997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 20
Cayman : 2005- 16
Cayenne : 2003- 4
Post new topic   This topic is locked: you cannot edit posts or make replies.
Gazc2
PostPosted: Mon Oct 08, 2012 8:45 pm    Post subject: 964 Project - Under the bubbles Reply with quote
Well decided to have a prod round the bubbles at the weekend corner of the windscreens no real surprise will get the wings off the next couple of weeks to see what lurks underneath. the rear quarter has had a bodge and fill but actually was not quite as bad as I expexted as in wasn`t as far up the rear quarter as I had expected (like Clinchy`s) so looks like cut the bit on the sill and take a cut across the quarter.
could be a few nights in the mancave this winter.
 Filesize:  80.88 KB
 Viewed:  28744 Time(s)
 Filesize:  87.85 KB
 Filesize:  92.04 KB
 Filesize:  60.57 KB
igaffz
PostPosted: Tue Oct 09, 2012 6:08 pm    Post subject: Reply with quote
Get one of those magic pens of the tele, that will sort it Thumb
Horizon blue, 964 carrera 2 tip, lowered on koni's, k&n, de-cat, cup pipe, leather trim and 18" 3 piece split rims.
Silver 928 S2, B reg, manual.
Guards red 944 lux, the new project!
Gazc2
PostPosted: Tue Oct 09, 2012 8:04 pm    Post subject: Reply with quote
How do you get your car on that classic car restoration program they could fix this up in no time Laughing
clinchy993
PostPosted: Tue Oct 09, 2012 8:29 pm    Post subject: Reply with quote
Sleep with the program producer Dont know
Gazc2
PostPosted: Sun Oct 14, 2012 4:18 pm    Post subject: Reply with quote
Made a bit of progress today stripping the front end and had a good look round,I suspect it has had both front wings replaced at some point both have certainly been off previously, the oil cooler and front aluminium bumper have also been replaced have tonbridge opc stickers still attached so looks as though it has maybe had a front end tap at some point. The tub is spot on with no sign of damage so all pretty good really some overspray here and there from some of the countless bits of paint it has had.
Made a start on removing the wing/fender all pretty straightforward other than a couple of retaining bolts behind the AC plumbing which I think I can probably get, or should I pull the ac drier etc ?
 Filesize:  80.48 KB
 Viewed:  28506 Time(s)
clinchy993
PostPosted: Sun Oct 14, 2012 5:48 pm    Post subject: Reply with quote
Gary if the front wings have never been off the car there will be a small spot weld in the area of the windscreen scuttle panel and the top of the wing under that little rubber strip and the wing will not come off with this intact
You can see it to the right of the bolt
I just used a sharp chisel and tapped it off
Gazc2
PostPosted: Sun Oct 14, 2012 6:42 pm    Post subject: Reply with quote
Thanks for that Clinchy I was aware of these welds and none there, pretty sure both wings have been replaced at sometime a heap of waxoil has been sprayed along the inner edges and wing tape is keeking under the seam.
good news is the wings are in perfect condition
fuch
PostPosted: Wed Oct 17, 2012 7:30 pm    Post subject: Reply with quote
Good news on the wings being mint!! Think there about £600 each new.
This is why my bubble was there as you can see in the metal the tin worm has set in and this was repaired by a opc bodyshop around 5 yrs ago!! With a lifetime guarantee.....Mmmmmm
If you look close you can see where they have put weld in to try and fill the holes to fill I'm up!!
Nice....
http://s1177.photobucket.com/albums/x347/fuch964/?action=view&current=285B22A5-6CED-41F4-B18F-0F33FD07787B-4337-0000040EFF73224B.jpg
Steve made me a new one and fabricated it in so no more tin worm....yippe
Gazc2
PostPosted: Wed Oct 17, 2012 8:46 pm    Post subject: Reply with quote
Pretty pish attempt at a repair welding up rusty holes , surgery is the only solution I have the same issue on one side, what you doing with your paint blending it in or do you have to do the whole quarter ?
fuch
PostPosted: Thu Oct 18, 2012 12:10 pm    Post subject: Reply with quote
I've a few bits on the door that need doing so going to go down the whole side as its metallic so the colour match will be ok....it's going to be all done one day!!
clinchy993
PostPosted: Thu Oct 18, 2012 1:37 pm    Post subject: Reply with quote
Nice....
If I remember when the PO had that done his bill was north of £7k Grin
Vic
PostPosted: Fri Oct 19, 2012 8:30 am    Post subject: Reply with quote
clinchy993 wrote:
[If I remember when the PO had that done his bill was north of £7k Grin
Must have been the same bodyshop Sram used Floor
-ooops, sorry Sram Box In
fuch
PostPosted: Sat Oct 20, 2012 10:17 am    Post subject: Reply with quote
I think that big OPC sign above the door doesn't mean to much in today's world unfortunately....heard good things about byfleet Thumb
Sorry for the hi jack Gaz... Lets see them pics of your current labour!!
Gazc2
PostPosted: Sun Oct 21, 2012 7:34 pm    Post subject: Reply with quote
No progress this weekend to busy with electrics and relaying all the glass wool on the extension ,murder, also wedding anniversary so priority to the team leader. and just when I would rather spend on the 964 the bloody lights on the wifes ML have went all wonky some active module thingy went tits up Sad
Gazc2
PostPosted: Sat Nov 03, 2012 6:02 pm    Post subject: Reply with quote
Small bit of progress today got the passenger wing off had hoped to get the AC lines out the way making it easier to get to the bolts at the inside/top of the wing but nuts under the sill were seized solid so a bit of fiddling to get the bolts out. contemplating removing the AC altogether not a huge requirement for Scottish summers Laughing
Good news is the inner wing is spot on with the rust localised to the corner of the windscreen.
 Filesize:  95.63 KB
 Viewed:  23794 Time(s)
 Filesize:  94.96 KB
fuch
PostPosted: Mon Nov 05, 2012 8:38 pm    Post subject: Reply with quote
Where you suprised at How big that washer bottle was when you got the wing off!!
I bet our cars sit a inch lower on the passenger side when it's full of washer fluid... Surprised
Gazc2
PostPosted: Mon Nov 05, 2012 9:38 pm    Post subject: Reply with quote
Tempted to get rid of everything under that wing and use the intensive washer , might pull the A/C as well . worried the car will end up lopsided !
Gazc2
PostPosted: Fri Dec 28, 2012 6:32 pm    Post subject: Reply with quote
Well eventually found some time to get back to the car, when you buy cars of this age you don`t really know what your getting untill you start tearing it apart
someone went to the time and considerable expense to put new wings on the least they could do is put all the bolts back in ! a couple missing from the trunk side and the 2 awkward ones at the top in the wheel arch missing wing practically fell off once the bolts were out no tape or sealer on wing on any of the edges the good news is wing is perfect and only very light surface corrosion on inner wing. also removed the sill cover and good news is sill and rear quarter are perfect did notice the small packer/screw that holds the thermostat to the sill is broken something else to put on the list for repair the only other couple of bodges are the clips either end of the sill were put on with sikaflex rather than fixing the clips.and again rather than spraying underseal over the wing join its covered in waxoyil apoligies for the poor pictures .
 Filesize:  67.72 KB
 Viewed:  23792 Time(s)
 Filesize:  65.26 KB
 Filesize:  67.48 KB
 Filesize:  90.76 KB
Gazc2
PostPosted: Fri Jan 04, 2013 8:30 pm    Post subject: Reply with quote
well some more small progress got the door handles off , that`s a fun job getting the inside nut off , also got the mirrors off tried to seperate the bases for painting and broke a glass I have managed to do this with every set of mirrors I have removed so if anyone has a spare glass in the garage .
Got round to the rear bumper soon became apparent its never been off and probably why it was a different colour from the rest of the car. speed nuts screws with small heads no room to get a decent turn on them . I am going to look at alternative fittings putting them back.
The bonnet badge had been stuck on with sikaflex
Now the bad news is the lower lip/flange on the rear quarter has rotted out and still have some bubbles further along however will all get cut out just about ready to send to the metalwork man.
 Filesize:  54.28 KB
 Viewed:  22862 Time(s)
 Filesize:  53.59 KB
Discord23
1996 Porsche 993 Carrera 2
PostPosted: Sat Jan 05, 2013 12:45 pm    Post subject: Reply with quote
Great thread Thumb but its made me very nervous about buying one now. Dont know
1996 C2 Midnight Blue
Dear God man. Check those seals....
(Wheels approved by ChrisW)
Post new topic   This topic is locked: you cannot edit posts or make replies.   All times are GMT - 12 Hours
Goto page 1, 2, 3 ... 14, 15, 16  Next
Page 1 of 16
