997 : 2004- 61
Boxster : 1997- 26
Cayman : 2005- 20
Cayenne : 2003- 4
Hughb
PostPosted: Tue Jul 16, 2019 9:55 pm    Post subject: Re: ***Non-Turbo 996 owners - Please read - IMS DATA REQUIRE Reply with quote
Here's my data for my car.
date inputted: 16/09/19
member: Hughb
model: 996 Carrera 2 manual
engine size: 3.6
purchase date: 04/07/19
date registered: 01/07/03
mileage (at purchase): 85868
mileage (now): 86112
bearing (orig./replacement): Original
failure data (if applicable):
comment: clutch change at 48000, but no record on invoice of any inspection of ims bearing
AK996
PostPosted: Fri Oct 18, 2019 11:12 pm    Post subject: Reply with quote
Here's data my for my car.
date inputted: 18/10/19
member: AK996
model: 996 Carrera c4s tip
engine size: 3.6
purchase date: 11/10/19
date registered: 01/01/03
mileage (at purchase): 71000
mileage (now): 71200
comment: Original IMS , no mention of ims in paperwork/history.
PhilipR
PostPosted: Wed Oct 30, 2019 12:51 pm    Post subject: Here's data for my car Reply with quote
Date Inputted: 30.10.19
Member: PhilipR
Model: 996 Tip, Cab
Engine Size: 3.2
Purchase Date: August 2019
Date Registered: 2001
Mileage [at purchase]: 54,300
Mileage [predent]: 55779
Bearing: Original
Comment: Original IMS
DarthFaker
PostPosted: Sat Nov 23, 2019 5:16 pm    Post subject: Reply with quote
Updated my previous post, car at specialist with the engine out to find out what the issue is, metal in oil filter.
PostPosted: Sat Nov 23, 2019 5:19 pm    Post subject: Reply with quote
Please feed back when they tell you what it is. I'd be surprised if it was your IMS bearing.
DarthFaker
PostPosted: Sun Nov 24, 2019 7:15 am    Post subject: Reply with quote
DELETE THIS POST PLEASE
PostPosted: Sun Nov 24, 2019 8:33 am    Post subject: Reply with quote
Possibly so, the IMS bearing may be goosed, but it may not be the cause of the problem. Could have had a jammed valve or something that then put too much strain on the chains and bearing causing them to also fail.
DarthFaker
PostPosted: Sat Nov 30, 2019 2:52 pm    Post subject: Reply with quote
Confirmed as IMS failure by specialist.
GMG
PostPosted: Sat Dec 21, 2019 12:51 pm    Post subject: Reply with quote
Why?
willy
PostPosted: Sat Dec 21, 2019 6:16 pm    Post subject: Reply with quote
2yr update:
date inputted: 21/12/19
member: willy
model: 996.1 C2
engine size: 3.4
purchase date: 03/12/12
date registered: mid 1998
mileage (at purchase): 112000
mileage (now): 149000
bearing (orig./replacement): Original - dual row
comment: Clutch\flywheel replacement with IMS inspection @138000.
1998 996 Carrera Ocean Blue
Dave.P
PostPosted: Tue Dec 31, 2019 8:45 pm    Post subject: Reply with quote
date inputted: 31.12.19
member: Dave.P
model: 996 Carrera 4 manual
engine size: 3.6
purchase date: October 2017
date registered: 2003
mileage (at purchase): 63000ish
mileage (now): 65500
bearing (orig./replacement): Original ( presumed)
comment: clutch change and gearbox rebuild at 55k ish invoice showing new ims seal, so presumably checked then but not replaced
jnj
PostPosted: Fri Jan 03, 2020 8:00 am    Post subject: Reply with quote
date inputted: 01/2020
member: jnj
model: 996.2 C4
engine size: 3.6
purchase date: 03/10/2018
date registered: 03/2002
mileage (at purchase): 124000 km
mileage (now): 140000 km
bearing (orig./replacement): Factory rebuilt short block at 85000km, reason unknown
comment: Now has bore scoring and engine under rebuilt.
James996
PostPosted: Fri Jan 03, 2020 10:16 pm    Post subject: Ims upgrade replacement Reply with quote
Hi guys if any one lives in the south i can recommend JMG porsche
They did a fantastic job on my 996 c4s and very
Reasonably priced there near Bournemouth starf are very knowledgable. Job was fantastic.
 Filesize:  712.72 KB
 Viewed:  286 Time(s)
Goto page Previous  1, 2, 3 ... 21, 22, 23
Page 23 of 23
