997 : 2004- 63
Boxster : 1997- 27
Kingb4
PostPosted: Tue Apr 17, 2018 12:53 pm    Post subject: Reply with quote
date inputted: 17/04/2018
member: Kingb4
model: 996.2 c2
engine size: 3.6
purchase date: 20/2/2018
date registered: 03/02
mileage (at purchase): 80000
mileage (now): 80600
bearing (orig./replacement): Unknown
failure data (if applicable): None
comment: I have all past receipts and there isnt a record of the IMS being changed (they did the IMS seal in 2016)
2002 996.2 C2 Cabriolet
jockmog
PostPosted: Mon May 07, 2018 4:32 pm    Post subject: IMS Survey Reply with quote
Date input 07/05/18
Member Jockmog
Model Carrera 2
Engine size 3.4
Purchase date 04/05/18
Date registered 01/07/2001
Mileage at purchase 74420
Mileage now 74570
Bearing Believed original
Failure Dat N/A
Comment This is really good work! I have only just purchased the car and I am thinking about a IMS and clutch change.
dombo
PostPosted: Mon May 14, 2018 3:33 pm    Post subject: Reply with quote
date inputted: 14/05/18
member: dombo
model: 996.2 C2 Cab silver/black
engine size: 3.6
purchase date: 06/05/17
date registered: March 2003
mileage (at purchase): 69000
mileage (now): 73000
bearing (orig./replacement): Original
failure data (if applicable): N/A
comment: Last service Sept 2017 oil filter cut open and inspected for bits by specialist 9e. None showing. This will be checked every 12 months when serviced by 9e.
eabeukes
1999 Porsche 996 Carrera 2
PostPosted: Sun Jun 10, 2018 1:40 pm    Post subject: Reply with quote
date inputted: 10/06/2018
member: eabeukes
model: 996.1 C2
engine size: 3.4
purchase date: 11//17
date registered: 17/03/1998
mileage (at purchase): 135000
mileage (now): 137500
bearing (orig./replacement): replacement
failure data (if applicable): Possible replacement 85k, 121k. Replaced 130k, unit faulty and replaced again at 137k
comment: Rebuilt engine at 137k due to cam timing. Internals still excellent condition.
Cybot7
2001 Porsche 996 Carrera 2
PostPosted: Mon Jun 18, 2018 1:07 pm    Post subject: Reply with quote
date inputted: 18/6/18
member: Cybot7
model: 996.1 C2
engine size: 3.4
purchase date: 03/02/18
date registered: 02/01/2001
mileage (at purchase):29400
mileage (now): 30510
bearing (orig./replacement): Original. No mention of any major work in FSH
failure data (if applicable):N/A
comment: So far so good.
Nothing is foolproof to a sufficiently talented fool
rdodger
PostPosted: Mon Jun 18, 2018 1:19 pm    Post subject: Reply with quote
member: rdodger
model: 996.2 C2
engine size: 3.6
purchase date: 03/05/18
date registered: 01/05/2004
mileage (at purchase):68,214
mileage (now): 68,746
comment: Seal removed at 68,214
Stotty
PostPosted: Fri Jun 22, 2018 1:22 pm    Post subject: Reply with quote
date inputted: 22/6/18
member: stotty
model: 996 C2
engine size: 3.4
purchase date: 01/04/08
date registered: 01/01/00
mileage (at purchase):57,000
mileage (now): 169,000
comment: Bearing checked when RMS replaced Feb '18. Seal has gone, but bearing well lubricated and showing no outward signs of failure. Discussed option with Indy and decided to leave well alone.
2000 996, C2, manual, arctic/metropole, Koni shocks, H&R -30 springs, H&R ARB's, Rennline SS engine mounts, cup wheel, 170k miles. 2018 Touareg RLine Plus
Nytol
PostPosted: Sat Jun 23, 2018 7:07 am    Post subject: Reply with quote
Date inputted 23/6/2018
Member Nytol
Model C2
Engine 3.4
Date purchased Summer 2012
Year 1999
Mileage at purchase 92k
Current mileage 125k
Bearing original
No failure
Moodytunes
PostPosted: Sat Jun 30, 2018 10:06 pm    Post subject: Reply with quote
date inputted: 30/06/2018
member: moodytunes
model: 996.1 C4
engine size: 3.4
purchase date: 10/2016
date registered: 14/01/2000
mileage (at purchase): 83,693
mileage (now): 89,000
comment: No issues to date
sbhassall
PostPosted: Mon Jul 02, 2018 9:27 pm    Post subject: Reply with quote
date inputted: 2/7/18
member: sbhassall
model: 9961 C2
engine size: 3.4
purchase date: 24/6/18
date registered: 1/6/2001
mileage (at purchase): 109300
mileage (now): 109485
comment: RMS and clutch changed at 94,000 miles by Cath Burrows,IMS not changed
CMar996
PostPosted: Sat Nov 24, 2018 3:19 pm    Post subject: IMS failure 1998 C4 Reply with quote
Hi l was reading the update on IMS failures and thought I should share my experience in November last year..
I had bought the car a year earlier and had gone thro a mixed experience with specialists including one listening to the bearing with a stethoscope and it seemed fine. In November I took it to the same specialist and asked them to cut open the oil filter when they changed the oil. Shiny bits of metal in the filter and I posted on here at the time . I got three specialists to respond the one above said go and run it for 1000 miles and check again , one said don't run the car again until the bearing is changed the last said drive it to us , about 130 miles , but no more.
I used the last one and when they took the engine out the bearing was so degenerated they reckoned it would have failed in 10 miles. The sump had bits of broken bearing in it.
So at 70000 they bearing failed.
The car had had very limited use for 4 years before I bought it at 62000 miles and while the low mileage was attractive the downside may well have been the effect of this on the bearing.
So these cars do still fail from this potentially defective component.
GMG
PostPosted: Sat Nov 24, 2018 4:49 pm    Post subject: Reply with quote
...mine collapsed at 69k miles...no warning... dwarf and bearing debris found throughout the engine when stripped down...
GMG
PostPosted: Sat Nov 24, 2018 4:50 pm    Post subject: Reply with quote
...no dwarfs were found in the engine...swarf was though Very Happy
PostPosted: Sat Nov 24, 2018 7:24 pm    Post subject: Reply with quote
Can you post your full details up then:
date inputted:
member:
model:
engine size:
purchase date:
date registered:
mileage (now):
comment:
996 Simon
PostPosted: Fri Nov 30, 2018 7:57 am    Post subject: Reply with quote
date inputted: 20/11/18
member: 996 Simon
model: 9961 C2
engine size: 3.4
purchase date: June 2014
date registered: March 1998
mileage (at purchase): 80,000
mileage (now): 108529
bearing (orig./replacement): Original (nothing in the service history)
comment:
1998 996.1 GT3 Aerokit
18" Sport Technos
IPD / Designtek CAI
Dansk Supersound (now with new flexi's).
PostPosted: Fri Nov 30, 2018 8:03 am    Post subject: Reply with quote
thumbsup
I'll try and get my spreadsheet updated over the weekend. Well over 100 cars now.
Griffter
PostPosted: Sat Dec 01, 2018 10:46 am    Post subject: Reply with quote
date inputted: 1 Dec 2018
member: Griffter
model: 996.1 C4
engine size: 3400
purchase date: Oct 2015
date registered: April 2001
mileage (at purchase): 42000
mileage (now): 48000
bearing (orig./replacement): original as far as I know
comment: squeaky clean underneath
PostPosted: Sat Dec 01, 2018 12:05 pm    Post subject: Reply with quote
Just updated the data collection this morning. Now have data from over 130 cars.
Results here: http://911uk.com/viewtopic.php?t=102070&postdays=0&postorder=asc&start=55
SaintsPaul
PostPosted: Sun Dec 02, 2018 4:18 pm    Post subject: Reply with quote
date inputted: 2/12/18
member:SaintsPaul
model:996.1 C2
engine size: 3.4
purchase date: 17/11/18
date registered: 8/3/00
mileage (at purchase):76,000
mileage (now): 85,550
bearing (orig./replacement):original
comment: A bit late to the party but thought I should add my data. Gearbox rebuilt in the summer so had bearing checked. Original bearing in great condition and I had the dust shield removed on the bearing.
SaintsPaul
PostPosted: Sun Dec 02, 2018 4:20 pm    Post subject: Reply with quote
Sorry wrong purchase date. Should be 12 not 18 Embarassed
Goto page Previous  1, 2, 3 ... 20, 21, 22, 23  Next
Page 21 of 23
