997 : 2004- 77
996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
porscheuk
PostPosted: Thu Mar 12, 2015 6:21 pm    Post subject: 2.4S Spec Engine Disaster Reply with quote
Took my 1972 S spec to Brands track day and ran a bearing. Took car to Tower Bridge Porsche in London, who charged me GBP 10,000 for an engine rebuild.
1500 miles later the engine destroyed itself. Consensus of opinion by two of the UK's best engine builders is that Tower not only used the wrong Loctite, but put far too much on resulting in the excess falling into the crankcase ,blocking oil passages and destroying the engine. Estimated cost of repair is just under GBP 30,000.
Tower want to recompense by providing their labour. Not likely!! Litigation proceeding. What a disaster.
Any others experienced shoddy workmanship from Tower, or am I the only unlucky one?
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Mar 13, 2015 6:14 pm    Post subject: Reply with quote
Sounds like a nightmare, any Porsche engine builder worth their salt should know the correct sealant compound and not be using too much or at least not to let it squeeze out internally, the results can be catastrophic as in your case. But one good thing is it always leaves the evidence behind when you strip the engine. I always use Loctite sparingly for this reason, you don't need much anyway.
Would you trust them to rebuild it again? Who is paying for the parts and did you get a warranty with the rebuild?
Griff500
PostPosted: Thu Aug 27, 2015 3:01 am    Post subject: Reply with quote
10 grand for an engine rebuild and now 30 grand for another rebuild....Someone is making an awful lot of money out of repairing Porsches...
My 1980 SC in Black Metalic ( SGK 608V where are you now ? )
C367 TUT an 86 Guards Red 3.2 (where are you? )
F67 GNT ( where are you now ? ) very nice Baltic Blue 3.2
Griff500, E46M3, 3.0CSL, MK1 3 Litre Capri, R5GT Turbo x 2 ( one is for sale ) Alfa Romeo 2600 Sprint Bertone ( for sale )
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Thu Aug 27, 2015 3:34 am    Post subject: Reply with quote
Welcome
First posts are normally better news than this!
I suppose you are also paying the cost of London premises!
What's the parts cost in the £30k? Seems a lot.
Chief
PostPosted: Thu Aug 27, 2015 7:32 am    Post subject: Reply with quote
As Pete says, not the best first post ever....
Every engine builder has their preferred methods but this clearly is a case of poor workmanship. I just can't stand this "We'll provide the labour and you cough up for the expensive bits" If you are at fault you sort it all out! Evil or Very Mad
I stand by my products and wouldn't bail out if it went tits up, so should they....Rant over, good luck and keep us posted.
porscheuk
PostPosted: Thu Aug 27, 2015 7:33 am    Post subject: 2.4 S engine Reply with quote
Unfortunately Towe Porsche deny any responsibility despite overwhelming evidence of their negligence.
The quote for an engine rebuild was from Canford Classics and included £4500 for a new crankcase, £3300 for the rebuild plus the replacement of camshafts, rocker shafts, valves ,pistons, oil pump,oil lines, crankcase work, etc. Basically to replace every part of the engine plus £5000 in VAT.
In the end I gave up and got Nick Fulljames of Redtek to supply and build a 3.2 Carrera engine on Weber carbs with a 964 cam for half the price.
The good news is that it pushes out 250 BHP and goes like an absolute rocket!
