Author |
Message |
jonttt Long Beach
Posted: Fri May 24, 2013 10:12 am Post subject:
As part of my hobby I like setting myself some challenges to source parts second hand rather than take the easy route and buy new. This is not being a cheapskate but adds some fun for parts which ultimately are just as good second hand as new.
There are a few new motorsound airboxes on ebay at the moment from £90 to £139 and I've made a few offers around the £60 which have been rejected so I was pretty pleased when I source one for <£60 delivered second hand.
Fitting is a 1 minute job by releasing the retaining clips at the top and front and pulling off the auxiliary rubber tube.
OEM standard and motorsound "sports" option side by side.
There is a cosmetic difference in the metal intake compared to the original plastic effort so everyone KNOWS you have the "upgraded" box installed
Then there is the performance enhancing holes in the side Now I've done a fair bit of research into induction systems for other cars and fundamentally anything which is prone to bring hot engine air into the induction is more likely to reduce performance than increase it
ie colder air = more performance (and hence why a car always seems faster on a clear chilly winters morning blast because it is )
So drilling holes in the side surrounded by warm engine air does not on the face of it make sense. However due to some presumed air pressure entering the box when the car is in motion it is likely that this pressure would stop warm air from actually entering the induction through these additonal holes. It follows that any increased noise is created by this effect but with absolutely no performance benefits at all If thats not the case then fitting this option would probably reduce performance so far as I can tell.
I've not driven it yet and have heard mixed reviews as to whether it compliments the RSR's or if any additional induction noise is hidden so will be interesting to hear and I will report back.
I'm not expecting a BMW CSL induction effect (the sound of a CSL induction under full load is awesome)
Fitted....... and I know I did not have the resource to clean it before fitting but I have new filters on order so will clean it then
Its worth noting that people have spend £0 on this upgrade and simply drilled holes in the side of the standard box either to copy the motorsound box or larger holes. There is even an option to just buy a retaining frame for the filter and leave almost the entire side of the filter open. That would be the same as fitting an open cone filter which I don't really like as you are certainly dragging in warm engine air  _________________ 1997 Porsche 911 993 C4S My Journal
Zingari Brands Hatch
Dont get many cars in that place  _________________ The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
jonttt Long Beach
Posted: Fri May 24, 2013 10:24 am Post subject:
400 spaces and about 200 cars use it. I have 3 or 4 cars in there at any one time
Its a great car park, city centre, 2 story underground, large spaces, 24/7 security, full CCTV, ventilated, well lit and allocated parking (we own a number of the spaces so now one else can park in them).
It helps when one of my companies runs it
Some nice cars in there but I still struggle to get the Phantom in
Here is a pic with Quentin Wilson with my excellent parking skills
jonttt Long Beach
Posted: Fri May 24, 2013 10:38 am Post subject:
Some small OCd jobs which make all the difference
Myu rear spoiler only had one protection cap fitted. If that would have been missing I would not have even known there should be some.
You need 6 of these in total
Here is full write up on fitting for those poor souls who are not very technical.....
1) raise spoiler. Hint it is easier to do this whilst stationary via the button in the car rather than at 40MPH +
2) push on each protection cap (one at a time unless you have really long fingers and are a magician)
3) lower spoiler via button in car (or slow down )
job done
Next was for the dreaded drainage rubbers. I had two missing so ordered 5
nb these are listed under the headlight fittings on PET as they are also fitted in the headlight recesses.
and finally a more obscure part......door lock covers. As I have remote central locking I would only ever us the key in the door locks in an emergency. These are designed to stop crap getting onto the keyhole. Again I need to clean the keyholes properly at some point but covers fitted
before
after
Posted: Fri May 24, 2013 10:49 am Post subject:
Nice one Jon - Nipples and teats done I will have to get the door lock caps
BTW have you ever been to the Chung Ku restaurant on the waterfront? Owner Norman Shum is a big Porsche fan - IIRC he has a 964 3.6 Turbo and I believe ninemeister are building a back-date for him. Goes by 'Nski' on RL _________________ The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
jonttt Long Beach
Posted: Fri May 24, 2013 12:02 pm Post subject:
I know of it but never been. Its one of those places I've always wanted to try but never got round to it not helped by the fact the best known chinese in Liverpool is on my doorstep  _________________ 1997 Porsche 911 993 C4S My Journal
jonttt Long Beach
Posted: Fri May 24, 2013 10:03 pm Post subject:
Update on the motorsound airbox....... Yep it makes a difference........ Much more than I thought it would so will be staying on even if it does loose a few BHP. I did scare myself trying it out though  _________________ 1997 Porsche 911 993 C4S My Journal
aak Montreal
Posted: Fri May 24, 2013 10:27 pm Post subject:
Hi!
where did you get the door lock covers from?? _________________ 993 C2 Schwarz Black
997 C2S Seal Grey
jonttt Long Beach
Posted: Sat May 25, 2013 12:31 am Post subject:
I got them from jasmine porsche a part as I have an office just down the road from them. You could order them from an OPC. The part number is in the picture. _________________ 1997 Porsche 911 993 C4S My Journal
jonttt Long Beach
Posted: Sat May 25, 2013 9:37 am Post subject:
I have received my cars official Porsche Certificate of Authenticity.
There is usually a fee for this but its free if you quote your PCGB membership number
jonttt Long Beach
Posted: Sat May 25, 2013 9:42 am Post subject:
I ordered some aluminium bezel rings and decided to fit them. I used Bluetack as contact adhesive so they are easily removable when required.
They will fit in with some other changes I have in the pipe line as part of my plans to "lift" the blue interior
and original v new look....
ps I've had more chance to drive the car with the new steering wheel fitted and I really am pleased with it  _________________ 1997 Porsche 911 993 C4S My Journal
jonttt Long Beach
Posted: Sat May 25, 2013 9:49 am Post subject:
Another quick and easy job was to replace the blown light switch bulb.
These should be on whenever the ignition is on and so the bulbs must blow after a few years of constant use.
Very easy change, bulbs sourced for a few £ from ebay, pull off the knob top (nb you do have to pull hard but it will just pull off), pull out the exposed bulb left behind, push in new bulb (leave ignition on so you can check the bulb works) and then push the knob button back on (nb it does have a small grove so is directional with the bulb upside down when you push back on)
Knob pulled off with exposed bulb holder left behind (bulb removed)
New bulb in place
Job done....
Its weird to think this bulb could have been blown for 10 years and no one realised.
Is it working in yours  _________________ 1997 Porsche 911 993 C4S My Journal
jonttt Long Beach
Posted: Sat May 25, 2013 10:03 am Post subject:
I love buying a new hobby car, the first few months feel like Christmas every day
New suspension arrived today.
I was keen to retain the M033 OEM 4S suspension height and ride settings whilst upgrading the OEM dampers for some units which would last longer. The car will not be tracked and so I do not need a fully adjustable setup. Plus my other toy has a track "Race" suspension fitted which whilst great around the twisties does not half make the teeth chatter
I settled on the well proven Bilstien B8 (also known as HD's for Heavy Duty) with new OEM M033 springs. These do offer adjustablility for ride height/corner weighting but not bump and rebound.
nb The Bilstein B8 shocks/dampers have the same damping as the Bilstein B6 but the stroke of the pistons is 20mm shorter. Due to the shorter rebound, it makes the Bilstein B8 a better match for the shorter M033 / M030 OEM springs whilst allowing enough adjustment to retain OEM lowered ride height. B6's should be used if standard (longer) 993 ride height springs are used.
Delivered from Gert Carnewal whose customer service is second to none and he offers a range of well proven "kits" to meet all needs. He was also the cheapest I could find which is always an added bonus
This is one heavy box but received 2 days from Belgium after placing the order. Its so nice to find a supplier who actually has what he sells in stock.
and the sun even came out for the unpacking...
includes new bump stops which is good as mine where picked up on the inspection as being rotten ....
I have to take my 3 year old daughter to Toys r Us now this afternoon as she wants to know why I am getting all the presents
ellistai Spa-Francorchamps
1997 Porsche 993 Carrera 2S
Posted: Sat May 25, 2013 1:35 pm Post subject:
I can see that you've got the "blue" M033 springs for the front (front doesn't have a choice anyway). What about the rear? "White" or "Lilac"? _________________ Ex: 04 997 C2S Manual
Current: 97 993 C2S Vesuvius Grey MT
10 997.2 C2S Macadamia Metallic MT
dommorton Zolder
1998 Porsche 993 Carrera 4S
Posted: Sat May 25, 2013 2:05 pm Post subject:
Didn't realise you can pull the whole top off these.
I levered the cap out of the middle and used needle nose pliers  _________________ Good cars can get you from point A to point B. And great cars? Well, they'll just get you into trouble.
Posted: Sat May 25, 2013 2:08 pm Post subject:
Very nice............where will it end I like the alu instrument rings. I'd dismissed these before as tacky (probably the chrome ones) but actually they look very good indeed  _________________ The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
jonttt Long Beach
Posted: Sat May 25, 2013 5:53 pm Post subject:
dommorton wrote: | Didn't realise you can pull the whole top off these.
I levered the cap out of the middle and used needle nose pliers  |
There is more than one way to crack and egg.......but some are harder than others  _________________ 1997 Porsche 911 993 C4S My Journal
jonttt Long Beach
Posted: Sat May 25, 2013 6:05 pm Post subject:
Zingari wrote: | Very nice............where will it end I like the alu instrument rings. I'd dismissed these before as tacky (probably the chrome ones) but actually they look very good indeed  |
I was not sure myself but when I saw this version from Carnewal who only seem to source the best parts for the 993 I thought I would give them a go and so added them onto another order. I figured if I did not like them I could sell them on pretty easily.
I do like them fitted and I'm trying for a slight silver theme inside with the steering wheel stitching, gear stick top and other small things in the pipeline hopefully it will all come together without being OTT. _________________ 1997 Porsche 911 993 C4S My Journal
jonttt Long Beach
Posted: Sat May 25, 2013 6:31 pm Post subject:
ellistai wrote: | I can see that you've got the "blue" M033 springs for the front (front doesn't have a choice anyway). What about the rear? "White" or "Lilac"? |
The Carnewal kit comes with Rear Springs P/N 993 333 531 21 504 (White color).
The difference to the more expensive Lilac Rears (P/N 993 333 531 22 504) is negligible. Consequently everyone stocks the whites as they are interchangeable and you would never notice the difference. _________________ 1997 Porsche 911 993 C4S My Journal
Posted: Sun May 26, 2013 10:13 am Post subject:
jonttt wrote: | ellistai wrote: | I can see that you've got the "blue" M033 springs for the front (front doesn't have a choice anyway). What about the rear? "White" or "Lilac"? |
The difference to the more expensive Lilac Rears (P/N 993 333 531 22 504) is negligible. Consequently everyone stocks the whites as they are interchangeable and you would never notice the difference. | Yeah, but as being OCD, shouldn't you opt for the Lilac one which is more correct for car with A/C? Price shouldn't be a concern of yours  _________________ Ex: 04 997 C2S Manual
