997 : 2004- 71
996 : 1997-2005 35
Boxster : 1997- 25
Cayman : 2005- 14
richardjjs1
PostPosted: Mon Apr 07, 2014 4:51 pm    Post subject: 996 Convertible gets bad condensation in heavy rain Reply with quote
This is a 2000 Y model year 996 Convertible
It is not using water from the engine so I assume its not a coolant problem
Does the ROOF need re sealing Mad
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Mon Apr 07, 2014 8:00 pm    Post subject: Reply with quote
It will be blocked rear drainage channels, your carpets will be soaking.
The only way to sort it is to clean the debris out (lots of threads on this, but basically rear wheel inner arches out), then remove your seats and get the carpets out to dry them properly. The foam is so absorbent that it will take months to dry out any other way, even with a de-humidifier.
