ie higher up)
AndyS
PostPosted: Sat Oct 12, 2019 4:55 pm    Post subject: Reply with quote
Exactly - like the Brodit Thumb
I really must take a picture in mine - but here's Nick's: http://www.911uk.com/viewtopic.php?p=1357047
Andy
PostPosted: Sat Oct 12, 2019 6:03 pm    Post subject: Reply with quote
You can’t really beat the Rennline item for OEM looks Bandit
[/img]
AndyS
PostPosted: Sat Oct 12, 2019 8:18 pm    Post subject: Reply with quote
....yes you can - with a Brodit clip (can you tell Yet that I like it) Bandit Grin
Andy
PostPosted: Sat Oct 12, 2019 11:36 pm    Post subject: Reply with quote
Really Question
gunner
PostPosted: Mon Oct 14, 2019 7:16 am    Post subject: Reply with quote
[/img]
Looks like its been taken off a bus steering wheel...
993 C2 Tip Aventura
nickjonesn4
PostPosted: Mon Oct 14, 2019 10:48 am    Post subject: Reply with quote
gunner wrote:
[/img]
Floor Floor
1996 Carrera S Vesuvius Metallic
2016 Golf R
2005 AMG E55K Wagon
PostPosted: Mon Oct 14, 2019 4:29 pm    Post subject: Reply with quote
Looks the business to me Thumb
