997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
segart
PostPosted: Thu Feb 04, 2016 9:50 am    Post subject: Reply with quote
Not sure your mileage is correct Stasis. IMS replaced in 2003 at 90k miles? Car purchased in 2008 with 71k miles?
Rick
997.2 Carrera 2S pdk
Ex 996 C4S Manual
alex yates
PostPosted: Thu Feb 04, 2016 12:49 pm    Post subject: Reply with quote
Thank you kind sir!
thumbsup
cobrars
PostPosted: Tue Feb 23, 2016 9:17 am    Post subject: Reply with quote
Hello there... details as requested
date inputted: 23/02/2016
member: cobrars
model: 996.1
engine size: 3.4
purchase date: 02/03/2013
date registered: 15/03/1999
mileage (at purchase): 85324
mileage (now): 90354
bearing (orig./replacement): Original !!! - (edited 06-08-16) Thought was replacement.
failure data (if applicable): N/A
comment: Full Hartech Rebuild at 65,000 after Porsche Dealer forgot to put oil in after a service, took for test drive and seized the engine.... thumbsup
Previous : TVR Cerbera 4.5
Current : VW Golf 25th Anniversary No 1398
Current : Porsche 911 996 C2 Manual With Full Hartech Engine & Gearbox Rebuild
Car Thread - http://911uk.com/viewtopic.php?t=118834&highlight=
alex yates
PostPosted: Tue Feb 23, 2016 11:29 am    Post subject: Reply with quote
thumbsup
declandio
PostPosted: Tue Feb 23, 2016 11:32 am    Post subject: Reply with quote
Which dealer was that? I'd love to book my next service with them, assuming they paid for the rebuild!
cobrars
PostPosted: Tue Feb 23, 2016 2:15 pm    Post subject: Reply with quote
Ha, it's not that simple i'm afraid. I'm not 100% on which dealer it was so don't want to name on a public forum without checking. basically, Porsche dealer seized engine, believe it or not, rang customer and said car was knackerd and was nothing to do with them. After an 18 month legal battle, the dealer was ordered to reimburse customer..... By the end of it all the customer had a pocket full of cash, a car with no engine and a box of stripped down engine bits..... (engine was stripped for court case to prove engine had seized due to lack of oil) Judge
Then it was off to Hartech...... Thumb
jerzybondov
PostPosted: Tue Feb 23, 2016 9:21 pm    Post subject: Reply with quote
That is frickin' APPALLING.
The sheer gall of the dealer to lie about it to that extent... You wonder whether it was just the 17 year old trainee tech who forgot to put the oil in and lied about it - everyone else believed him. Surely not though... This has to go right up to the management?! Surprised
alex yates
PostPosted: Tue Mar 08, 2016 10:32 am    Post subject: Reply with quote
Review added to 1st post on page 1, or see last page here: http://911uk.com/viewtopic.php?t=102070
stasis
PostPosted: Tue Mar 08, 2016 11:40 am    Post subject: Reply with quote
Rick
oops you are right should be ims at 2013, corrected below
date inputted: 05/02/16
member: stasis
model: 996.1.C2 tip
engine size: 3.4
purchase date: 1/05/2008
date registered: 06/01/98
mileage (at purchase): 71000
mileage (now): 96,000
bearing (orig./replacement): replaced in 2013 at 90k, had not failed, preventative only
failure data (if applicable):none
stainless chinese manifolds, Designtek straight through exhausts, hemholtz removal and foam filter.
paulstevens64
PostPosted: Tue Mar 08, 2016 11:50 am    Post subject: Reply with quote
date inputted: 08/03/16
member: Paul Stevens64
model: 996 C4S
engine size: 3.6
purchase date: 15/06/2015
date registered: 15/09/2002
mileage (at purchase): 57,000
mileage (now):60,000
bearing (orig./replacement): Original. Checked in August when clutch replaced.
Niall996
PostPosted: Tue Mar 08, 2016 12:13 pm    Post subject: Reply with quote
stasis wrote:
Rick
member: stasis
model: 996.1.C2 tip
engine size: 3.4
What did you replace it with because I was under the impression you couldn't get the original 1998 type dual row bearings any more?
Jamie©
PostPosted: Tue Mar 08, 2016 1:58 pm    Post subject: Reply with quote
member: Jamie©
model: 996 C4S
engine size: 3.6
purchase date: 13/11/2015
date registered: 07/10/2002
mileage (at purchase): 74,000
mileage (now):77,000
bearing (orig./replacement): unknown
Chris_in_the_UK
Estoril
PostPosted: Mon Mar 14, 2016 9:49 pm    Post subject: Reply with quote
FWIW I think some of the comments are disingenuous .
Firstly, there are 1000's of Porsche owners/drivers who know nothing about any technical aspect of their car and never will - they drive it, end of. The poll alex started was an attempt to put an enthusiast perspective on the numbers and frequency - nothing more, nothing less.
The quoting of 'class action disclosure' is useless at best since it's only referring to what Porsche in the USA fixed and we know what OPC's do when stuff is apparently broken - they swap it.
Some of you guys are painful - seriously.
2006 Cayman S PCCB's
petero
PostPosted: Tue Mar 15, 2016 8:05 pm    Post subject: Reply with quote
I'll give it a go Alex:
Date input: 15/03/16
Member: petero
Model: 996.2 C4
Engine: 3.6
Purchase Date: 05/03/2016
Date Registered: 18/03/2003
Mileage (at purchase): 130,800
Mileage (now): 131,000
Bearing (orig/replacement): N/A - Engine rebuilt on new Porsche short engine @ 125k due to piston/head/bore damage on one cylinder.
Failure Data: None
Comment: IMS bearing was fine on original engine and now has later type IMS which came with new block.
alex yates
PostPosted: Tue Mar 15, 2016 8:11 pm    Post subject: Reply with quote
Member: petero
Model: 996.2 C4
Engine: 3.6
Date Registered: 18/03/2013
Failure Data: None
Your registration date is incorrect my friend. When was it registered?
thumbsup
petero
PostPosted: Tue Mar 15, 2016 8:15 pm    Post subject: Reply with quote
My bad! 2003 - wishful thinking on my part I guess!
2003 996.2 C4 Coupe
petero
PostPosted: Tue Mar 15, 2016 8:19 pm    Post subject: Reply with quote
Corrected it now Thumb
2003 996.2 C4 Coupe
alex yates
PostPosted: Tue Mar 15, 2016 8:23 pm    Post subject: Reply with quote
Steve Gom
PostPosted: Sun Apr 03, 2016 6:29 pm    Post subject: Reply with quote
Info for your survey Alex.
Date input: 03/04/16
Member: Steve Gom
Model: 996.1 C2
Engine: 3.4
Purchase Date: 03/05/2015
Date Registered: 27/11/1997
Mileage (at purchase): 91,500
Mileage (now): 95,400
Bearing (orig/replacement): Replacement
Failure Data: None
Comment: IMS bearing replaced by Jaz in Nov 2007 at 62,800 miles.
Steve
Slow in fast out...
1997 996 C2 manual
2006 955 Cayenne 3.2 tip
1998 RS 50th Anniversary VFR 800FiW
Les
2008 Porsche 997 Carrera 2
PostPosted: Tue Apr 05, 2016 9:33 am    Post subject: Reply with quote
Just seen this thread:
date inputted: 05/04/16
member: Les
model: 9962 C2
engine size: 3.6
purchase date: 04/05/13
date registered: 10/09/02
mileage (now): 79000
bearing (orig./replacement): Replacement
failure data (if applicable): Valve seat dropped destroyed engine
comment: Cold engine reversing out of garage. Total failure.
As soon as my bore score issues are felt with I'll update again.
5 out of the 8 Porsches I've owned have all suffered catastrophic engine failures.
I don't think they like me.
Goto page Previous  1, 2, 3 ... 17, 18, 19, 20, 21, 22  Next
Page 18 of 22
